Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Jun 24, 2013 at 4:11 PM
    #1981
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    me too :(
    wish i wouldnt have sold my 35 spline d60....... getting hard to find them.... guess I could do what NWI did.... :(
  2. Jun 24, 2013 at 4:59 PM
    #1982
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Does anyone know the difference between an 1987 Wagoneer vs a 1987 Grand Wagoneer? or perhaps the wagoneer vs grand wagoneer in general when it comes to axles. I know one turns into the (cherokee) like body style. But are they both running d44 up front?
  3. Jun 24, 2013 at 5:18 PM
    #1983
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    hmmmm their is a 9" center with d60 outers in my area for cheap........
    whats the downside of running a 9 center on a second gen????
    I know you gain more clearance on a 9" center - you still have the strength of a d60 outer as thats what it is........
  4. Jun 24, 2013 at 6:47 PM
    #1984
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Pretty sure the axles are the exact same. The difference was one was more luxury (grand) with a bigger motor option.
    What is the price? In reality... it's not a good buy.. Is it even driver side drop?
    Why it's not good: You are now leaving your weakest link in the ring and pinion which is never a good thing.
  5. Jun 25, 2013 at 9:36 AM
    #1985
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Maybe :p
  6. Jun 25, 2013 at 9:37 AM
    #1986
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Everything i've read - goes back and forth. I'm just gonna go check it out and pull the BOM numbers off and look those up.
  7. Jun 25, 2013 at 10:39 AM
    #1987
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    B.O.M. number. It tells you the Bill of Materials for the axle...hence BOM
  8. Jun 25, 2013 at 10:42 AM
    #1988
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    that's right ;)
  9. Jun 25, 2013 at 11:48 AM
    #1989
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Mark, I think I owe you a new 1" breaker bar.:eek:
    I finally got the kingpins off, but now there's a slight bend in the breaker bar. Cracked one of the KPs in the process as well.
  10. Jun 25, 2013 at 12:18 PM
    #1990
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Haha glad you got them out. Woulda had a hell of a time with a 1/2" breaker lol :D
    And I am not too worried as long as its not too bad.
  11. Jun 25, 2013 at 5:01 PM
    #1991
    Supra TT
    Eric
    Indiana
    Well, when you go to put the new ones in... it should straighten the bar [​IMG]
  12. Jun 25, 2013 at 8:17 PM
    #1992
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I wouldn't say there is a downside to running it. Really depends how hard you wheel. Is it a Spidertrax housing or stock Ford 9 with D60 ends welded on? Price? Driver drop?
  13. Jun 26, 2013 at 5:13 PM
    #1993
    Supra TT
    Eric
    Indiana
    Brian, did your D44 steer very well? (As in degree of turning) Mine just plain sucks. I have the reid racing knuckles and I never ground down the steering stops. I have my ram limited about 1/16" before the stops too, but the thing just cannot turn... It's about as bad as a f-350 longbed :(
  14. Jun 27, 2013 at 5:32 AM
    #1994
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Eric-as I said its an easy fix.
    1. Cut the whole cast stop off the Reid knuckles.
    2. Turn Wheel until axle u-joint begins to bind.
    3. Reduce internal ram spacer to new length.
    4. Enjoy tighter turning radius.
  15. Jun 27, 2013 at 1:19 PM
    #1995
    Supra TT
    Eric
    Indiana
    Yes I am going to do that, but you have my grinder :D
    Won't get much turning anyway since the fucking leaf springs will limit it
  16. Jun 27, 2013 at 1:31 PM
    #1996
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Wheel spacers?
  17. Jun 27, 2013 at 1:31 PM
    #1997
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    sounds like you should convert to links
  18. Jun 27, 2013 at 1:32 PM
    #1998
    Supra TT
    Eric
    Indiana
    Links [​IMG]
  19. Jun 27, 2013 at 1:42 PM
    #1999
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    YES!!
  20. Jun 27, 2013 at 4:13 PM
    #2000
    Supra TT
    Eric
    Indiana
    But no time to do links. And really I don't even know which end to link...
    Obviously the pros will be the same for each axle... mostly
    Cons for front: gotta cut off my new hydro mount... minimal space with a D44..
    Cons for back: 4 link rear (gotta move gas tank)... A good pro of the back is that I can move my wheelbase down to about 121" or so.. can't really move the wheel base with the tank in the way, could still 3 link, but why 3 link when the tank is moved?.. With the front I can't move my WB and I am once again a limo..
    I think I just need to re-do the rear and get some bedsides, it won't look as funky :D
