Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Aug 4, 2016 at 6:18 PM
    #7421
    RPS1030
    RPS1030 Well-Known Member
    Uhm, depends. IFS Controls Arms are GONE! If it's a linked suspension, it has upper links or control arms different from IFS.
  2. Aug 4, 2016 at 6:21 PM
    #7422
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    Are the control arms in a different location on a solid axle conversion?
  3. Aug 4, 2016 at 6:24 PM
    #7423
    RPS1030
    The entire stock IFS front suspension is removed and cut off of the frame. Nothing remains, nothing is reused.
    Then it depends on if leaf springs or coils/coilovers are used with straight links.
  4. Aug 4, 2016 at 6:31 PM
    #7424
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Ok, thanks. So regardless of what's used (coils/leaf springs) there are no upper control arms? Sorry to keep emphasizing that. Got into a discussion with a friend who recently bought a jeep. I know they come stock with a solid front axle but I'm guessing it's different than the link set up
  5. Aug 4, 2016 at 6:49 PM
    #7425
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Jeeps have a 4 link front with a panhard bar. Yes they do have control arm, but they arent like the A arms that are on a tacoma.
    allenfab likes this.
  6. Aug 4, 2016 at 6:52 PM
    #7426
    RPS1030
    Yeah, you're getting into naming conventions with that argument. Jeep links are usually called control arms. But each Jeep Control Arm has 2 point of connection (frame end and axle end). Where as Tacos have 3 points (2 at the frame and 1 at the spindle/balljoint)
  7. Aug 4, 2016 at 6:55 PM
    #7427
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Thanks guys.
  8. Aug 4, 2016 at 7:09 PM
    #7428
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Radius arm? Lol
  9. Aug 4, 2016 at 7:18 PM
    #7429
    RPS1030
    Shit, now things are getting weird. :spy:
    Back to 3 point is connection, but it's 1 at the frame and 2 at the axle. Locates and limits axle rotation with 1 piece instead of 2 on that side of the vehicle.
  10. Aug 4, 2016 at 7:23 PM
    #7430
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I'm saying they're basically the same as a radius arm :laugh:
  11. Aug 4, 2016 at 7:24 PM
    #7431
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Ok, so with the 3 link set up, the links are the control arms or the radius arms? I need to read up more on SAS.
  12. Aug 4, 2016 at 7:34 PM
    #7432
    RPS1030
    Jeeps are 5 links - 2 uppers 2 lowers and 1 track bar (binds by design eventually, requires rubber bushings)
    Triangulated 4 link has 2 uppers and 2 lowers. 1 or both pairs (uppers and/or lowers) are triangulated (frame end and axle end have significantly different mounting widths) to limits lateral movement.
    Standard 3 link has 1 upper, 2 lowers and 1 track bar. Upper limits axle rotation, track bar controls lateral movement.
    Radius Arms have 2 "lower" arms and 1 track bar. Radius arms have 2 mounting points on the axle to limit rotation and the track bar controls lateral movement.
    bayareataco, Ugly Betty and stumbles like this.
  13. Aug 4, 2016 at 7:35 PM
    #7433
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  14. Aug 5, 2016 at 12:35 PM
    #7434
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    @rctoy do you air down when you pull?
  15. Aug 5, 2016 at 9:14 PM
    #7435
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Well that sucked... Launched way too hard and snapped the output off of my FJ case and toasted the double cardan joint in the drive shaft.. Going to swap in my spare output before the mud drags next weekend. Good thing I needed something to do
    ckeene9 and 45acp like this.
  16. Aug 6, 2016 at 7:24 AM
    #7436
    slander
    Hickory, NC
    Damn i ment to start a "what will nwi break" poll, but got busy last night and forgot!
  17. Aug 6, 2016 at 4:02 PM
    #7437
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    I told the flag guy before I hooked up I was gonna snap an output, I'm glad it was the tcase lol
    She's almost good as new...gonna hold up and put 2 new output seals in while I've got things apart.
    Mud drags this friday :D
  18. Aug 7, 2016 at 8:42 PM
    #7438
    bullaculla
    Da big big island!
    Getting there... Not really tho.
    Just wheeled the axle outside to give it a coat of primer, and I thought I'd slap the wheels on to see how it looks and fits.
    Sadly I'm still wrestling with my front range off road X member. So no link brackets or shock towers yet...
    Acerwin and bayareataco like this.
  19. Aug 7, 2016 at 9:15 PM
    #7439
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Looking good @bullaculla !! Keep pushing. Took mine out for the maiden voyage at the local ish svra. More pics in my build
  20. Aug 7, 2016 at 9:38 PM
    #7440
    bullaculla
    Da big big island!
    Sweet! Been lurking your build too :spy:
