  1. Sep 14, 2020 at 1:08 PM
    Tacoscar-the-grouch
    Tacoscar-the-grouch [OP] Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    SOLD!
    Have a pair of OME 2881 springs that were too much for my truck - reg cab 2.7L. Installed on truck for about 10 minutes, then swapped for some 880's. Never even left the garage with these installed. One scuff on one of the springs where the spindle hit it during install/removal. Otherwise 100% brand new.
    I will note that one of the springs is a bit longer than the other, ~1/4", or 6mm, so it would be best installed on the driver side and might fix your taco lean without the trim packer. Measurements in photos.
    Trim packer available as well - this is the kind that is installed BELOW the spring perch on the nitrocharger shocks. I do not know if it is compatible with other shock assemblies. I had a reverse taco-lean so I pulled it out with the 881's. Again, this item is brand new, never left the garage.
    Will ship at buyers expense, I would guess $25-30 to ship, but not sure. Located in Northern Idaho.
  2. Sep 15, 2020 at 9:21 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
  3. Sep 15, 2020 at 9:50 PM
    Eatbeers1stgen
    Eatbeers1stgen Well-Known Member
    2001 Toyota Tacoma 4x4 manual
    Ome front coils and shocks (881) All pro rear leafs Custom welded front Baja bumper Elocker from trd Tacoma with low range wiring harness.
    can you text me? 8056104915
  4. Sep 15, 2020 at 9:53 PM
    Eatbeers1stgen
    very interested. located in california, willing to pay shipping cost if less then website quotes.
  5. Sep 16, 2020 at 7:51 AM
    Eatbeers1stgen
    Pm me when you have a chance
  6. Sep 16, 2020 at 8:00 AM
    Tacoscar-the-grouch
    Josh
    North Idaho
    Sent you a message to this number
  7. Sep 17, 2020 at 4:12 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
