solid axel death wobble ?
Discussion in 'Solid Axle Suspension' started by mt sas, Feb 19, 2013.
  1. Feb 19, 2013 at 8:01 PM
    mt sas
    mt sas [OP] Well-Known Member
    western montana
    fun
    S.A.S 21spline tcase highsteer
    I have a Toyota axel up front wth leaf springs I have replaced bushings and sleeves . all steering parts are tight wheels are balanced gettn wobble around thirty five mph . any ideas ? thanks
  2. Feb 19, 2013 at 8:08 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Check all your bolts to make sure they are tight. What condition are the trunnion and wheel bearings in?
  3. Feb 19, 2013 at 8:10 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Wheel/hub bearings and trunion bearings play a large roll in the equation.
  4. Feb 19, 2013 at 8:19 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    What kinda tires you runnin?
  5. Feb 19, 2013 at 9:57 PM
    mt sas
    western montana
    fun
    I replaced the long side burfield a couple months ago wheel bearing was good then I will get it off the ground and check bolth thanks !
  6. Feb 19, 2013 at 9:58 PM
    mt sas
    western montana
    fun
    I switch between 32x11.50 maxxis and 33x12.50 xterrains depending on what kind of wheeling im doing its been doin it with bolth
  7. Feb 19, 2013 at 9:59 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    How much caster and toe are you running?
    Caster is difficult to adjust with leaf springs but can make a big difference with steering wobble.
  8. Feb 19, 2013 at 10:00 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    I would also check your bj's, tie rod ends, and the pitman arm. Those could cause DW
  9. Feb 19, 2013 at 10:14 PM
    Redneck92
    Concord, NC
    no ball joints on a toyota axle:cool:
  10. Feb 19, 2013 at 11:01 PM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    really? did not know that, what is used instead?
  11. Feb 19, 2013 at 11:04 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    knuckle balls
  12. Feb 19, 2013 at 11:05 PM
    IgnorantlyAlberta
    IgnorantlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Mud in rims?
    Wieghts feel off rim?
    Wieghts fell of drive shaft?
    If you dont get a nasty rubbing or squeeling sound I would check these first.
  13. Feb 20, 2013 at 6:37 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    ^^^Wrong. Trunnion bearings are used. It is more similar to a kingping axle than a ball joint axle.
  14. Feb 20, 2013 at 9:23 AM
    mt sas
    western montana
    fun
    ive got a trail gear highsteer set up thats 6months old every thing externally is tight and all isgreased i will check out my steering box tonight thanks bighorns have 5000 miles on em xterrains are hammerd does it with bolth
  15. Feb 20, 2013 at 9:25 AM
    mt sas
    western montana
    fun
    all is good front driveshaf is perfect
  16. Feb 20, 2013 at 10:47 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Yeah totally uses trunnion bearings on a c knuckle
  17. Feb 20, 2013 at 11:14 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    It uses trunion bearings on the knuckle ball. But the force is on a bearing not a ball joint. The knuckle ball does nothing except enclose the birfield so it can run encased in grease instead of open to the elements. Otherwise it acts as the "C knuckle".
  18. Feb 20, 2013 at 3:41 PM
    KenLyns
    Belly of the Beast
    Did you get an alignment done after the SAS install? What were the numbers?
  19. Feb 20, 2013 at 5:17 PM
    mt sas
    western montana
    fun
    yes it was aligned I don't know the number it drove great for the first 5000 miles
  20. Feb 20, 2013 at 7:20 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Did you shim it properly when installing the hi-steer arms?
