  1. Nov 21, 2022 at 1:57 PM
    KDtaco
    KDtaco [OP] Well-Known Member
    Kyle
    Los Angeles, CA
    '13 Trd 4X4 V6
    Engine:Volant Intake, Mbrp Exhaust, Lighting:30" Baja Designs Stealth Light Bar,Suspension:Total Chaos 3.5 inch Race Series w/ Kings Total Chaos Spring Under Kit, Tires:285/75/16 K02
    Item sold
    reeves1 and clenkeit like this.
  2. Nov 22, 2022 at 12:59 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Just pilin' on to help a brother out. love mine. For those of you that use your truck like a truck. The best feature is how it protects the top edge of the tailgate, so that it's a usable edge.
  3. Nov 23, 2022 at 3:50 AM
    joesgarage
    joesgarage Well-Known Member
    2007 prerunner
    3" DONAHOE SUSPENSION
    Would this still allow you to use a camper shell?
  4. Nov 23, 2022 at 5:06 AM
    KDtaco
    Kyle
    Los Angeles, CA
    '13 Trd 4X4 V6
    I think it would require modification
  5. Nov 23, 2022 at 9:17 AM
    kidsmoke
    Flyover Country
    I can’t think why you’d need to modify it. The top of the tailgate with this installed sits just a bit lower than with the OEM plastic cap.
    it’s possible that you’d want to add a gasket of some type to the topper if there’s a gap, but it would be minimal. Look at the ‘end’ view in my post above.
  6. Nov 23, 2022 at 10:48 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Works fine with my shell. No notable gap or anything of that manner
    BassAckwards and kidsmoke like this.
  7. Nov 23, 2022 at 5:00 PM
    KDtaco
    Kyle
    Los Angeles, CA
    '13 Trd 4X4 V6
    Thank you, I wasn’t sure if there would be an issue. I don’t have a topper on my truck. Also when I originally looked at getting the reinforcement I though I read something about the exterior of the tailgate has a bit of side to side curve. the reinforcement doesn’t have that same curve and that’s what causes the gap at the end of the reinforcement. wasn’t if the reinforcement being flat would cause a problem with the topper
  8. Nov 24, 2022 at 8:27 PM
    bloggerstomper
    bloggerstomper Well-Known Member
    CA
    Crumpy
    would you meet somewhere like calabasas or similar?
    I'm in SB but def interested
  9. Nov 25, 2022 at 2:31 PM
    KDtaco
    Kyle
    Los Angeles, CA
    '13 Trd 4X4 V6
    Sorry I need to keep it a bit more local.
  10. Nov 25, 2022 at 5:35 PM
    bloggerstomper
    CA
    Crumpy
    what's the farthest up north you'd be willing to go?
