Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Mar 11, 2014 at 8:14 AM
    #3821
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Why have I not heard of Ackerman angle until now... :anonymous:
    Assuming they're not k-spec? (are those even available yet?:confused:)
  2. Mar 11, 2014 at 8:56 AM
    #3822
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I think that's all they make in the 40"
  3. Mar 11, 2014 at 9:35 AM
    #3823
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    40" trail grapplers and trail gear creeper locks ordered. Fuck it.
  4. Mar 11, 2014 at 10:05 AM
    #3824
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Because it's not a big deal :p
    Where did you find Trail Grapplers? And how much are they? Should be a nice setup with Trail Gear beadlocks.
  5. Mar 11, 2014 at 10:17 AM
    #3825
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  6. Mar 11, 2014 at 10:20 AM
    #3826
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Sounds like you still need a spare. I never understood getting only 4 tires...
    Nice tire choice though. Interested in how they perform!
  7. Mar 11, 2014 at 10:29 AM
    #3827
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah spare will be used. I've got a while to find one.
  8. Mar 11, 2014 at 11:41 AM
    #3828
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Well hope you don't get a flat or slice a sidewall.
    My thoughts are the larger the tire the more critical having a spare is. I personally would never drive anywhere except to the tire shop without a spare.
  9. Mar 11, 2014 at 12:55 PM
    #3829
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    You've got those paper thin sidewall BFG KM2's huh? I could see you needing a spare at all times :p
  10. Mar 11, 2014 at 1:01 PM
    #3830
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Yeah funny thing is everyone that says that hasn't run KM2s, they just regurgitate what they "heard". I have seen plenty Kevlar sidewalls tear in two as well, but I don't go around bashing mtr's. :rolleyes:
    I have/do run them and have no issues. Haven't needed a spare yet. That doesn't mean I am going leave it at home, either.
    And regardless of what tire, unless it is a solid rubber tire like a forklift, it is possible to get flats, and it will happen.
    Proper planning prevents problems. If someone I am with gets a flat and has no spare, not my problem and I will/have left them there. If you cant afford a full set of 5, you really can't afford new tires yet, IMO.
  11. Mar 11, 2014 at 2:08 PM
    #3831
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I have not run KM2's. I was just ribbing you :p I have 5 BFG Baja KR's, just need a spare rim.
  12. Mar 11, 2014 at 2:18 PM
    #3832
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Anyone run KM2s at KOH? How'd they fare?
    You can read a million threads on mtrs vs km2s and it's all the same, back and forth with no consensus. I really wanted to step up into big boy tire land and get pitbull/swamper/maxxis type sidewalls but everything I read about the 40" trail grapplers said they have outstanding sidewalls and held up awesome at KOH.
    But yeah I don't think I'll have any problems with flats in my garage. Don't you worry about my spare. I'll get one by the time she's up and rolling err running. And I definitely don't need to waste money on a 5th new tire. I'm not they type of guy who rotates his spare tire though. It's a spare for a reason. However, I could afford it.
    So when you stepping up to 40s? :p
  13. Mar 11, 2014 at 2:30 PM
    #3833
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I know for a fact MT/R's do really well in sharp Arizona rocks. KM2's get shredded to hell. Other BFG's work good but not KM2's.
  14. Mar 11, 2014 at 2:31 PM
    #3834
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I read somewhere on Pirate that those 40" Trail Grapplers weigh over 100lbs each :eek: That's burly!
  15. Mar 11, 2014 at 2:34 PM
    #3835
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
  16. Mar 11, 2014 at 2:37 PM
    #3836
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  17. Mar 11, 2014 at 2:46 PM
    #3837
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    on the plus side, it's just more weight down low to keep the cog lower
  18. Mar 11, 2014 at 3:53 PM
    #3838
    BradyT88
    BradyT88 Well-Known Member
    It's also extra weight that will always help you grip rocks. Like if you get a little high centered, you just lost a good chuck of your sprung weight that was on your tires, but you tires and all the rest of your unsprung weight will help the tires get some grip assuming they are still touching the ground anyway. haha
  19. Mar 11, 2014 at 5:11 PM
    #3839
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    That's more rolling mass though. Harder/slower to turn, and more likely to break shit. I'd personally just prefer keeping a metric shit-ton of weight on the axle itself.
  20. Mar 11, 2014 at 5:18 PM
    #3840
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I think it's worth it for these.
    What does a rocker or a trep run compared to whatever else? I'm sure they're pretty fawking heavy too.
