Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Nov 4, 2014 at 9:28 AM
    #4261
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    :cool:
    No problem man, glad I could help! One question, how come you didn't just go with 250/300?
    Sounds about right on the rate there too. The springs just have to hold the truck up, everything else should be done with coilover valving. Glad to hear you're happy with the four link. Most of us really don't consider that an option, with our low slung trucks there's just no way getting around that pesky engine.
  2. Nov 4, 2014 at 11:36 AM
    #4262
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    trust me it's very tight when both shocks are bottomed out. and in all honesty my 3 three link only had one flaw and that's my ridiculously short track bar. but it's gone now and I have days of room for my bump stops which is what I really wanted. 4 link cost me $450 to do and I would have had to buy the link ends and truss anyways so all I wasted parts and money wise is the one of the joints and some DOM. ill get to reuse the other joint for my rear anti axle wrap bar.
  3. Nov 4, 2014 at 3:41 PM
    #4263
    rctoy
    konstantenos
    Pocatello Idaho
    I know I didn't do it the way everyone else does but with as tall as I am I thought this would play out nice and it did.
  4. Nov 4, 2014 at 8:50 PM
    #4264
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Well... probably because I'm dumb haha.
    Umm I figured that if I needed 137 that was the only way to get it. I'd have been fine with a 136 though, duh... :bananadead:
    I think I just got a little confused trying to figure this all out and got stuck on that 137 number. Didn't even dawn on me...
  5. Nov 5, 2014 at 8:44 AM
    #4265
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Yeah you really just need to get close to your "target" rate, and add or subtract a tiny amount of preload to fine tune. I like to choose the setup so I have at least an inch or two preload to force the suspension down rather than just have the axle weight working against the rebound valving.
    Either way I think you'll be fine.
  6. Nov 6, 2014 at 5:04 AM
    #4266
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Sexy, I think I should paint my truck this color :D
  7. Nov 6, 2014 at 5:46 AM
    #4267
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Add it to the list for this weekend and bring some paint :D
  8. Nov 6, 2014 at 6:56 AM
    #4268
    rctoy
    konstantenos
    Pocatello Idaho
    that was my plan to but I ended up not having enough up travel to do that :eek:.
    Tender coils look good though. a massive 25lb of down pressure at full droop unless my coils sag like 3 inch's which I don't see happening.
  9. Nov 6, 2014 at 11:18 AM
    #4269
    Supra TT
    Eric
    Indiana
    I'll add it to the list... But not for this weekend.. This weekend is fab weekend not watch paint dry weekend :p
    Tender coils are a crutch to the coil over. If you get the 2 springs properly tuned you don't need a tender spring. :cool:
  10. Nov 6, 2014 at 11:57 AM
    #4270
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I wanna come too! :goingcrazy:
  11. Nov 6, 2014 at 12:08 PM
    #4271
    rctoy
    konstantenos
    Pocatello Idaho
    this is true. but the lightest spring I could find in an 18" was 200# and I don't want a 100# 16" spring so I crutched it.
  12. Nov 6, 2014 at 1:48 PM
    #4272
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Sex! That was about the color mine was before I sprayed it with flat clear. Darkened up quite a bit. I used the rustoleum camo tan for like $3.50 a can from walmart
  13. Nov 7, 2014 at 4:06 AM
    #4273
    Supra TT
    Eric
    Indiana
    My truck will be like 4 different colors once I attached bed sides (within the next 5 years I hope :eek::eek::rolleyes:) So I need to paint it eventually... lol
  14. Nov 7, 2014 at 6:50 AM
    #4274
    rctoy
    konstantenos
    Pocatello Idaho
    FIFY
  15. Nov 10, 2014 at 11:24 AM
    #4275
    Supra TT
    Eric
    Indiana
    New ride height after Mark and I fixed my shit ass shackle angles and leaf spring brackets. Angle is a little flat due to me assuming the springs were 47" and were really 47.5", so I fucked that up a smidge [​IMG]
    26" in the front and 25" in the rear... Beats my 28" from before :puke:
  16. Nov 10, 2014 at 11:53 AM
    #4276
    rctoy
    konstantenos
    Pocatello Idaho
    looks good.
  17. Nov 10, 2014 at 3:25 PM
    #4277
    Supra TT
    Eric
    Indiana
    Thanks :cool: I don't mind a taller frame height I just want the truck to be level. If its at 26" or 27" whatever. I'd like to raise the back an inch to match the front instead of dropping the front anymore. only 5" uptravel right now due to the limiting factor of my ram hitting the oil pan :D But 5" is pretty good for leafs at this height (imo)
    Next time the truck goes in the shop it gets a super charger :burnrubber:
  18. Nov 10, 2014 at 4:07 PM
    #4278
    rctoy
    konstantenos
    Pocatello Idaho
    Kick ass. (I already have my supercharger)
    I actually like that raked look but that's just me. Im at 5.5" currently but I may drop to like 3.5 depending on how my air bumps turn out. droop for days is what this is turning in to.
  19. Nov 10, 2014 at 4:46 PM
    #4279
    Supra TT
    Eric
    Indiana
    SC FTMFW :D
    Droop for days is right. I need to flex this truck out now to see how much works. Probably too much flex for the shocks now haha
  20. Nov 11, 2014 at 9:40 AM
    #4280
    rctoy
    konstantenos
    Pocatello Idaho
    I need to get my front diff geared and locked then trim my rear bumper and see how much flex I have as well. I know I pulled some good numbers in 2wd but I need to do an actual test.
