Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Dec 15, 2014 at 7:59 AM
    #4381
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    That kit is for the older passenger side drop cases. Not sure if it will work on a TACOMA case. I have never seen a 1st Gen case with triple sticks I looked into it when i did my swap and couldn't find any info on it.
    Also if you get a J shifter let me know I'll take your current case off your hands.
  2. Dec 15, 2014 at 9:09 AM
    #4382
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    have you looked into what the differences are between the push button and the Jshift case??
    I looked as my space taco Jshift case and my old gear drive j shift and I don't see a difference in the mounting of the shifter.
  3. Dec 15, 2014 at 9:32 AM
    #4383
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Will do, but I will most likely be keeping it now. My bed rack must be near completion yeah? :p
  4. Dec 15, 2014 at 9:52 AM
    #4384
    JLee
    Jerry
    Grass valley CA
    I haven't looked too much into the J shifter case i know mine just go's forward for 4low and for 4hi i just hit the button on the shid of the shifter that' if my hubs are locked.
  5. Dec 15, 2014 at 10:19 AM
    #4385
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    While we're on the topic of tcases... when I USED to have a truck, I could shift in to 4wd on the fly. A couple months before I hacked it up, I started having issues where I couldn't move the shifter into 4wd unless the truck came to a stop, and then it was fine. Any ideas as to the culprit? ADD electric/vac issue? Worn/damaged synchronizer ring?
  6. Dec 15, 2014 at 10:26 AM
    #4386
    BradyT88
    BradyT88 Well-Known Member
    I'm guessing the latter. I don't see why the ADD would stop the shifter from moving. It's just some wiring between the ADD and the Tcase.
  7. Dec 15, 2014 at 10:28 AM
    #4387
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    It's a good thing I have two spares, then. :anonymous:
  8. Dec 15, 2014 at 10:35 AM
    #4388
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I had some random problems with my t-case before the swap... Now it's simple... Pull the handle down and you're instantly in 4wd (if hubs are locked of course). Love it! Not a single problem (except that time my ds fell out and broke the output shaft :anonymous:)
  9. Dec 15, 2014 at 11:22 AM
    #4389
    rctoy
    konstantenos
    Pocatello Idaho
    all this Tcase talk just makes me want an Atlas even more.
  10. Dec 17, 2014 at 6:31 AM
    #4390
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    I was looking at an atlas for down the road. Don't really want dump money into a dual case setup just to break tcase inputs if I get stupid with it.
  11. Dec 17, 2014 at 6:50 AM
    #4391
    rctoy
    konstantenos
    Pocatello Idaho
    yeah I looked at the same thing to get the full Gear drive Tcase set up with cromo everything that I can im looking at just over 3K might as well spend the extra 2K and get the 4 speed atlas that can do front wheel drive only low range and have one ton drive lines. The idea there is to make my rear axles and my hubs the weak points but we'll see.
  12. Dec 17, 2014 at 7:03 AM
    #4392
    Redneck92
    Concord, NC
    I've seen one of my buddy's use grade 5 driveshaft bolts at the pinion flange to act as a fuse. Works fairly well and can keep you from getting to stupid with it.
  13. Dec 17, 2014 at 8:14 AM
    #4393
    rctoy
    konstantenos
    Pocatello Idaho
    yeah I had that thought but the odds of breaking a rear shaft aren't too high. not sure about the front right now
  14. Dec 17, 2014 at 5:45 PM
    #4394
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Don't shoot me but how feesable does this sound, sawping an entire fj80 front into the tacoma? Radius arms, coils, axle, whole nine yards? See any issues running this set up?
    Edit: may run coil overs with the radius arms on the 80 axle
  15. Dec 17, 2014 at 7:36 PM
    #4395
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    IMHO look at pirate and Ih8mud and read about the 80 owners that converted to links and COs
  16. Dec 18, 2014 at 8:28 AM
    #4396
    Redneck92
    Concord, NC
    There's a 4Runner build on pirate I think Dylan that he uses the FJ80 radius arm.
  17. Dec 18, 2014 at 9:15 AM
    #4397
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Lol :p text me the link
  18. Dec 18, 2014 at 11:29 PM
    #4398
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    It's not actually a bad little setup for a low reliable sas rig. I've seen a couple that had everything work really well within the boundaries of radius arms. It'll never be a ramp champ but it will drive nice and let you ditch the stock weak cv's. You have to go to a gear drive case setup though to get passenger drop, not a bad idea anyway considering the cost and gearing options that become available.
  19. Dec 18, 2014 at 11:32 PM
    #4399
    Redneck92
    Concord, NC
    Google the shit. To lazy to look for it.
  20. Dec 19, 2014 at 5:12 AM
    #4400
    Supra TT
    Eric
    Indiana
    Just 3 link it... You can make it just as low as a stupid radius arm... And it'll flex way better and handle better if you set it up right.
