Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Mar 20, 2015 at 10:26 AM
    #5301
    BradyT88
    BradyT88 Well-Known Member
    Yeah, I have a picture some where of the TRD 8", an 8.4" and the older Toyota 8" ring gears stacked and they are all the same size. We measured them with calipers to confirm it.
  2. Mar 20, 2015 at 11:14 AM
    #5302
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Yea but the pre tacoma v6 3rds don't have the habitual problems of popping gears like the 2nd gen TRD rear's do and they are missing the girdle.
    I proposed that perhaps there was a MFR defect on the 2nd gen tacos, or the fact that the 4.0 coupled with a heavy ass truck causes the problems seen with those 3rds, and i was labelled a heretic by Tacoma World, i think i lacked credibility since i don't have a satoshi, 40" LED light bar and a roof rack.
  3. Mar 20, 2015 at 11:19 AM
    #5303
    BradyT88
    ^^^This is my thought! I think Toyota fucked up making the 2nd gen TRD ring and pinions... I killed 2 of them way too easily...
    My Nitro 4.88's from ECGS lasted me longer than my first 2 Toyota 3.73's combined!
    I think I'll chalk up my 4.88's to hard abuse... I wrecked everything on my 3.73's. My 4.88's only lost 3 teeth on the ring gear and the pinion was fine. That's a good indicator that I shock loaded it at some point. Probably out at the dunes...
  4. Mar 20, 2015 at 11:23 AM
    #5304
    slander
    Hickory, NC
    That's the other part of it, people beat the shit out of their trucks and its the parts fault, not saying that's you lol. Yes crawling stuff at idle, winching, or bypassing things you should not be on makes for boring pics and stories, but so does trail wrenching which SUCKS.
  5. Mar 20, 2015 at 1:35 PM
    #5305
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Ok just to clarify on some points, I have a 1 piece rear drive shaft. And unfortunately I'm pretty sure the adapter is TG and I know it is all 21 spline. I have a w56, not a tacoma tranny.
    What issue would their be running a 14 bolt with the fj60 other than width and gearing?
    Also I just found a d60/d70 combo setup for 3 link and 4 link. Pros and cons for the 70 vs 14 bolt?
  6. Mar 20, 2015 at 2:12 PM
    #5306
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Yeah it does!
    Rear driveshaft is fine, shorten or lengthen as you need to. Are the cases stuffed with stock gears or 4.7s? Match everything if you want the same ratio and go 23 spline.
    No issues with a 14 bolt. Arguably the strongest cheapest rear axle you can buy. The front axle doesn't care what rear axle you have :p D70 and 14 bolt are similar in size and strength but you'll get lower (numerically higher) gearing options with the 70.
  7. Mar 20, 2015 at 2:20 PM
    #5307
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    14 bolt is easier to setup gears. You can pick up axle shafts for 15 to 30 a piece at most junk yards. Super easy to swap to disks. Can shave to gain another 1.75'' of clearance.
  8. Mar 20, 2015 at 2:29 PM
    #5308
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    My cases are 2.28 in the front and 4.70 in the rear.
    So the only difference would be a slight difference in strength and different gearing options? I wouldn't go any deeper than 5.38. I don't need 7.17 haha, I'd still like to be able to drive on the highway.
    Here's the axles I found:
    http://www.nc4x4.com/forum/threads/full-1ton-buggy-part-out-cash-or-trades.161582/
    Looks like they are stock besides the gears and covers.
  9. Mar 20, 2015 at 2:38 PM
    #5309
    slander
    Hickory, NC
    14bolts are the shit. If you find a c&c one it will be the same width as your front. I think you can swap the c&c hubs on a srw one to narrow it as well. I was building one to swap into a jeep that I ended up selling. I was going to swap a 60 into it, then saw the 14bolt parts compared to the 60s and realised where the beef really was. My friend has one in his heep that he shaved down and it has more clearence under the diff than a d44 and he didn't even shave the ring gear. The 14 bolt also has the pinion support bearing to stop gear deflection,60s don't have that.
  10. Mar 20, 2015 at 3:24 PM
    #5310
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    This is true. 14 bolts have a dropout pinion so they are way stronger than 60 or 70s in the rear. The D70 does have a huge pinion though.
  11. Mar 20, 2015 at 3:42 PM
    #5311
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    So basically I'm getting that I should do it right the first time and go 14 bolt..
  12. Mar 20, 2015 at 4:27 PM
    #5312
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    With either axle you will be fine in the strength department. But for clearance, cost, and ease of setup the 14 bolt wins.
  13. Mar 20, 2015 at 7:54 PM
    #5313
    slander
    Hickory, NC
    Yes and its by far the cheapest
  14. Mar 21, 2015 at 7:08 AM
    #5314
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    this ^^ and I rebuilt a dana 70 last month put the ring gear next to the 14 bolt gear I had at the shop and they are the same size.
  15. Mar 23, 2015 at 9:44 AM
    #5315
    rctoy
    konstantenos
    Pocatello Idaho
    so since I bought the atlas I have no need for my J shift case and I have two of them. You guys know of anyone looking for one?
  16. Mar 23, 2015 at 9:55 AM
    #5316
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Even with shipping costs, I'm sure they will go quickly in the buy/sell/trade section. Or send em to me so I can have 4 1/2 of them! :luvya:
  17. Mar 23, 2015 at 10:22 AM
    #5317
    slander
    Hickory, NC
    You should be able to sell those easy out there. I have had one for sale for 4yrs now, but not too many tacomas here in the midwest, and even fewer that are wheeled, and even FEWER that have the need for a replacement case lol! All the people i see that need them are on the west coast.
  18. Mar 23, 2015 at 10:31 AM
    #5318
    rctoy
    konstantenos
    Pocatello Idaho
    I was more asking if people wanted to convert to the J shift from the push button. Kinda just giving you guys first grab at them.
  19. Mar 24, 2015 at 9:38 AM
    #5319
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    save one for me incase i don't get my dads rig. He's got the j-shift
  20. Mar 24, 2015 at 10:12 AM
    #5320
    bullcrew
    bullcrew Well-Known Member
    travis
    oceanside
    03 quad cab sas
    I want to when I do dual cases....
