Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Oct 2, 2016 at 2:55 PM
    #7641
    RPS1030
    RPS1030 Well-Known Member
    Considered actually rotating the knuckle balls? Caster is way forward and could cause squirrely steering and/or slow or no return to center.
    Or not moving the perches will keep the geometry between arms and springs in a position less likely to contact.
  2. Oct 2, 2016 at 2:59 PM
    #7642
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    We may try rotating the knuckle balls. Really not something we want to mess up and dont have a jig. We moved the perches out wider but was thinking of not rotating them on the 2nd axle.
  3. Oct 2, 2016 at 6:16 PM
    #7643
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Yeah bought a diesel and built a trailer for a reason. I might run it down the freeway on some 38's
  4. Oct 3, 2016 at 11:37 AM
    #7644
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Need some ideas for fixing this disaster. Besides the gapping hole in my firwall, I'm not sure the rag joint solution was a good one.
    Damn hackIMG_20160930_154315127.jpg IMG_20160930_154323137.jpg IMG_20160930_154343626.jpg
  5. Oct 3, 2016 at 12:42 PM
    #7645
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
  6. Oct 3, 2016 at 1:54 PM
    #7646
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    I have a 1st gen and used the firewall plate from Trail Gear. It was not a perfect fit, so a small bead of silicone was needed to seal the gap.
    In terms of the steering shaft, i ended going with a custom piece from PSC. You can't find it on their website but they built one for me. It was not cheap...but It saved me a ton of time and it is actually a great part.
  7. Oct 3, 2016 at 2:32 PM
    #7647
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
  8. Oct 3, 2016 at 2:33 PM
    #7648
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    You recall roughly how not cheap it was? Couple hundred? Sounds like a good idea
  9. Oct 3, 2016 at 6:01 PM
    #7649
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I would recommend trying the FROR firewall plate over the Trail Gear one. The tube/hole portion on the TG unit wasn't even round and I couldn't get the TG steering seal to fit. Ended up throwing it out. I don't recommend the TG seal either. I have it mounted (but obviously haven't used it) and it's already tearing/cracking. :mad:
    Also, I HIGHLY recommend Woodward for steering components. Great quality, tech, prices, and selection to make custom setups. I used them for mine and couldn't be happier. I'm sure they can build a steering shaft for you. If not, it's easy to weld the components together yourself.
    http://www.woodwardsteering.com/
    Here's the first setup I did. Toyota splines on one side of the u-joint, and a Woodward spline on the other. Woodward splined stubs welded into DOM tube, and an identical u-joint on the opposite end.
    [​IMG]DSC00019 by Jonathan Krajnak, on Flickr
    [​IMG]DSC00018 by Jonathan Krajnak, on Flickr
    [​IMG]DSC00023 by Jonathan Krajnak, on Flickr
    ckeene9 and la0d0g like this.
  10. Oct 3, 2016 at 8:56 PM
    #7650
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    @SGTCap This plate sucked asshole, at least for me. All the problems @45acp had with his trail gear plate, i had with the fror unit. The inner hole was not round and the seal didnt fit inside it, none of the bolt holes were the right size or lined up, and it fit the firewall like shit. Make your own, i would have been time ahead making it out of plate with an angle grinder over cussing at and modifying that POS firewall plate.
    Ugly Betty likes this.
  11. Oct 4, 2016 at 4:35 AM
    #7651
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Alright, guess I'll make my own. Thanks for the heads up guys
  12. Oct 4, 2016 at 6:02 AM
    #7652
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    What a shame that no vendor seems to get these plates right. Jeez...it's just a pieceof bent steel with a hole in the middle.
  13. Oct 4, 2016 at 7:33 AM
    #7653
    slander
    Hickory, NC
    Pretty sure i yelled all this exactly, 3hrs into getting the fror one to work.
  14. Oct 4, 2016 at 12:52 PM
    #7654
    Boomtacoma01
    Houston
    Well shit. Didn't know that these plates had these sorts of problems. I retract my suggestion.
  15. Oct 6, 2016 at 7:39 AM
    #7655
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    I also had the same issue with the TG plate.. Ended up saying "Fug it" and ran it in with self tapping screws..
  16. Oct 6, 2016 at 9:13 AM
    #7656
    slander
    Hickory, NC
    Mine is held in with two factory screws and foil tape and the shaft is sealed with sheet rubber i got from menards and foil tape. Waste of money and an evening and a half of of time dicking around with that plate.
    suttonkb[QUOTED] likes this.
  17. Oct 6, 2016 at 9:37 AM
    #7657
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    I keep seeing this reoccurring trend of the issues with this firewall plate. I didn't have nearly the trouble as anyone that has posted regarding fitment. I actually was even able to fit the plastic "cover" aesthetic piece. Only thing I can think of is that everyone who has had this issue has pushed the steering box as far forward as possible and so now the angle of the steering shaft in "shifting" the alignment of this plate.
    Ideas, thought? Just curious.
    Ugly Betty, allenfab and malburg114 like this.
  18. Oct 6, 2016 at 9:59 AM
    #7658
    slander
    Hickory, NC
    Mine was all the bolt holes were in the wrong spot and too small, and the seal didnt fit in the center hole. I moved my steering box closer to the firewall so that affected the center hole (was ready for that), however the seal didnt even fit before i got the shaft in.
    SGTCap and suttonkb like this.
  19. Oct 6, 2016 at 10:00 AM
    #7659
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    Mine is def pushed as far forward as i could get it.
    SGTCap likes this.
  20. Oct 6, 2016 at 12:35 PM
    #7660
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    That's the issue! It seems those plates are designed to stock steering box location.
    My box is pushed all the way to the front body mount. That was the only way to get clearance for stuff.
    SGTCap likes this.
