Solenoid, relay or starter?
Discussion in 'Technical Chat' started by Corn, Dec 3, 2011.
  1. Dec 3, 2011 at 7:09 PM
    Corn
    Corn [OP] Active Member
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights added in 2002
    Need some opinions. Twice in the past month my Tacoma would not start. Basic issues: Full power in start position (lights, fans, radio, etc), new battery. Just a click sound. - Jumping does not help-
    Got it to start the first time by tightening the nut on the positive battery terminal. The second time it actually took disconnecting the wires to the positive battery terminal, then reconnecting after a minute.
    Does this sound like a relay issue (sticking) in the solenoid? The starter? Something different?
    Thanks.
  2. Dec 7, 2011 at 9:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds like worn out starter solenoid contacts. Common on Toyotas. If you pull the starter and open the solenoid cover to inspect, should be obvious.
  3. Apr 3, 2012 at 6:23 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    A couple of tips:
    1. After disconnecting the negative battery terminal, I would clean all of the electrical connections to bear metal including the grounds.
    2. If not the solenoid contacts, I check the starter motor brushes. Light tapping the starter motor will sometimes reseat the contacts or brushes and allow the motor to temporarily work, but they will need to be replaced.
