Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Apr 25, 2015 at 2:02 PM
    #5581
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    And in my case, the injectors.
  2. Apr 25, 2015 at 3:52 PM
    #5582
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Perfect time to upgrade to 100s :D lol
  3. Apr 25, 2015 at 4:05 PM
    #5583
    Balockay
    Blake
    Cleburne, TX
    Nah, replaced with remanned OEM. I was pretty hell bent on keeping everything on my truck stock.
  4. Apr 26, 2015 at 10:07 AM
    #5584
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    as far as all this tow rig talk goes they all suck just good parts here and there. In all honesty if i could piece one together i would take super duty axles and frame, a 2003 5.9 common rail, a asin 6 speed, all put under a tundra body,
  5. Apr 28, 2015 at 4:06 AM
    #5585
    Supra TT
    Eric
    Indiana
    Belt is on after the pump relocation!
    New bumper too!
    Thanks Jon!
  6. Apr 28, 2015 at 7:00 AM
    #5586
    rctoy
    konstantenos
    Pocatello Idaho
    just curious why you did a pump relocation??
  7. Apr 28, 2015 at 7:07 AM
    #5587
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    SUPER CHARGER!!!!!
  8. Apr 28, 2015 at 7:26 AM
    #5588
    rctoy
    konstantenos
    Pocatello Idaho
    that cant be it. I have a SUPER CHARGER!!! and my pump mounded in the factory location just fine.
  9. Apr 29, 2015 at 10:47 AM
    #5589
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
    It looks like it's a 4cyl supercharger so he has different mounts.
  10. Apr 29, 2015 at 11:21 AM
    #5590
    rctoy
    konstantenos
    Pocatello Idaho
    Well that changes everything.
  11. Apr 29, 2015 at 2:06 PM
    #5591
    Supra TT
    Eric
    Indiana
    Supercharger was in the way of keeping the pump rotated how I used to have it. With it in the new position the resi needed to be mounted through the hood about 6"... Look in my build there's a ton more info.
  12. Apr 29, 2015 at 4:10 PM
    #5592
    Supra TT
    Eric
    Indiana
    Holy shit lol
    This is a dana 80 cover over the pinion... JUST THE FUCKING PINION
  13. Apr 30, 2015 at 11:58 AM
    #5593
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Didn't want the resi sticking up through the hood. Raise the resi or lower the pump inlet, he chose the latter.
  14. Apr 30, 2015 at 12:04 PM
    #5594
    rctoy
    konstantenos
    Pocatello Idaho
    yeah I probably should have done the same but I have a V6 and I am willing to settle for low assist on sharp inclines
  15. May 1, 2015 at 7:04 AM
    #5595
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Mount your resi between the core support and air box. That's what I did, my feed line is about 4" long.
  16. May 1, 2015 at 7:24 AM
    #5596
    rctoy
    konstantenos
    Pocatello Idaho
    that's a good place but i have my WWF bottle there so I mounted mine above the valve cover and the feed line is about 6" long.
  17. May 1, 2015 at 10:01 AM
    #5597
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Oh yeah forgot the stock washer bottle was there haha. I got an aftermarket washer bottle from Summit and put it in the back passenger corner by the cruise control module. I don't think you'll have problems feeding to the pump. On steep inclines the front end will be light due to more weight over the rear tires.
  18. May 1, 2015 at 3:16 PM
    #5598
    Supra TT
    Eric
    Indiana
  19. May 1, 2015 at 4:05 PM
    #5599
    rctoy
    konstantenos
    Pocatello Idaho
    ah yeah. ill try to post a pic of what I did later tonight.
  20. May 3, 2015 at 2:42 PM
    #5600
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
