Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Feb 6, 2016 at 9:00 AM
    #6501
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    I've been documenting on my camera but managed to snag a few shots on my phone after a day it work on the truck. Waiting for 4wu link bracket kit, that is the biggest thing holding us up now.
    joemauma, Ugly Betty, 45acp and 5 others like this.
  2. Feb 6, 2016 at 7:18 PM
    #6502
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Who's triple stick setup is that? I asked davezoffroad, but I couldn't get a straight answer if it would work with Tacomas.
  3. Feb 6, 2016 at 9:01 PM
    #6503
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
  4. Feb 10, 2016 at 5:21 PM
    #6504
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Is a flap disk the best to clean the frame before welding reinforcement plates?
  5. Feb 10, 2016 at 5:23 PM
    #6505
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    From my experience, no. They get "gummed up" with the paint and grime on the frame. I always use a regular grinding disk to get everything off, then maybe hit it with a flap disk to smooth it out some.
  6. Feb 10, 2016 at 5:24 PM
    #6506
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    If your just cleaning of paint yes, that rubber coating bs Toyota put on a wire wheel is best.
    Wulf likes this.
  7. Feb 10, 2016 at 5:26 PM
    #6507
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Wire wheel seems better, I'll give both a try.
    What about repainting it, any recommendations?
  8. Feb 10, 2016 at 5:26 PM
    #6508
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    What's ideal is these abrasive wheels that remove rust and paint, without removing metal.
    A simple primer and paint should suffice, or spray-on bedliner like duplicolor.
    SnowroxKT[QUOTED] likes this.
  9. Feb 10, 2016 at 5:28 PM
    #6509
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Got a good link Jon?
  10. Feb 10, 2016 at 5:30 PM
    #6510
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  11. Feb 10, 2016 at 5:32 PM
    #6511
    Redneck92
    Concord, NC
    As far as paint I usually hit the bare stuff with self etching primer then go back and paint with rustoleum.
  12. Feb 10, 2016 at 6:46 PM
    #6512
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    A sawzall cut right behind each motor mount removes the IFS brackets and paint off the frame quite nicely and quickly.
    I like the krylon high zinc primer, that stuffs awesome but i can only find it at advance auto.
    Ugly Betty likes this.
  13. Feb 11, 2016 at 6:42 AM
    #6513
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    same only i go over that with Duplicolor bed liner because rock tend to chip paint and make it rust anyways.
    SnowroxKT and Redneck92[QUOTED] like this.
  14. Feb 11, 2016 at 7:09 AM
    #6514
    Redneck92
    Concord, NC
    Only reason I don't like using bed liner is because it's a bitch to clean all the mud and dirt of it.
  15. Feb 11, 2016 at 7:38 AM
    #6515
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Depends on the bedliner. Herculiner would indeed be a PITA. The Duplicolor and Rustoleum spray can stuff has little or no texture at all.
  16. Feb 11, 2016 at 7:40 AM
    #6516
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    I'm a fan of the rustoleum bed line... or rustoleum satin black
  17. Feb 11, 2016 at 9:16 AM
    #6517
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Is that the spray on stuff or brush on?
  18. Feb 11, 2016 at 1:38 PM
    #6518
    rctoy
    konstantenos
    Pocatello Idaho
    spray on and the cheaper of the two options it's like 10 bucks a can. i used it down the side of the cab for anti rock chipping and it works fantastic.
  19. Feb 11, 2016 at 1:51 PM
    #6519
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Yeah I did that to my rockers as well when I bedlined my cab, but I rolled it on. Wasn't sure if the spray on stuff was good enough, sounds like it is.
  20. Feb 11, 2016 at 2:54 PM
    #6520
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    For those who used bedliner, do you have any issue with it fading? I used the HF spray and it was gray in a few months
