Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Aug 29, 2012 at 6:57 PM
    #581
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    Yota axles man :cool:
  2. Aug 29, 2012 at 7:02 PM
    #582
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Fab work would kill me. I find that the dana 44 will be the best way. I would love to have all toyota or even a custom axle but then you run into more $$ than I think I need to spend.
  3. Aug 29, 2012 at 7:03 PM
    #583
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    That kind of setup are you planning on running suspension, tire, gear, case, axle, etc...?
  4. Aug 29, 2012 at 7:08 PM
    #584
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    It's gonna be on springs with 36-37's. 5.38's front 5.29's rear with powertrax lockers front and rear. Stock axles maybe or some cromo yukons. I have been looking at the sky off road sas kit a lot. Still undecided.
  5. Aug 29, 2012 at 7:24 PM
    #585
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    OF COURSE HOW STUPID I FORGOT :mad:... It is probably the cleanest looking SAS ever done on a 2nd gen. I love it!
    Well it's a jeep thing for one.............
    2nd, it's better for hills up and down since it pushes the front axle forward more than doing so. (Longer wheel base = better) And it keeps the driveline from slamming back into itself..
    LOTS of cons vs Pros though.. Fuck front shackles its retarded.
  6. Aug 29, 2012 at 9:02 PM
    #586
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Huh??
    Front shackle downsides-
    1. Decreased approach angle
    2. Axle swings forward when the springs are compressed
    a. Your tires will be into your head lights rather than the pinch weld
    3. Shitty ride quality on the road compared to shackle out back. My old boss claims that converting his Jeep from front shackle to rear shackle was the best mod he did for ride quality. Your suspension is fighting bumps rather than soaking them up, like a rear shackle does.
    This is a very simple concept if you think about it. You have a rear leaf spring setup on 99% of trucks on the road today, do they ever run a shackle on the front of the spring? No. Because it's fucking stupid. Still don't like Jeeps and how cheaply they are made nowadays. It's a Chrysler produ....I mean a Fiat product LOL
  7. Aug 31, 2012 at 5:30 AM
    #587
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    You are 100% correct. Toyota mini axle's are great but to make them work with these Tacoma's takes too much money for an axle that will be only as strong as a stock Dana 44 unless you use the 80 series axle's and then your talking big bucks.
    Thats just for front axle's though. The rear Tacoma axle's are stronger than the Dana44.
  8. Aug 31, 2012 at 5:55 AM
    #588
    Ihavataco98
    Ihavataco98 Well-Known Member
  9. Aug 31, 2012 at 7:58 AM
    #589
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    A question for you guys.
    In regards to this truck, I see that the guy went with a regular shock and coil setup instead of coilovers. I am sure with longer shocks he could get more travel out of it too and keep the truck lower. Which is what I like about this truck.
    What are the pros and cons between using coilovers and regular coils and shocks?
  10. Aug 31, 2012 at 12:01 PM
    #590
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
  11. Aug 31, 2012 at 12:02 PM
    #591
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    problem with that is, you have to be very careful you dont over extend and pull your spring out, not that is huge issue, but it could get annoying
  12. Aug 31, 2012 at 12:03 PM
    #592
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Quad Colormatch Rear Shocks > Front Driveshaft :cool:
    Simple Bro Math.
  13. Aug 31, 2012 at 5:03 PM
    #593
    awsumdc
    O.C. Cali
    SASED '05 Taco
    With a coilover system you have adjustability that you dont have with the spring and shock setup and it's a much more compact setup too. They are more expensive to purchase but in my mind are worth every penny. I can raise or lower my truck by just turning the top spring keepers. You can't do that with a regular coil spring and shock setup. I can get that dreaded Taco lean out of my truck by just a couple of turns and I can tailor my truck for what ever trail I'm going to run.
    Can't do that with regular coil springs or leaf springs.
    The main reason someone would go with this setup as opposed to a coilover set is money. Other than that there is no real benefit of a coil and spring over a coilover.
    On my next build I'll use coilovers as well but the truck will only be higher than stock because of the tires I'll be using. I'm going to use coilovers to KEEP it low and compact but it'll have massive flex compaired to it's ride height. the goals going to be 2" over stock but sitting on 35" tires.
  14. Aug 31, 2012 at 6:53 PM
    #594
    06tacomakev
    Kev
    Victoria BC
    That sounds like a great idea to keep it low and flexy.
    Thx for the answer
  15. Sep 1, 2012 at 12:04 AM
    #595
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    So what front diff would you opt for if you had diamond fab one up?
    Dana, TrueHi9?
    or
    would you just go straight to 1ton
  16. Sep 1, 2012 at 12:18 AM
    #596
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    this is my goal. 35's MAYBE, clean, reliable, reasonable expo rig.
  17. Sep 1, 2012 at 7:40 AM
    #597
    awsumdc
    O.C. Cali
    SASED '05 Taco
    I wouldn't go with Diamond. I'm going with Currie Rock Jock 60's on my next build as well because they are 1 ton with better clearance than a stock Tacoma axle and the cost would be about the same if not a bit cheaper than a diamond and hi/9 plus I can get it when I want it and not have to wait for months.
  18. Sep 1, 2012 at 7:41 AM
    #598
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Yep. I was going to build my 4th gen but I really like the 3rd gen 4runners so I'll probably go find one of those and build it with Currie Rock Jock 60's and 35's.
  19. Sep 1, 2012 at 9:52 AM
    #599
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    Yeah getting the mini to fit was a pain in that ass. In hind-sight I wish that I had held out for a FJ80... but My plan was to keep it low and on 33's. I'm keeping my fingers crossed that with the 33's and not being too crazy with it that I can make it last a while.
    I'm probably wrong/misinformed, but I thought a toyota = 44 equivalent. The big reasons that I wanted to stay away from the 44's is: 1) I just wanted to keep everything Toyota on my build. 2) Everyone I know with 44's hate them and haven't had good luck (not saying that they are, just others results with them). 3) I can get Toyota parts/shafts/etc... very easily in my area.
  20. Sep 1, 2012 at 9:17 PM
    #600
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Guess ill have to hang on to my 14Bolt thats van width for the rear
