Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Mar 23, 2016 at 6:00 PM
    #6921
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    If the snap ring is on and it's seated in the carrier I'd run it. It doesn't take long at all to pull it back out assuming you know the fast way to do it.... Only thing I can think of that would restrict it moving would be a bent housing or boogered splines.
  2. Mar 23, 2016 at 6:03 PM
    #6922
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    @malburg114 This is the way you should be pulling your knuckles to get the shaft in and out.
  3. Mar 23, 2016 at 6:04 PM
    #6923
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I'll look at the splines again. The shorter side snapped right on. How do you tell if the housing is bent?
    EDIT: video explained. Thanks guys. Will look tomorrow
  4. Mar 23, 2016 at 6:08 PM
    #6924
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    It's hard to find a slight bend. You can try and use a straight edge against the long tube. If your knuckleballs aren't gusseted they are prone to bending too. Either of your tires leaning in?
  5. Mar 23, 2016 at 6:11 PM
    #6925
    malburg114
    Las Vegas, NV
    Haven't had the axle mounted yet with wheels and tires yet. Just finished putting it all together. No gusset balls. Just a truss and diff cover but welded those very slowly so it wouldn't warp (1"-1 1/2" of welds then waiTed for it to cool)
  6. Mar 24, 2016 at 4:59 AM
    #6926
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    John Birfields technical term for breaking the birf.
    malburg114[QUOTED] likes this.
  7. Mar 24, 2016 at 5:26 AM
    #6927
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    @malburg114 I would pull apart the side that is giving you issues. Go through and tear it down then rebuild it. I remember having the ifs hubs (what you had machined down) give some resistance when seating onto the spindle and that seal there. I'd check to see if that side is actually full seated.
    Everything torqued to spec when you assembled the axle or just put together loosely?
  8. Mar 24, 2016 at 5:42 AM
    #6928
    malburg114
    Las Vegas, NV
    Yeah I'll start at the knuckle and work my way back. Will have to wait till tomorrow. Caught my finger with the angle grinder yesterday and had to get a few stitches. Plus have to mail some returns and buy some oil.
    Another question for you guys. It says to pack the knuckle full of grease. How much do you actually put in? I put a few big globs while reassembling it and coated everything but when I tore it down the first tjme, it hardly had any.
  9. Mar 24, 2016 at 6:04 AM
    #6929
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Pack the birfield full and coat everything with grease. Make sure the spindle bushing gets a good coating too. There is a plug you can remove to squirt grease in on the knuckle too. I wouldn't over pack as it doesn't do anything but make a mess of shit on disassembly, important part is the joint and spindle bushing.
  10. Mar 24, 2016 at 2:10 PM
    #6930
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    This.
    Make sure the birf is full and the bushing is good. Other than that just make sure everything has a light layer. The extra grease does nothing but make a huge mess when you take it apart again
    Redneck92[QUOTED] likes this.
  11. Mar 24, 2016 at 3:10 PM
    #6931
    malburg114
    Las Vegas, NV
    Will do. Thanks guys.
  12. Mar 28, 2016 at 11:27 AM
    #6932
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    From my build, requesting opinions.
    Tech Question for anyone with experience, a big mouth, or helpful advice:
    I want my rear suspension to roughly match my front SAS with 3" Trail Gear springs... This means I need about 2.5" more of rear end lift. (even with removing a leaf from the front pack)
    Please advise/flame/whatever below! lol
    Option 1) Put in an extra leaf I took out of my current leaf pack (add maybe .75" lift), run an extended shackle for the extra ~2" of lift. (so 4" longer shackle about)
    Option 2) Chevy 63" Swap and extended length shackles with possible AAL in the chevy leaf pack for more lift. Also, would need to change shock mounts and ditch the spare that is like a 28" tire lol
  13. Mar 28, 2016 at 12:25 PM
    #6933
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    63's work really well for what they are. Should give you plenty of lift as that's all I am running in the rear of my heavy pig.
  14. Mar 28, 2016 at 12:44 PM
    #6934
    Redneck92
    Concord, NC
    I'd go Ford 57s or Chevy 63s and run an inch block/zero rate if you needed a touch more to level it out.
  15. Mar 28, 2016 at 1:43 PM
    #6935
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Another vote for 63's, but don't put in an add-a-leaf or super long shackle just yet. My 63's with a standard size 5" shackle lifted the shit out of my 1st gen. It ended up being the perfect height to match the front, but I did have a set of add-a-leads handy just in case.
  16. Mar 28, 2016 at 3:52 PM
    #6936
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Thanks guys. Sounds like I'll be looking for some chevy leaves then...
    Any recommendation on a swap kit?
    I've been looking at this one from Ruffstuff http://www.ruffstuffspecialties.com/catalog/R1799.html
    and it seems to be everything I need and then just get leaves from a 1998 or older chevy.
  17. Mar 28, 2016 at 4:13 PM
    #6937
    Redneck92
    Concord, NC
    Ruffstuff is the only kit I'd buy, Barnes is nice too but not as compete as the Ruffstuff kit.
  18. Mar 28, 2016 at 4:19 PM
    #6938
    allenfab
    Todd
    Lakeland, FL
    Definitely the ruffstuff kit. It's what I used and what a handful of my buddys used as well.
  19. Mar 28, 2016 at 7:54 PM
    #6939
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    I used the Skys kit. It was cheap at the time and worked well. Can't go wrong with the RS kit either.
  20. Mar 29, 2016 at 1:21 PM
    #6940
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    I'm doing option 2. with the same kit you have.
