Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Jan 13, 2015 at 10:41 AM
    #4581
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Ok, I can do that. I'll set up the bump stops after I get the 63's put on, then go about figuring out the shock length I'll need.
    How about the angle of the shock towards the centerline of the truck? Leaning them in slightly should help keep the tires out of the shock. Instead of putting the top mount directly over the lower I can bring it towards the side of the bed, just outside the frame rail. That would be somewhere around a 2-3" offset, top to bottom. I could bring it in further, but I don't know if that's needed.
  2. Jan 13, 2015 at 10:47 AM
    #4582
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah If you can get a little angle in it would help keeping the tires off the shocks. Also give you a little wiggle room when flexing. If you tuck them tight to the frame like so ll when you flex you might contact the frame with the shock body.
  3. Jan 13, 2015 at 11:31 AM
    #4583
    SMKYTXN
    Nathan
    Houston
    DCFB
    Sounds good to me.
    Looks like I'll bee ready to start phase one this weekend.
  4. Jan 13, 2015 at 11:32 AM
    #4584
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    yeah you are right I always angle them to have max travel with out bottoming them out but where as he has a lot more weight to deal with 100% dampening is important.
    As close to the inside at the top as possible and as close to the backing plate as possible is what you're saying??
  5. Jan 13, 2015 at 11:35 AM
    #4585
    SMKYTXN
    Nathan
    Houston
    DCFB
    That's what I'm getting from it as well. Should I angle the upper and lower brackets to be in line with shock? It won't be much of an angle, but should keep things from binding.
  6. Jan 13, 2015 at 11:52 AM
    #4586
    rctoy
    konstantenos
    Pocatello Idaho
    Not really sure what you're asking there. This is how I did mine, and I know i'm a lot lighter and a first gen but I have no issues with these cheap Pro Comp shocks at the angle they are at.
  7. Jan 13, 2015 at 11:57 AM
    #4587
    SMKYTXN
    Nathan
    Houston
    DCFB
    I was talking about the traditional double shear shock mount, like these.
    If I'm going to mount to the back of the axle housing and lean the shock inboard I will probably be better off using a bucket type mount like this.
  8. Jan 13, 2015 at 12:15 PM
    #4588
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Go for the bucket off the back of the axle. Buddy just swapped 63's into his tacoma and uses all of his 14 inch bilstiens. That with the shocks angled 25 degrees under the bed of the truck
  9. Jan 13, 2015 at 1:41 PM
    #4589
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Straight up and down, tilted slightly back and behind the axle. Make sure you have one mount parallel to the axle, and one perpendicular to avoid binding.
  10. Jan 13, 2015 at 4:55 PM
    #4590
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    So... I might of found some 40" treps on racelines for sale that I put dibs on :anonymous:
  11. Jan 13, 2015 at 4:59 PM
    #4591
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    I approve! Hopefully they will actually make it on the truck unlike the sc... lol
  12. Jan 13, 2015 at 5:03 PM
    #4592
    Supra TT
    Eric
    Indiana
  13. Jan 13, 2015 at 5:16 PM
    #4593
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    :devil:
  14. Jan 13, 2015 at 7:42 PM
    #4594
    rctoy
    konstantenos
    Pocatello Idaho
    so my girl friend said what if you roll your taco. I paused for a minute then took a swig of JD and said then I guess we custom build a tube frame and keep it low and fast the second round.
  15. Jan 14, 2015 at 4:05 AM
    #4595
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Lol love it!
    So some one tell me if I'm wrong because this sounds pretty simple. And really surprised hardly anyone's went this route with the fj80 radius arms axle and all.
    So far I'm looking at:
    Fj80 axle
    Track bar and mounts
    Radius arm and mounts
    Fj80 drag link
    Fj80 steering box
    Psc pump
    Pre taco tcase
    Adapter
    23 spline conversion
    Coil over buckets
    Coil overs
    Of course I'm leaving out all the rebuild kit and what not but this is the main stuff that will be on the truck. Just seems to simple to me... No math configuring suspension set up or anything.
  16. Jan 14, 2015 at 7:04 AM
    #4596
    rctoy
    konstantenos
    Pocatello Idaho
    shock mounts for the frame?
  17. Jan 14, 2015 at 8:00 AM
    #4597
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Doing coil over buckets and running either a fox or a foa 12" coil over
  18. Jan 14, 2015 at 8:04 AM
    #4598
    rctoy
    konstantenos
    Pocatello Idaho
    my bad. I saw coil over bucket and my mind deleted the over part of that.
  19. Jan 14, 2015 at 8:43 AM
    #4599
    slander
    Hickory, NC
    I looked into it, and was swayed away by friends who have 80s. The radius arm setup on the 80s binds up pretty good, as do most radius arm systems its an inherent limitation of the design, and in order to fix that you may as well just build a wristed radius arm, 3link front, or even leafs. I would personally save some $$$ and just put regular coils and shocks on it, you will never even come close to maxing out the coils with the stock radius arm system and will be wasting some $$$ IMO.
    I would do some reading over in the land cruiser section on pirate, and read the ih8mud 80 forums before making a final decision and seeing if you want to accept and be happy with those limitations.
    Take it with a grain of salt i guess, I'm working on a shackle forward leaf spring setup in my head using slider boxes or shackles for my SAS...
  20. Jan 14, 2015 at 9:17 AM
    #4600
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Radius arms do bind up but this is more a dd than a wheeler right now. I can live with a little binding with more flex than ifs.
    Eventual plan is to three link it but that will happen when time and money allows. Right now I'm just trying to make this a nice reliable set up that Is nice on the road, decent off road, and fairly easy to instal.
    We thought about going coils but by the time you make coil buckets, shock hoop, get a decent shock and then figure out what coil you need you come up roughly 2-300 bucks short of just getting a coil over. Plus figuring out what coil you would need would be a total nightmare.
