  1. Apr 16, 2022 at 7:51 AM
    TacoPharm
    TacoPharm [OP] Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    Finally getting around to posting this stuff. Everything is good to go and ready to install!
    Set 1: ADS 2.5 extended travel with resi and adjusters #650 springs.
    Purchased from Headstrong. Less than 5k miles on them, passenger side rebuilt by ADS due to leaking shaft seal and never reinstalled. Very little off-road time. These are in perfect condition.
    These are $2600 retail including taxplus any current lead time.
    I'm asking $1300 cash (PayPal Goods and Services add $39)
    Shipping on buyer (~60 LBS box 18x11x32 in from 92121)
    Set 2: $$SOLD$$
    ADS 2.5 rear with piggyback resis (0-2 inch lift)
    Set 3: $$SOLD$
  2. Apr 16, 2022 at 7:54 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    Assuming the rears are extended travel as well?
  3. Apr 16, 2022 at 7:55 AM
    TacoPharm
    Phil
    San Diego
    There are two versions, this is the one for the 0-2 inch lift I'll add that to the post thanks
  4. Apr 16, 2022 at 10:31 AM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    If I were in SD I'd totally pick up the battery kit.... sigh...
    TacoPharm[OP] likes this.
  5. Aug 21, 2022 at 8:20 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Reguarding set #3, if I mounted the resis in a different manner could I get the sway bar in? Or am I missing the reason why they are not compatible..? Also, is the resi mount a swaybar spacer?
  6. Aug 26, 2022 at 5:23 AM
    TacoPharm
    Phil
    San Diego
    ADS no longer sells the longer hoses or mounts for the horizontal resis mounting, but you could get hoses made to suit that purpose. The mounts I have included do attach using the sway bar bolt locations, but do not relocate the sway bar forward, which is necessary to clear the spring coil and perch. I do have a set of relocation brackets if you’d be interested. But the reason I bought Set #1 is because I broke a hose on Set #3 and didn’t want to remove the sway bar
  7. Aug 27, 2022 at 6:46 AM
    TacoPharm
    Phil
    San Diego
    Just for clarity, Set#1 installed in above picture the bottom of the resi is short enough to clear the sway bar even when flexing the suspension. However, the older ADS resi’s are longer and even when installed as far upward as possible, the hoses/connectors will interfere with the sway bar travel, sorry I have no pics. But here is how they use to be installed
    It’s my understanding the shift to the newer style was to accommodate a wider selection of tire sizes
    007fodo[QUOTED] likes this.
  8. Jan 11, 2023 at 1:43 PM
    TacoPharm
    Phil
    San Diego
  9. Jun 17, 2023 at 2:37 PM
    TacoPharm
    Phil
    San Diego
    Bump price drop
  10. Jun 18, 2023 at 6:54 PM
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    Damn, wish this wasn’t lost so far down in the mix when I bought a new set a month ago. GLWS.
