Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Oct 24, 2016 at 10:30 AM
    #7741
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    They're aluminum. I'm tempted to try to melt them away with the torch, but I'm told it won't work
  2. Oct 24, 2016 at 10:38 AM
    #7742
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    So how do people cut strong pieces of aluminum? There must be something that work lol
  3. Oct 24, 2016 at 10:45 AM
    #7743
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    honestly just buy a "thin" wall socket take a flapper disk to it and you'll be golden. If the easy way doesn't work then you can always get creative with a wide vane bur bit for and air dremmal tool.
  4. Oct 24, 2016 at 10:59 AM
    #7744
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    The thin wall socket option was already recommended but he said they don't sell them anywhere:D
  5. Oct 24, 2016 at 11:01 AM
    #7745
    rctoy
    konstantenos
    Pocatello Idaho
    hence the "thin" and taking a flapper disc to it to make it thin.
  6. Oct 24, 2016 at 11:04 AM
    #7746
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Got you LOL. I read that too fast the first time around :D
  7. Oct 24, 2016 at 11:11 AM
    #7747
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Just like a D60 Pinion Nut socket :D
  8. Oct 24, 2016 at 2:56 PM
    #7748
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    I got a flip socket from low range Offroad that is thin and made for those nuts. It's 19 and 21 mm
  9. Oct 24, 2016 at 3:58 PM
    #7749
    rctoy
    konstantenos
    Pocatello Idaho
    I havent had an issue ever but i have like 80K in tools so it's not hard to find the right tool for the job.
  10. Oct 24, 2016 at 5:30 PM
    #7750
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I think I have the problem figured out and solved but I won't know for sure till I go back to the truck and try it
  11. Oct 24, 2016 at 7:31 PM
    #7751
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Bought a 13/16 socket which is the biggest thing I can fit it the spacer and hogged out the inside. Modern sockets have rounded edges to prevent the corners of bolts from rounding but it means the socket has to be thicker. I figure if I knock those high spots down with the dremel it might fit over a bigger nut. Hope this worksIMG_20161024_222629921.jpg
  12. Oct 25, 2016 at 7:19 AM
    #7752
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Finally happening
    Boomtacoma01, Nickel and Sacrifice like this.
  13. Oct 25, 2016 at 7:44 AM
    #7753
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Hell yeah!! I wish I'd gone this route
    allenfab[QUOTED] likes this.
  14. Oct 25, 2016 at 8:25 AM
    #7754
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Damn, you must have really well equipped garage. That's a dream of mine to have a garage with hydraulic lift and a shit ton of tons at my disposal.
    Awesome!
    Would you mind sharing your thought process as you selected the 4spd with that gearing?
    I debated for a while but ended up with a 2spd atlas, after receiving advise from multiple individuals that affirmed a 2spd would be a better choice for my specific application. The gears on the 4spd are either too close to each other on one end, or way to far on the other end. This might work well in a vehicle with a different configuration, but with my 2.7 5spd running on 40"s the 2spd Altas does not have as much gear overlap.
    Looking forward to hearing your opinions.
  15. Oct 25, 2016 at 10:05 AM
    #7755
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Anyone know if they make an adapter for the 6 speed trucks
  16. Oct 25, 2016 at 11:59 AM
    #7756
    rctoy
    konstantenos
    Pocatello Idaho
    I work at a shop with 4 2 post lifts and we have a sister shop with a 4 post and alignment rack. It's a must to have lots of tools. My dad and i have a shop with a two post lift and i don't even wanna think about how much into that shop.
  17. Oct 25, 2016 at 2:03 PM
    #7757
    allenfab
    Todd
    Lakeland, FL
    I really just did a lot of research on what other similar trucks had for dual t-case gearing (mine is a 3.4/r150f 5-speed with 4.88s in the axles). I saw a lot of guys running dual yota cases with 2.28s and 4.7 gears in the cases and they seemed very happy with that setup so I went with the 2.72 and 3.8 gearing which is 10.34 in double low. I'm not running a lot of high traction trails like the west guys but I plan on it. I have some ratio options written down at home that I'll post when I get home.
    Ugly Betty likes this.
  18. Oct 25, 2016 at 2:12 PM
    #7758
    rctoy
    konstantenos
    Pocatello Idaho
    I did the 2.72 and the 3.0. great new is if i want to jump to the 3.8 in the rear case i can do that later in life, for now though i actually love having that gearing because depending on what tire size im running i can be very close to a factory 4low gearing and performance. The 3.0 is perfect with my 42's and on 39's the 2.72 is perfect. it's 8.0 in double low and thats stupid slow esp. with the auto. My max speed in double low is 25 mph in overdrive and bouncing of the revlimiter.
  19. Oct 25, 2016 at 6:36 PM
    #7759
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Interesting.
    For my application I couldn't quite visualize how the gearing available for the 4spd would work with the gear overlap.
    With the 2spd atlas, 5th gear in low range is just below 1st gear in high range. It sort of transforms the tranny into a 10speed without too much gear overlap in the tcase. With the 4cyl this seems to work well.
    However, i'm stuck with a very low reverse gear :(
    Most of the toyota guys with duals i talked to said that most of the time they wheeled with the 4..7 anyway. But it is nice to have that ultra low-low final gear if needed.
    There are so many variables to consider. I wish the AA had more options in the gears you can select to configure the 4spd.
  20. Oct 25, 2016 at 6:45 PM
    #7760
    rctoy
    konstantenos
    Pocatello Idaho
    Yeah other than not having a double low there's nothing wrong with a really low low range. But having gearing options is what won my last tractor pull competition
