Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Feb 13, 2015 at 5:58 PM
    #4921
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Why not weld to the cast? That's what I did.
  2. Feb 13, 2015 at 6:26 PM
    #4922
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I'm not sure I can trust someones welding to the cast :cough Jon cough:
  3. Feb 13, 2015 at 6:40 PM
    #4923
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    not to mention that you need to use ni-rod and preheat the cast to make a good strong weld
  4. Feb 13, 2015 at 6:49 PM
    #4924
    Supra TT
    Eric
    Indiana
    Isn't ni-rod only for cast iron?
  5. Feb 13, 2015 at 7:00 PM
    #4925
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Yup fuck strength as long as it looks nice...
  6. Feb 13, 2015 at 7:06 PM
    #4926
    Supra TT
    Eric
    Indiana
    No one wants ugly welds... you just get flamed for it. :luvya: The strength difference is marginal. There's much to debate on it...
  7. Feb 13, 2015 at 7:09 PM
    #4927
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Guess you have never welded with co2 and Flux then. Lays down just like solid with 75/25 mig mix but burns in way hotter with the same power. Only thing you have to do is chip off a little layer of the Flux stuff after your done.
  8. Feb 13, 2015 at 7:14 PM
    #4928
    Supra TT
    Eric
    Indiana
    Nope, if you have flux you might as well use it and learn with it. Get c02 and do it that way. If you don't like it just switch to mig wire and you can still use the c02 to weld with it. Works great too.
  9. Feb 13, 2015 at 7:23 PM
    #4929
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    I use solid and mig mix but a friend of mine work at an big fab shop and they all use Flux and co2 for the extra strength. They seem to think it's worth it. They also use t100 plate for everything though lol.
  10. Feb 13, 2015 at 7:23 PM
    #4930
    Supra TT
    Eric
    Indiana
    What did you use to weld it? Any special rod? preheat and post heat? Temps? and was your diff nodular iron or cast steel? I can't figure out what mine is so I guess I'll have to do a spark test. I am pretty sure its nodular iron according to some posts online.
  11. Feb 13, 2015 at 7:36 PM
    #4931
    slander
    Hickory, NC
    Avoiding getting flamed by webwheelers is the goal. If you have 110 its not even worth your time fucking around with gas, just get flux core and go to town at least it will stay together. On a 220 machine, I don't know why you would be messing around with flux core.
  12. Feb 13, 2015 at 7:51 PM
    #4932
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Depends on how big your machine is and how thick your welding. I would have loved some Flux and co2 a few weeks ago when welding out some 3/8ths at work with our miller 180.
  13. Feb 13, 2015 at 7:59 PM
    #4933
    slander
    Hickory, NC
    That's when you break out the stick welder.
  14. Feb 13, 2015 at 8:16 PM
    #4934
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    What's my psc single ended ram worth? I think it's an 8" stroke. I may swap to a double ended since all I would have to go is swap the rams out and weld up the steering links.
  15. Feb 14, 2015 at 1:18 AM
    #4935
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I don't see any problem with unshielded flux welding, just have to brush off the flux before you paint and it can still be pretty. I actually just took my hobart 140 to flux from mig because I got tired of the wind blowing away the shielding gas anytime I was welding near the open garage door
  16. Feb 14, 2015 at 9:22 AM
    #4936
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I have friends that weld for a living as long as you don't over heat one area of the cast then you can use Ni rod to weld steel to cast and you can do it without heading up the housing to 500+ degrees just by jumping around and doing short welds also giving it time to cool, it's how I did mine the first time I did the 3 link worked fine.
  17. Feb 14, 2015 at 11:27 AM
    #4937
    Supra TT
    Eric
    Indiana
    What if I only have access to mig welder? Then what do I do?
  18. Feb 14, 2015 at 11:49 AM
    #4938
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    X2!
  19. Feb 14, 2015 at 1:46 PM
    #4939
    Supra TT
    Eric
    Indiana
    I seriously think I am just going to build a minitruss. Just do not want to trust that old shitty center section being welded. maybe if I had the proper rod and a stick welder and someone that knew how to weld to nodular iron.
    Similar to this one as I posted earlier.
  20. Feb 14, 2015 at 3:03 PM
    #4940
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    There is some high Ni content wire but the shit ain't cheap. I remember it being talked about on pirate but not sure of the brand.
