Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Oct 22, 2013 at 12:09 PM
    #2681
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    This is true. Yep gonna be a lot of suspension work huh??? Lol
  2. Oct 22, 2013 at 12:13 PM
    #2682
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Ha ha who said anything about teasing ;d
  3. Oct 22, 2013 at 12:21 PM
    #2683
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    At least your clearances for 4d's. Looks good bud. Just read the build yesterday and your god some impressive ideas
  4. Oct 22, 2013 at 5:40 PM
    #2684
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Brand new Davez offroad front toyota springs with horrible shackle angle from the initial swap. Unfortunately the frame is at 28". 7" uptravel though :D . Shackles are straight up and down most likely giving it 2" extra. I need to add my winch again too, should bring it down a tad.
    This is the truck before the new springs.
  5. Oct 22, 2013 at 5:49 PM
    #2685
    Supra TT
    Eric
    Indiana
  6. Oct 22, 2013 at 8:39 PM
    #2686
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    A few adjustments to make sure everything clears and it should be good I hope.
    How many degrees of steering should I be aiming for? What's an acceptable number?
  7. Oct 22, 2013 at 10:41 PM
    #2687
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  8. Oct 23, 2013 at 5:59 AM
    #2688
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I out the factory stops back in so I have exactly the same amount of steering as it did under the F350. I am using all of the ram's stroke so I can't really get more at this time.
  9. Oct 23, 2013 at 6:45 AM
    #2689
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Not sure. Maybe where the u-joints in the axle shafts don't bind? Looks badass! From full bump to full droop, how much does the axle shift side to side?
  10. Oct 23, 2013 at 6:59 AM
    #2690
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    14bolt drums, dana 60 discs, what size master cylinder? Any thoughts? Anyone? :S
  11. Oct 23, 2013 at 7:06 AM
    #2691
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    didnt this get covered???? Ive heard the Tundra MC works but i know that a chev K3500MC works..
  12. Oct 23, 2013 at 7:14 AM
    #2692
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Depends what D60 calipers, chevy or ford. Best bet is to measure the piston diameter and calculate the hydraulic ratio, the closest to stock would be your best bet.
    For me it was a 1Ton T100 master cylinder.
  13. Oct 23, 2013 at 8:23 AM
    #2693
    rctoy
    konstantenos
    Pocatello Idaho
    I have a T100 MC doesnt look any bigger than My taco MC ill have to look into this little deal seeing how as after this next springs moab trip im gonna start my sas...
  14. Oct 23, 2013 at 8:25 AM
    #2694
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Well look closer because it is. :D
    Taco MC is 13/16" dia.
    T100 is 1" dia.
    1 Ton T100 is 1 1/16" diameter. Only made the 1 Ton T100 for a few years.
  15. Oct 23, 2013 at 8:38 AM
    #2695
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'll be running a chevy 60.
    Was thinking of hydroboost but it'd be a lot easier/cheaper if I could run my stock 92 80 MC and booster. It's already set up for rear drums/front discs too (at least I'd assume there would be the proper residual valves). It's a 1" MC.
  16. Oct 23, 2013 at 8:50 AM
    #2696
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Start here:
    http://home.4x4wire.com/erik/4runner/brakes/#Basics
    Do the math, it doesn't lie.
  17. Oct 23, 2013 at 9:15 AM
    #2697
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thanks for the link, sounds like I need to go hydroboost as originally intended.
  18. Oct 23, 2013 at 9:25 AM
    #2698
    rctoy
    konstantenos
    Pocatello Idaho
    I didnt even know they mad a 1ton T100 Do you know what years it was made im goning to see if i cant hunt down a MC off of one.. gonna be lazy and try to stick with toyota shit under the hood.
  19. Oct 23, 2013 at 9:36 AM
    #2699
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    I know it was offered in '95.
    I got mine from Rockauto
    CENTRIC Part # 13044722
    RWD; Non-ABS; 1 Ton
  20. Oct 23, 2013 at 9:52 AM
    #2700
    rctoy
    konstantenos
    Pocatello Idaho
    found on for $54 local parts store nice..
