Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Oct 16, 2013 at 5:52 AM
    #2621
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I'd keep the tons. What parts are you needing to source. I can help you find what you need easy and I have a bunch of fasteners, etc. from my axle since I replaced everything :D
  2. Oct 16, 2013 at 8:51 AM
    #2622
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    im with this guy ^^^^^ i mean i love toy axles but in the long run they are just as expensive as tons and still not as strong.
  3. Oct 16, 2013 at 11:20 AM
    #2623
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Everything except the house and diff cover, bolts included. I just don't have the time to source all the parts. Plus after looking at what I'd spend buying them I'd be better off just buying a complete 60. I know I'll be giving up a little strength but since I only plan for 37s I'd rather have the extra ground clearance and less weight. Ill eventually build a one ton rig but not right now. Maybe the Tacoma will get tons down the road.
  4. Oct 16, 2013 at 1:09 PM
    #2624
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    Because you are using fj axles. Do you plan on staying with radius arms or linking ?
  5. Oct 16, 2013 at 1:24 PM
    #2625
    Redneck92
    Concord, NC
    Neither cause I'm a cheap ass. I've already got my rig set up with leafs and it'll stay that way for a while. In hind sight I should have link it, but don't feel like doing it now. The suspension is pretty much done just needs shocks and bumps.
  6. Oct 16, 2013 at 1:27 PM
    #2626
    rctoy
    konstantenos
    Pocatello Idaho
    There is nothing wrong with leafs.. i ran them for my 94 sas and got 13" of flex out of each side at the spring.. Though links alow for more control of the axle esp. when running bigger tires. so no death wobble.
  7. Oct 16, 2013 at 1:30 PM
    #2627
    Redneck92
    Concord, NC
    Not saying there was I like them for the simplicity over setting up a home brew link setup. It should flex rather well I think just from flexing it with the jack. The rear has some panty dropping flex, the front not near that level though.
  8. Oct 16, 2013 at 4:20 PM
    #2628
    06tacomakev
    Kev
    Victoria BC
    No worries. Leafs are effective. I was just hoping to see someone do a radius arm setup fr the beginning. Just see the numbers.
  9. Oct 16, 2013 at 6:08 PM
    #2629
    Redneck92
    Concord, NC
    I had thought about it for my Tacoma Just due to the system is already designed and I know it works great for a dd/wheeler setup. Only bad thing is the FJ80 radius arm setup leaves alot to be desired, but it'd be stupid easy to set up.
  10. Oct 16, 2013 at 6:18 PM
    #2630
    06tacomakev
    Kev
    Victoria BC
    That is the draw it seems to be a great DD setup. I was considering it for my 06. But now I am hunting around for a 2000-2001 Dbl cab trd. House and baby take priority right now. I think the first gen that I find will end up getting the treatment at some stage.
    Sounds like you have a pretty good setup going.
    Hey rctoy, when you did your leafs on the 94, How much up travel were you getting as opposed to downtravel? just wondering
  11. Oct 16, 2013 at 6:26 PM
    #2631
    rctoy
    konstantenos
    Pocatello Idaho
    i had the allpro 5" leafs and 6" shackels they gave my heavy ass caged truck 5.5" up and the rest down. was perfect but for some odd ass reason the right spring would sag out after like 8 months.
  12. Oct 16, 2013 at 10:21 PM
    #2632
    downpour11
    downpour11 Well-Known Member
    Rob
    Chico, CA
    96 4runner
    1996 4runner SR5 4x4 - 419,000 miles, 14" Spacer Lift
    Fixed the rear panhard bracket, it was coming in contact with the rear drivers side coilover.. finally got to fully flex it.
    IMAG0023
    IMAG0021
  13. Oct 16, 2013 at 10:23 PM
    #2633
    Slodgetto
    Slodgetto Ăśber Posre
    Silas
  14. Oct 17, 2013 at 6:34 AM
    #2634
    Redneck92
    Concord, NC
    Flexy HoRunner
  15. Oct 17, 2013 at 7:25 AM
    #2635
    rctoy
    konstantenos
    Pocatello Idaho
    time for bumpers now.
  16. Oct 17, 2013 at 9:08 AM
    #2636
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    1st gen double cap FTW! ;)
  17. Oct 17, 2013 at 9:25 AM
    #2637
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    FJ80 front don't flex for shit, all the land cruiser guys try but it's about worthless for flex.
    Those axles can be built pretty damn stout. The birfs are a lot larger than mini truck axles. Chromos and some knuckles and you'll only ever break 3rds lol.
  18. Oct 17, 2013 at 9:33 AM
    #2638
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    So would that be an appropriate leaf/ shackle set up for 42s and deliver a lot of articulation? Or since I want a cage as well would I I need something a bit stiffer to hold the extra weight
    The allpro 5" springs all around and some 6" shackles.
  19. Oct 17, 2013 at 10:11 AM
    #2639
    rctoy
    konstantenos
    Pocatello Idaho
    when i ran the Allpro 5" springs and a 2" body lift on my 94 extended cab i still rubbed 37's so no it's not.
    The Allpro link kit is set up to clear 37's but if you wanna run the big boy shit you better start looking into building your own set up and as far as the axle has to go forward to clear big tires at full stuff you will have to let go of your easy leaf idea and switch over to links my friend..
  20. Oct 17, 2013 at 10:16 AM
    #2640
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Looking good we will defiantly have to hit some trails next season.
