Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Feb 14, 2017 at 7:32 AM
    #8241
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Well...that's not too bad. If you add the time it takes to rebuild and drill/tap an almost 20 y/o from a junk yard, I think their asking price is "OK" for those of us lazy asses that do not like to spend time doing that kind of work :D
  2. Feb 14, 2017 at 8:23 AM
    #8242
    la0d0g
    running for the hills
    For crawling not hauling
    This is a strange statement coming from the dude that is always talking about spending less money.
    malburg114 likes this.
  3. Feb 14, 2017 at 8:29 AM
    #8243
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    I think you may have misunderstood my sermons :D
    My argument about saving money is not on things like steering boxes or "smaller" items. My sermons are about big ticket items like axles and entire suspension systems.
    So here's the sermon again: Typical dude says, "I want to keep it all toyota, leaf springs and will never go bigger than 35"s"
    Three years later the same dude gets 1 ton axles, 37"-40" tires and links with coilovers; essentially doing a SAS twice.
    That's all I preach about :D
    Besides, this is the SAS B.S. thread:luvya:
    Ugly Betty likes this.
  4. Feb 14, 2017 at 9:10 AM
    #8244
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    400 bucks for a tapped steering box is insane!! Send your junkyard box to west texas offroad and for 100 bucks more than allpros ass rapeing, you can have a ready to go HA system.
  5. Feb 14, 2017 at 9:25 AM
    #8245
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Sorry to change the topic but i'm still working on my spread sheet and thought i'd stop back in. Was hoping for some quick advise on running taller than 12" shocks/coilovers. I'll probably do a coilover over say an ORI. The big thing for me is I want to do all the big stuff (axles, suspension, gears, t-case, etc) once, so want to be sure a 12" coilover is the right decision and was hoping or some insight.
    Edit: This is for the front, haven't looked into the rear past the Chevy 63 leaf swap.
  6. Feb 14, 2017 at 10:14 AM
    #8246
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Good approach (bold letters above):thumbsup:
    I am afraid there is not a simple answer to your coilover question. There are a lot of variables, it all depends on what you want to accomplish with your suspension travel/movement.
    I think most guys have 12" coilovers. I have 14" coilovers, no regrets there.
    Few local guys have 16" and 18" and I can tell you they had to be aggressive with how they designed their suspensions to get the best out of those longer coilovers.
    I think you will be fine with a 12" or 14" coilover. Anything longer and you will probably need to do some heavy frame notching or build and entire new front end section of the frame with square tubing. You need to bring those coilovers as far up as possible to keep the ride low, but you also need to make sure nothing binds when the axle moves up/down.
    It's really a lot of trial/error and compromising. It would be ideal if you had a couple of different coilovers of different lenghts at your disposal to mock your suspension as you go.
    CedarPark[QUOTED] likes this.
  7. Feb 14, 2017 at 10:14 AM
    #8247
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    You can have a general idea but you won't really know for sure what you can fit until you get the axle under the truck and start to measure. The packaging on the front can get interesting depending on ride height, up/down travel you are able to run, and how much cutting you want to do. There are a ton of variables when picking shock size.
  8. Feb 14, 2017 at 10:18 AM
    #8248
    CedarPark
    Dylan
    Cedar Park, TX
    I wouldn't go bigger than a 14".. All the websites, like All Pro, have hoops you can just buy for 12" shocks. Basically wondering if a 14" is worth the extra work.
    Hah, I hate that. I'm the type to plan everything before jumping in when it comes to heavy financial investments. Sure it'll be fun once I get there though :D
  9. Feb 14, 2017 at 10:18 AM
    #8249
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Agreed with the above posts, shock length is really going to depend on after you fully cycle the suspension and get real numbers. i.e. up-travel/down-travel, compressed and extended lengths.
    Common sizes are 12" and 14" tho.
  10. Feb 14, 2017 at 11:02 AM
    #8250
    la0d0g
    Budget for 18s and then you'll get some $$ relief when the project starts :D
    Ugly Betty and CedarPark[QUOTED] like this.
  11. Feb 14, 2017 at 11:23 AM
    #8251
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Budget? What the hell is a budget on a truck build? :luvya:
    Boomtacoma01 and la0d0g[QUOTED] like this.
  12. Feb 14, 2017 at 1:04 PM
    #8252
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    VonWilsonator on p4x4. I think he's $120 shipped for a rebuild tapped IFS box. Hes up to like 100 or so hes done for people...
  13. Feb 14, 2017 at 2:15 PM
    #8253
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Someone just sent me a link to them. I was gonna coll them. I need a box as well, mines fubared so I'm hoping I can buy the core from them. Is there system worth a fuck? The price is sure right
  14. Feb 14, 2017 at 2:32 PM
    #8254
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    It's not even tapped! :rofl: just rebuilt. Well if anyone wants to make an offer, shoot me a PM. Like I said, brand new from all pro.
  15. Feb 14, 2017 at 3:20 PM
    #8255
    slander
    Hickory, NC
    Yea they have been around forever in the jeep world. They make a system called the "redneck ram", bascially a cost effective hydro assist system. I would 100% use and trust them, i just recently found out they did toyota stuff after forgetting about them.
  16. Feb 14, 2017 at 3:21 PM
    #8256
    slander
    Hickory, NC
    Lmao WOW!!
  17. Feb 14, 2017 at 3:41 PM
    #8257
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Drilling, tapping, and rebuilding an old Toyota steering box is seriously the easiest part of a SAS. You can do it for less than $100 including the price of the box from a salvage yard.
  18. Feb 15, 2017 at 7:55 AM
    #8258
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    You must have done a bunch of them then :D
  19. Feb 15, 2017 at 8:17 AM
    #8259
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Just get one from lowrange? (Trail gear) alreadg tapped and rebuilt. Don't mess with junkyard ones. Paid 90 buck for it snd took a crap within less than a year.
    James at Lowrange likes this.
  20. Feb 15, 2017 at 10:19 AM
    #8260
    time2getdirty
    time2getdirty Well-Known Member
    David
    2011 Black Access Cab
    Rebuilt with lifetime warranty at autozone for less than $300....
    I think I will take that gamble.
