Solenoid/Transmission Failure at 60K?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eugino, Oct 27, 2015.
  1. Oct 27, 2015 at 3:09 PM
    Eugino
    Eugino [OP] Member
    Noah
    2010 Tacoma Pre-runner TRD
    I bought my 2010 Tacoma Pre-Runner in May with 56K from Carmax and have only put 4K miles driving back east. I experienced some low-idle/shakiness when I would bring it to a stop and I also noticed some lurching from a stop to first gear. Today as I drove it to the dealer for some warranty maintenance for the seatbelt it would not shift into 5th gear and was revving up to 4500RPMs.
    The idle issue was chalked up to be spark plug/engine misfire- not a bid deal. However,the mechanic said it returned two error codes (PO776, P2714) for a Solenoids B and D were Bad/Sticking/Off? He reported that replacing the solenoids would not solve the problem because of debris floating around in the fluid, and that replacing the fluid and solenoids would not solve it either. At the end of the day he told me I need a new transmission?
    I have to ask, am I getting screwed? Its a Toyota with 60K miles, these trucks roll around for 200K. Is there something I should do first or did I buy a lemon.
  2. Oct 27, 2015 at 4:03 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I had the same issue on my Frontier. My neighbor has owned an import auto shop since 1978 (good neighbor to have) we flushed my transmission and changed out the filter and whatnot....Ordered the wrong solenoid so...flushed the transmission again. Then ordered the right solenoid and swapped it out. I never got the CEL to turn off. Unfortunately, I blew the head gasket before I ever got it resolved. I've read several places that you can't get that error to correct. Hopefully someone else here has an answer better than my experience.
  3. Oct 27, 2015 at 5:21 PM
    Eugino
    Eugino [OP] Member
    Noah
    I don't have any lights on the dash appear, but the lurchiness seems to be typical from what I read around TacomaWorld. I am wondering if getting new solenoids or just flushing the transmission fluid like you did will solve the problem. Also, on the way home from the dealer the truck drove just fine (figures). I am going to take it to another dealer and have them diagnose the problem. I think its too easy to suggest to an owner who has just passed the warranty to replace their transmission.
  4. Oct 27, 2015 at 7:20 PM
    Eugino
    Eugino [OP] Member
    Noah
    Doh, looks like I made the classic error of draining the ATF fluid instead of the oil. I added more oil and have driven a while with this situation. I hope I didn't screw things up too bad. Im going to have the oil drained and the ATF fluid refilled. If I am experiencing this error code from the Solenoids am I totally F****d?
  5. Oct 27, 2015 at 7:28 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  6. Oct 27, 2015 at 8:05 PM
    Eugino
    Eugino [OP] Member
    Noah
    Yeah Im reading that with the transmission pan drained I should NOT drive, but I have driven a couple hundred miles. If the mechanic is saying I need a new transmission, is topping the level off going to make a difference?
  7. Oct 27, 2015 at 8:19 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  8. Oct 27, 2015 at 8:35 PM
    Eugino
    Eugino [OP] Member
    Noah
    Moondeath, whats the deal? Have I royally screwed up?
  9. Oct 27, 2015 at 8:38 PM
    moondeath
    Pa, Gardners
    Are you really saying you drove with the tranny drained?
    bobsuruncle likes this.
  10. Oct 27, 2015 at 8:41 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    Wait, you're driving around approximately 3-4 qts low on ATF?
  11. Oct 27, 2015 at 8:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think you should find another transmission.
  12. Oct 27, 2015 at 8:42 PM
    Eugino
    Eugino [OP] Member
    Noah
    Yep, I accidentally drained the pan
  13. Oct 27, 2015 at 8:42 PM
    BlueMile
    Patrick
    2009 TRD Sport
    Can you shift in and out of gear still?
  14. Oct 27, 2015 at 8:44 PM
    Eugino
    Eugino [OP] Member
    Noah
    It performs pretty normally, only had one issue today where it wouldn't shift into fifth. No lights on dash, just two solenoids sending error codes.
  15. Oct 27, 2015 at 8:46 PM
    BlueMile
    Patrick
    2009 TRD Sport
    :bananadead:
    Do not turn your truck back on, back away slowly, call a transmission shop and explain how long you have been driving without fluid in the pan.
    gearcruncher likes this.
  16. Oct 27, 2015 at 8:47 PM
    Eugino
    Eugino [OP] Member
    Noah
    I think I've driven a couple hundred miles, what is the extent of damage I could have done?
  17. Oct 27, 2015 at 8:49 PM
    moondeath
    Pa, Gardners
    Toast the tranny. I'm surprised it didn't act up with that little fluid in it.
  18. Oct 27, 2015 at 8:50 PM
    BlueMile
    Patrick
    2009 TRD Sport
    I'm not going to speculate on how much damage has been done, get a pro to come out and look at it, if you are lucky the damage will be limited to a solenoid or two.
    The reason I say don't turn the truck back on: circulation, you don't need the pump circulating any more air than it already has.
  19. Oct 27, 2015 at 8:58 PM
    Eugino
    Eugino [OP] Member
    Noah
    Pardon, but what pump is circulating air and what is it damaging?
  20. Oct 27, 2015 at 9:00 PM
    BlueMile
    Patrick
    2009 TRD Sport
    Transmission oil pump
