Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Aug 18, 2013 at 9:54 PM
    #2281
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Personally I wouldn't even bother with a D60 rear. D60 rears have mostly all 30 spline axles unless you go with a semi-float axle but no one does that if you want 1 tons :D You do get a bigger ring gear than a Toyota axle which is good but you'll have to upgrade the axle shafts in some way or another. The benefit is LOW axle gear ratios :)
    Build a 14 bolt, I worked on mine today :cool: 5.38 thick gears and ARB are installed minus the pinion :cool:
  2. Aug 18, 2013 at 10:00 PM
    #2282
    downpour11
    downpour11 Well-Known Member
    Rob
    Chico, CA
    96 4runner
    1996 4runner SR5 4x4 - 419,000 miles, 14" Spacer Lift
    Now you need some of these: http://www.pirate4x4.com/forum/axles-tires-wheels-sale/1414794-new-43x14-50x17-tsl-wheels-sale.html
    damn good deal
  3. Aug 18, 2013 at 10:00 PM
    #2283
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    :jellydance: !!! More pics of the exo/bed section? Looks a lot like how I want to build mine.
  4. Aug 18, 2013 at 10:22 PM
    #2284
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
  5. Aug 18, 2013 at 10:28 PM
    #2285
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    It's booger weldz old 4 door that he sold. I have a couple more. My buddy built the badass tire carrier that uses a winch at the third brake light to raise and lower :cool: They plan to get rid of the 3/4 elliptical setup and install coilovers.
  6. Aug 18, 2013 at 10:46 PM
    #2286
    downpour11
    Rob
    Chico, CA
    96 4runner
  7. Aug 19, 2013 at 1:26 AM
    #2287
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Let's just say, I've been bit by the bug. And for the first phase, it wont be anything insane. Just enough to get me rolling and finally say I did a SAS on a 2nd gen.
    We have front D44's with lockers lying around here that could be put to better use. Full float 35 spline D60's in the future, but for the tires I want to run (37's) the stock Toyota rear housing with a trussed/sleeved/gussetted D44 up front will be fine with a few adjustments (ring/pinion, regear, lockers, etc). Thinking King 2.5" IBP resi coilovers up front, PSC hydro steer, custom shackle mounts in the rear with a custom Deaver pack, caged bed for upper shock mounts (possibly building to adapt to links in the future), and definitely going with some mud terrains on beadlocks. :)
    As far as the t-case goes, I'd love to put in a TacoBox "Taco Supreme" with 4.70 ratio mated to a 1 piece rear shaft like Wyatt's, and a 1350 CV front shaft.
    I want to keep the truck looking like a truck and not a trail rig. It's going to still be my daily driver, so 40's are out of the question until I can buy a commuter. With that being said, I'm planning on running Glassworks front fenders and flat bedsides, and finding a way to keep the Bestop would be nice.
    I just know I'll be running into a buttload of electronic issues such as ABS sensors throwing codes for the VSC, Auto LSD, Steering alignment light, etc. Not really looking forward to all that.
  8. Aug 19, 2013 at 1:44 AM
    #2288
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Link it stealthily like alove
  9. Aug 19, 2013 at 6:22 AM
    #2289
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Wait lemme make sure I hear this right. You are gonna go through the work of a SAC and waste your time with a D44 and reuse the stock rear end that isn't even locked?
    You sir belong in the FAIL thread.
  10. Aug 19, 2013 at 6:24 AM
    #2290
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    I'll keep my Full float 35 Spline D60 rear and my extra clearance over a shaved 14Bolt any day of the week.
    You are right...you've gotta find the right axle or do the work to the one you can find, but I still believe its a better option over the 14bolt.
    I do wish I could set up my damn gears as easy as you can on a 14bolt though!
  11. Aug 19, 2013 at 6:30 AM
    #2291
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I would at least do the D-60 for the front from the get go you don't want to do it twice trust me. You don't need to run 40's with the 60. I DD my rig just fine and I linked both ends. don't put int he 44 on a 2nd Gen you will be braking shit left and right.
  12. Aug 19, 2013 at 7:13 AM
    #2292
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Yeah $600. It'll get me by for the time being until I can save up for some nice tires.
  13. Aug 19, 2013 at 7:19 AM
    #2293
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Yeah you did the same thing I did with the last D60 rear I had (but sold). Bored out the spindles to accept 35 spline shafts :D Really happy I got the 14 bolt! The only special shims you need are for the pinion and the pinion unbolts with 6 bolts, the shims sit behind there. The adjusters give you proper backlash. It's really no wonder why people are turning them into front axles!
  14. Aug 19, 2013 at 8:26 AM
    #2294
    The Traveler
    SoCal
    Can you elaborate on that a bit? I work with JK's all day long that run 37's on built D30's, so I'm wondering why the 44 wouldn't work in the 2nd gen? Just curious, I'm still learning about how these behave in the Toyotas.
    And yeah a built RockJock 60 would really be nice, but I can't swing that just yet.
  15. Aug 19, 2013 at 8:27 AM
    #2295
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    37's on D30's....bahahahaha. They must wheel "hard" alright :rolleyes:
    I've watched stock 31's bust D30 shafts.
  16. Aug 19, 2013 at 8:28 AM
    #2296
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    yah ive been around plenty of d30 37's..... all they are good for is driving around town....
  17. Aug 19, 2013 at 8:45 AM
    #2297
    The Traveler
    SoCal
    What about a sleeved and trussed 44 with chromoly shafts?
  18. Aug 19, 2013 at 8:47 AM
    #2298
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    youll just be breaking inner parts still.... our trucks just have too much weight as a second gen, CanadianBum John did a D44 in his truck swapped to chromoly started breaking side gears
    he wishes he wouldnt have wasted his time doing a d44, now has a built d60 f+r ready to go in
  19. Aug 19, 2013 at 9:05 AM
    #2299
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Look at Erics 1st gen...he wheels hard. He is way lighter than us and its fully built and he hasn't really had any issues, but....HE STILL WISHES HE WENT WITH A 60 INSTEAD.
    We are really just trying to help you. Its a big enough job to do once, let alone twice.
  20. Aug 19, 2013 at 9:15 AM
    #2300
    JLee
    Jerry
    Grass valley CA
    LOL yeah it's a JEEP thing :rolleyes: I would never put a 44 under a Tacoma. maybe a reg cab 1st gen but that's about it. You guys are way too heavy for a Dana 44.
