Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. May 25, 2016 at 10:51 AM
    #7101
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    How are you guys drilling the holes in your frame for the box?
    @NwiTACO paint those rusty ass sliders! :luvya:
  2. May 25, 2016 at 10:53 AM
    #7102
    la0d0g
    running for the hills
    For crawling not hauling
    With a drill
    PSU Taco85 and Snowy like this.
  3. May 25, 2016 at 10:55 AM
    #7103
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    I love my mag drill for that shit. Nice and square and all.
  4. May 25, 2016 at 11:15 AM
    #7104
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I would have killed for a mag drill, thought about renting one but said f-IT and used my cordless deWalt lol
    No can do on painting the sliders...its called PATINA and makes shit worth more :headbang:
  5. May 25, 2016 at 11:15 AM
    #7105
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    as long as its not on a first gen frame
  6. May 25, 2016 at 11:20 AM
    #7106
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :drool:
    I'm almost done reading this entire thread. Now I just need to start saving for stuff. Probably figure out an fj case and crawl box first.
  7. May 25, 2016 at 2:05 PM
    #7107
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I've always used a plasma to cut the holes in the frame. I like doing that better than risking my hand/wrist/arm being rolled up by a stuck drill bit causing the drill to twist up faster than I can let go of the trigger.
  8. May 25, 2016 at 2:09 PM
    #7108
    la0d0g
    Clutch :D
  9. May 25, 2016 at 2:28 PM
    #7109
    slander
    Hickory, NC
    I would pay more for a mag drill than my entire sas LOL!!
  10. May 25, 2016 at 2:29 PM
    #7110
    slander
    Hickory, NC
    Patina, HA!! I remember a certain someone always giving me shit over my rusty ass sliders!!
  11. May 25, 2016 at 3:02 PM
    #7111
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Rent that shit from Lincoln Rent-All or whatever passes for a tool rental place in Bolingbrook lol
  12. May 25, 2016 at 7:45 PM
    #7112
    slander
    Hickory, NC
    Miguels tool rental.
  13. May 26, 2016 at 6:15 AM
    #7113
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    maybe i need to look further into shifting them a little back. I had them (what i thought) lined up on the turn of the frame but i'll try to slide it around better today.
  14. May 26, 2016 at 7:46 AM
    #7114
    slander
    Hickory, NC
    I would be more focused on getting the draglink in the proper spot so it doesn't hit your tie rod and what not. Its much easier to hack apart and reinforce your core support then to move the steering box after everything is welded on.
    So glad im going with a forward swing!!
    malburg114 likes this.
  15. May 26, 2016 at 3:35 PM
    #7115
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I may or may not be picking up a d60 tomorrow :spy:
    Acerwin likes this.
  16. May 26, 2016 at 3:54 PM
    #7116
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  17. May 26, 2016 at 7:23 PM
    #7117
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    Building the axle... When we put the spindle on without bolting and torquing down, the pinion spins freely and everything is good but the axle shaft can't move back and forth much at all. When we torque it down the pinion gets in a bind and is very hard to move and the axle shaft can't move at all. Think my axle shafts could be too long? Or something else?
  18. May 27, 2016 at 5:10 AM
    #7118
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    it acts like the brass bushing in the spindle is too tight around the birfield when it gets pushed all the way on which creates tension between the two. should the brass bushing be able to go all the way up to the birfield joint rather freely?
  19. May 27, 2016 at 5:15 AM
    #7119
    slander
    Hickory, NC
    Are they stock birfs? You may have to clearence the inside of the knuckle ball if not. I would go searching or asking on marlins board or even pirate, TW is good for learning how to put chicken wire in place of your stock grill, not good for mini truck axle tech.
  20. May 27, 2016 at 5:19 AM
    #7120
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    they're longfield TG birfs. we clearanced the knuckleball a little but like i said the only time that it binds up is when the spindle gets completely bolted down. I'm going to bet that the damn bushing is too tight around the birfield so that when the spindle gets pushed on its contacting it instead of being clearanced like .004" or whatever it is.
