Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Feb 18, 2014 at 10:56 AM
    #3541
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    It's like you are all speaking another language in here - where's the "key" :eek::)
  2. Feb 18, 2014 at 10:57 AM
    #3542
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    full hydro steering is what we are talking about..
  3. Feb 18, 2014 at 11:04 AM
    #3543
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    all the welding plate/boxing frame/etc..
  4. Feb 18, 2014 at 12:10 PM
    #3544
    rctoy
    konstantenos
    Pocatello Idaho
    oh that stuff.. yeah you weld on 3/16 or in my case 1/4 plate steel to help reinforce the frame where you will have mounts and steering attached to the frame. the factory frame is only 10guage and thats not all that thick of metal to have a gear box bolted directly to..
  5. Feb 18, 2014 at 12:42 PM
    #3545
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Hydro assist for me :cool:
    Everyone is talking about plating the stock frame, aka polishing a turd. When you put big tires on a flimsy frame that wasn't designed for it, problems arise (shocking). While it may be easier for some to buy pre-cut plates and weld them on, the more permanent solution to the problem is cutting the stock frame out and building a new section of frame out of thicker material.
  6. Feb 18, 2014 at 12:44 PM
    #3546
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    yes but 2 layers of thinner material "laminated" together are stronger then one layer of the same material in the same thickness
  7. Feb 18, 2014 at 12:44 PM
    #3547
    rctoy
    konstantenos
    Pocatello Idaho
    This is true, but im not going to rebuild my frame just add lots to it..
  8. Feb 18, 2014 at 12:49 PM
    #3548
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Hydro assist for me as well. I'm putting together a kit that will cost me about 120 bucks. My frame is boxed by the previous owner with 1/4 plate and its still flexy
  9. Feb 18, 2014 at 2:41 PM
    #3549
    rctoy
    konstantenos
    Pocatello Idaho
    full hydro steering will put less steering stress on the frame so it's kinda a different world for me..
  10. Feb 18, 2014 at 3:00 PM
    #3550
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Even with a 2x3 frame I'd still plate around the steering box area just for added insurance.
  11. Feb 18, 2014 at 3:12 PM
    #3551
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    x2, I did the same 2x3 .188 wall and plated both sides with 1/4" where the steering box mounts.
  12. Feb 18, 2014 at 3:15 PM
    #3552
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    1/4" is plenty. I will probably do 3/16".
  13. Feb 18, 2014 at 3:23 PM
    #3553
    rctoy
    konstantenos
    Pocatello Idaho
    just so im clear you guys are doing this 2x3 frame replacement mainly for the gear box right??
  14. Feb 18, 2014 at 3:28 PM
    #3554
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    No, because it's cleaner, easier to do then using the old frame. Plus I don't have to cut any off the sides or bottom to clear coilovers or the panhard/drag link.
  15. Feb 18, 2014 at 3:37 PM
    #3555
    rctoy
    konstantenos
    Pocatello Idaho
    OK thanks. guess thats something ill have to figure out when i get there but in my head right now ill be fine just plating the side and bottom with 1/4" and building a new cross member.
  16. Feb 18, 2014 at 4:10 PM
    #3556
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    This i had my frame cut out and rebuilt in 3 hours ready to go. I would hate to cut and grind all the brackets off on the stock frame.
  17. Feb 18, 2014 at 5:25 PM
    #3557
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    It is stronger. Also, it's 100x easier to not spend 3 or 4 hours grinding the stock brackets off. Did that on my last truck and....NEVER AGAIN. Grinding sucks!!
  18. Feb 18, 2014 at 7:38 PM
    #3558
    rctoy
    konstantenos
    Pocatello Idaho
    Plazma cutter/ 7" wild cat grinder/ air chisel no fear here. im gonna do it the hard way and that way it gives me something to do down the road.
  19. Feb 18, 2014 at 8:43 PM
    #3559
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    I had an oxy-acetylene torch and a 4 1/2" grinder. Was down to the frame in about an hour from the first cut
  20. Feb 19, 2014 at 7:13 AM
    #3560
    rctoy
    konstantenos
    Pocatello Idaho
    ive done lots of sas's im not worried about the time it takes to clean up a frame and im just not seeing the need to replace it.
    Edit: in my case i dont see the need
