Thread Status:
Not open for further replies.
  1. May 7, 2021 at 10:35 AM
    JoeyWales
    JoeyWales [OP] Well-Known Member
    SC
    Brand New never installed. Still have the tags on the springs.
    $140
    Will ship on buyers expense. Should still be cheaper than a vendor given no tax.
    CBreck696 and barf like this.
  2. May 7, 2021 at 1:41 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Damn... I really wanna buy these but I'm too lazy to assemble coilovers myself:(
    GLWS!
  3. May 7, 2021 at 3:36 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I paid $25 per coilover at a local place. Was worth it.
    barf and Abeyancer[QUOTED] like this.
  4. May 7, 2021 at 3:57 PM
    Eatbeers1stgen
    Eatbeers1stgen Well-Known Member
    2001 Toyota Tacoma 4x4 manual
    Ome front coils and shocks (881) All pro rear leafs Custom welded front Baja bumper Elocker from trd Tacoma with low range wiring harness.
    Worst coils ever. At least in my experience. Clicks every bump for some reason with the 5100s set at second notch. Is it user error?
  5. May 7, 2021 at 4:28 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    I don’t think you’re supposed to use OME springs on any setting but 0 with 5100s.
    04Pre_Runner likes this.
  6. May 7, 2021 at 4:32 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Hey man, dont be hating in someones for sale thread :).
    But youre supposed to use em on the lowest setting.
    jackn7 and barf like this.
  7. May 7, 2021 at 4:38 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    For real. I have OME all around and love them. User error for sure.
    Abeyancer likes this.
  8. May 7, 2021 at 7:22 PM
    Eatbeers1stgen
    I didn’t mean to come off as rude. I had them at 0 but was too soft with bumper, winch and skid plate. Rides smooth and such, just makes a clicking noise. 0 notch and other notch.
  9. May 7, 2021 at 7:39 PM
    Piccup
    Piccup Active Member
    2004 Tacoma 4x4 ExtraCab
    exactly my front setup. no clicks, rides great. 881 on the 2nd notch from the bottom. I have the V6.
    I was over thinking the assembly as well, then it dawned on me as I had the front suspension off. Just use the truck to assemble and it worked like a charm. Took 2 minutes.
    Edit: I should also say, it was safer than any other method in my mind.
  10. May 10, 2021 at 5:07 PM
    56killa
    56killa Well-Known Member
    2004 Double Cab TRD 4WD
    Can you replace the stock springs with these to achieve a lift, or will there be issues with the stock shock? I need a temp/cheap solution to clear rubbing in the meantime while I wait for some king shocks for the front of my 1st gen DC.
  11. May 13, 2021 at 10:25 AM
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    I think it is unlikely that the springs would click. There are no moving parts in a spring to hit and make noise. Check every other bolt you touched on install, and make sure every joint in your steering and suspension is solid - tie rods, BJ's, bushings, stabilizer bar ends, etc. etc. Far more likely that's where your click is.
  12. May 13, 2021 at 10:27 AM
    Tacoscar-the-grouch
    Josh
    North Idaho
    It will lift to the extent that your stock springs sag, but not to the extent that an aftermarket shock would allow. The stock coil over assembly is not any longer, so will top out and that's as far at your "lift" will go. Probably not worth it, honestly.
    56killa[QUOTED] likes this.
  13. May 13, 2021 at 12:23 PM
    JoeyWales
    SC
    @JKO1998 Has some nice shocks that would pair perfectly with these.
    JKO1998 likes this.
  14. May 13, 2021 at 12:27 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's one extra nut to tighten vs installing an assembled coilovers. Pretty easy to do with a floor jack.
    Good luck with sale OP. I enjoyed the 881s when my truck was stock.
  15. Jun 29, 2021 at 6:47 PM
    CBreck696
    CBreck696 Member
    Chad
    2001 Taxoma
  16. Jun 29, 2021 at 6:48 PM
    CBreck696
    CBreck696 Member
    Chad
    2001 Taxoma
    I have read through this thread. Is this still available? I just got some 5100 and need springs. Let me know.
Thread Status:
