Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Jun 1, 2012 at 6:02 PM
    #181
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Yes you are right. 3-link does articulate better.. :eek:
    But, I know you have ran into numerous problems with your three link system... sometimes they aren't always easier
  2. Jun 2, 2012 at 8:57 AM
    #182
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Granted, nothing is ever easy when your trying to put something that was not in the oringinal design concept of a vehicle especially when you were the first with said vehicle, however, once it was designed and put together it works flawlessly now and has been copied time and again.
    Trying to put a four link either in the front of one of these trucks or in the rear of one of these trucks has many issues. First, if you use a triangulated system in the front you'll have to have the truck sitting too high to be of any use because of where the engine sits. Second, if you use a parallel system, you will need to run a panhard bar to keep the axle from moving side to side. Now you have five links instead of four links.
    In the rear if you use a four link triangulated system you will have to move the fuel tank to get it to work or you can just have a truck that is sitting really high to make it work. Then again running a parallel four link system you have to run a panhard bar.
    To me it's just simpler and better to run a three link as opposed to any four link system.
    Not trying to bash on you. Your one of the few who were brave enough to step out and tackle something like this by yourself. just want everyone to have enough information to make a decision on how to approach their projects.
  3. Jun 2, 2012 at 10:48 AM
    #183
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    What is the typical cost of trying to do a home brewed 3 link?
  4. Jun 2, 2012 at 12:04 PM
    #184
    Supra TT
    Eric
    Indiana
    I see, I see. You are the brave one, cutting up an 05 first week off the lot! :eek:
    Anywho, thanks.
    Rear, front? Both?
    ShiftyShank likes this.
  5. Jun 3, 2012 at 8:11 AM
    #185
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Just the front. Also, in my shopping/searching I have more questions. Aside from axle shafts, knuckle service kit, and a 3rd member rebuild/re-gearing, what else should I be purchasing and from where to do a complete rebuild for this axle I bought?
  6. Jun 3, 2012 at 8:59 AM
    #186
    Supra TT
    Eric
    Indiana
    Typical cost for the front 3 Link I would say would be around $1500 or more depending on if you make your brackets. Heims aren't cheap and neither are C/Os.
    And parts can be purchased from numerous places I believe. I know http://www.marlincrawler.com/axle/front-axle-parts/service-parts For sure
    You will want the trunion eliminator kit too, and axle ball gussets
  7. Jun 3, 2012 at 9:13 AM
    #187
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    For $1,500 it sounds like I am better off just going with leaf since I won't be doing hard core rock crawling. Since you mentioned Trail-Gear to me a while ago I have been shopping them mostly and marlin crawler. For the Marlin Crawler stuff does the pick up also fall under the Hilux parts?
  8. Jun 3, 2012 at 10:28 AM
    #188
    Supra TT
    Eric
    Indiana
    Yeah CO's are no joke on price. Leafs can be done for like half that or less. And leafs work great, I love my leaf springs, haven't let me down yet, and they aren't even set-up properly... :D
    Hilux and pickup I believe are the same thing. Call them if you need to they are good guys there.
  9. Jun 3, 2012 at 11:03 AM
    #189
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Right on man, good lookin' out. Do you see any major issues running 4.88's on a 27 spline axle for 35's? Or for that matter 5.29's?
    edit: Just read an article here http://www.fourwheeler.com/techarticles/129_0409_birfield_eliminator_kit_install/index.html and now I am confused if the front diff is a 30 or 27 spline axle carrier. WTF. FML. Mind=blown.
  10. Jun 3, 2012 at 11:28 AM
    #190
    Supra TT
    Eric
    Indiana
    I would run 5.29's Lower is usually better. I regret not going lower IMO. And I'm at 5.38s on 39s...
    The diff is what ever it is, the difference in spline count they are talking about is on the outer splines. Usually if you run 30 spline you may need to grind the knuckle a littler since they are bigger shafts to fit. If you have the extra money get the 30 spline... They are only like $60 more. Also if you buy axles, get them from longfield axle... trust me, he has the best.
    Like my dana 44 has 19 spline outer, 30 spline inner. I can upgrade to 30 spline outer but........... $$$ for me.
  11. Jun 3, 2012 at 11:49 AM
    #191
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    So essentially if I stay with the Birfield's I would have a 27 spline inner and a could use a 30 spline outer if I so chose to? I would prefer to run chromoly 30 spline axles for that peace of mind while out and about. The other thing too is that this 22RE is (maybe) pushing 100bhp so would 5.29's be overkill? I am trusting you on this cause I don't have shit for a clue of what I'm doing with SAS and I've read through your build maybe 50 times.
  12. Jun 3, 2012 at 12:37 PM
    #192
    Supra TT
    Eric
    Indiana
    I don't think you can use the original inners (maybe) but you would need to replace the CV joint, since I believe it is different. (I really have no clue) It only would make sense to me in order to use the bigger outer, the CV would need to be bigger.
    I would call longfield and verify what I said above, ^ since I am not sure..
    Also, If you are concerned with it go with 5.13s? Instead of 5.29s. My truck only has 145BHp and 5.38s are not low enough. Lower gear ratio = more control.
    Are you driving it on the road?
  13. Jun 3, 2012 at 7:30 PM
    #193
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    5.13's might not be a bad idea. As of right now no. When it's all said and done the only road time it will see is to and from trails local to me in AZ. No interstate/freeway driving for this rig.
  14. Jun 3, 2012 at 8:34 PM
    #194
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    What size tire are you wanting to run? My buddies crawler/DD has a 22R on propane. He's running 36in Iroks with 5.29's and he said that it's right at stock, maybe just a little more pep. He also has 4.7's in the case and his rig does great!
    As far as the three link, you'll have a pretty penny in it but it's well worth it! Linke SupreTT said, the shocks are pricey and the joints are a kick in the nuts... especially since there's so many of them.
  15. Jun 3, 2012 at 9:34 PM
    #195
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    End goal was going to be 35'' tires, on 5'' of lift, running 5.29's, on a Detroit locker and probably 5 more years down the road dual transfers. The axle spline count is what has me worried about doing that. If I can run chomoly 30 spline axles then I'll do it. Also planning on running a rear Detroit as well (but I guess that is a given).
  16. Jun 4, 2012 at 3:49 AM
    #196
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    Gotcha, sounds like a clean setup and you definitely doing it right... My buddy is running stock shafts in his right now. So far he's only busted one shaft, but he was just being stupid when he did that. I think he's doing the Dirty 30's here in a few months just so that it would be one less thing to worry about.
  17. Jun 4, 2012 at 9:24 AM
    #197
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Make sure you get chromo tcase output shafts.. learned the hard way with a single case..upgraded to a double case when we switched out the broken shaft
  18. Jun 4, 2012 at 5:29 PM
    #198
    Supra TT
    Eric
    Indiana
    Oh yeah, THIS ^
  19. Jun 4, 2012 at 9:16 PM
    #199
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    here are the options for your toy front axle:
    stock inner shafts with stock birfs
    stock inner shafts with chromoly 27 spline birfs
    chromoly inner shafts with chromoly 27 spline birfs
    chromoly inner shafts with chromoly 30 spline birfs(trail gear dirty 30's and longfield 30 spline axle shaft set)
    if you have the cash go straight to either tg dirty 30's or the longfield 30 spline axles, well worth the money. couple friends of mine just run stock birfs and maybe break 1 or 2 a year but that is being really careful on the rocks, they are both getting 30 spline axles soon though.
    5.29's and 35's are perfect for a 22re and even the 3.0, thats what i wish i put in my truck, and i have 4.88's with 35's. you have a choice of 4.88's to 5.29's they do not make anything in between for toy axles. hope that helps if you have any other question feel free to ask me.
  20. Jun 4, 2012 at 9:33 PM
    #200
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    You'll want hydro assist steering too :D the 85 4runner my dad I built we went with
    30 spline longfields
    Front arb
    Rear detroit
    5:29 gears
    4.7 transfer case gears
    Hi steer but looking to get hydro.
    I've got my own sas'd 88 4runner with 4.7 gears in the transfer case and locked rear but just stock everything else other than hi steer.
    Sounds like you have a good plan though :thumbsup:
