Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Mar 20, 2017 at 1:24 AM
    #8481
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    That's what I am gonna try if I can find an axle locally. If not, I'll go diamond again.
  2. Mar 20, 2017 at 2:32 AM
    #8482
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Famous last words :D
    Ok, you might not go over 40". But what about wheeling with 37", 38" or 39" tires without having to worry about breaking anything?
    It pays off to think outside the "all toyota parts" box. A 14bolt shaved is just such a great option. Cheap, strong, plenty of aftermarket support, etc. Also, with 2nd gens I would personally go with 1 ton axles anyway, as those trucks are heavier, bigger and wider.
  3. Mar 20, 2017 at 4:12 AM
    #8483
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    The FJZ80 rear is a one-ton axle. 9.5" R&P, full float axles, beef housing. If it walks like a duck and talks like a duck....
    They are cheap on car-part, 6-lug, lightweight, high clearance, and gears are as easy to setup as any other Toyota third with multiple locker options. It's a great axle option.
    Pair one up with a fabbed housing with a 9.5 third and FZJ80 outers and you've got a kickass combo. Especially now that there are options for either high steer on fabbed knuckles or y-link with a RHD steering arm.
    NorthwestCruiser likes this.
  4. Mar 20, 2017 at 5:30 AM
    #8484
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Interesting. I guess I don't know much about those axles :D
    Question is, after everything is said and done, can you build them as cheaply as a 14bolt or dana 70 and will they have the same amount of strength?
    xweslingx likes this.
  5. Mar 20, 2017 at 6:45 AM
    #8485
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    I'm going to be running a rear d60 once it's done getting the gears and locker installed. It'll have 35 spline axles etc. Plus the superduty 10" ring and pinion can be run in a 60 as well. It's not a bad choice. Me personally it came down to weight and ground clearance when I made my choice as well as being readily available to me. Also For a second gen I'd definitely say one ton from the get go. I've seen lighter trucks on smaller tires twist 9.5 shafts. It's not "really"a one ton axle and the fzj80 is not a one ton truck last time I checked.
  6. Mar 20, 2017 at 8:28 AM
    #8486
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Depending on the original condition of the axle you could. Is it as strong as a 14bolt, no, but its good enough for what 98% of wheelers do with a full cab truck. Plus it doesnt weigh a fuck ton and it has good ground clearence stock as opposed to a 14bolt.
    I considerd a 14bolt, but went fj80 because it would have been less work to hook the brakes up as opposed to a 14bolt and i wanted to have something a bit different. Over half the people i wheel with have 80s or 80 rears so it helps they would have spares for me as needed. I did just buy a set of rear hubs for it incase i break the hub studs i can get it back wheeling again in a few hours. I also carry spare shafts for it. My friend with a 14 bolt carries the same level of spares for his truck as well.
  7. Mar 20, 2017 at 9:06 AM
    #8487
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    It seems like those 80 rear axles are a good choice then for tires under 40". I guess if they can be found and built cheap, why not? Why is it that not more toyota guys are using those axles? Just curious.
    Yea, a 14bolt has no clearance in factory form. Have to shave them to make it practical, otherwise is a waste of time. There are actually some "hidden costs" with 14bolts: shave kit, labor [if you do not trust your welding; better what you are doing!], shaved gears [if you do not have the tools to shave it yourself], disk brake conversion, etc. I ended getting a late model 14bolt, as they come with disk brakes already.
    Your friend carrying spare parts for the 14bolt is probably wasting his time. I have never seen anybody break those axles :D I am sure it has happened though..
  8. Mar 20, 2017 at 9:47 AM
    #8488
    la0d0g
    running for the hills
    For crawling not hauling
    Want to know an easy way to jinx yourself?
    slander and THROTTLE231 like this.
  9. Mar 20, 2017 at 10:07 AM
    #8489
    slander
    Hickory, NC
    The offset scares people on the 80 axles for some reason. If it wasnt for the yota freaks i wheel with i would have not even thought about them, i didnt even realize the 80s had a factory full float!
    His 14bolt came with twisted splines and was bent, he carries the stock twisted spline axles as trail spares. He twisted the center section skyward twice as well. Once he didnt weld it to the tubes, the second time the welds failed. He shaved it using his milling machine and it has the same ground clearence under the diff as a d44 and no shaved ring gear. Its pretty sweet but took him forever to do it.
    Also carrying spare parts almost guarentees you wont break them!
  10. Mar 20, 2017 at 10:36 AM
    #8490
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    That's why I've got spare inner axle shafts and a spare birf now. :D
  11. Mar 20, 2017 at 10:44 AM
    #8491
    slander
    Hickory, NC
    Lol, thats why i carry a spare tcase input and crawl box coupler!
  12. Mar 20, 2017 at 10:45 AM
    #8492
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    To be honest I did not know those axles were full float from factory either LOL. I thought it was a conversion people had to do. I guess you learn now things every day :D
    More people should be all over those axles. It seems like a really good option.
    BTW...it seems like your friend got a really beat up 14bolt to begin with. An yea..after the shave you get a lot of clearance. It's really an important mod to do to with those axles.
  13. Mar 20, 2017 at 11:36 AM
    #8493
    slander
    Hickory, NC
    He paid 50 bucks for a c&c 14bolt out of an old tow truck, so yea it was beatup. He built a triangle of death and bent that mofo back into position. He was going to build a clone of it with a 14bolt i got for free to swap in my old jeep, but i sold that hunk of crap jeep before that swap ever went down.
  14. Mar 20, 2017 at 11:51 AM
    #8494
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    :ballchain: Damn I'm over here wasting my time with a non shaved non disk brake 82 14bolt axle. Does it drag? here and there and every time removes a little of the problem. I figure ill let mother nature take care of the save for me:D
    phillstill likes this.
  15. Mar 20, 2017 at 12:30 PM
    #8495
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    I paid quite a lot more for my 14bolt with straight axle tubes :D
    Still a Jeep hater??:laughing:
    I guess the 14bolt can flatten those rocks pretty good LOL. Not a big issue with a tall rig like yours.
    But for the rest of us...the shave/disk brake mods are awesome.
    Actually, I can't believe you kept those nasty drum brakes LOL
  16. Mar 20, 2017 at 12:34 PM
    #8496
    rctoy
    konstantenos
    Pocatello Idaho
    Yeah I keep thinking I need to upgrade but I don't think the t100 master I picked up will do the trick. Haven't really looked into other options
  17. Mar 20, 2017 at 12:43 PM
    #8497
    slander
    Hickory, NC
    And he has less than 500 bucks into a locked and regeared 14bolt!
    Fuck yea, they stopped making good vehicles at the cj5. I owned 3 jeeps, a 93 cherokee, a 94 yj and a 44 willys mb. The only good thing on those chrysler era jeeps are the 4.0 and the 5spd, evreything else is left over scraps from other mfrs.
  18. Mar 21, 2017 at 10:26 AM
    #8498
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Yea I still haven't upgraded my master cylinder. I think the t100 is the ticket from what I've heard. Next on my modification agenda is to sort that out.
    But man...get rid off those drum brakes!
    I have about $500 in just the axle LOL! Add carrier, shaved gears, locker, add shave kit, labor for the shave job, etc. It got fun :D
    oh yea the 4.0 and 5spd was a good combo!
  19. Mar 21, 2017 at 12:52 PM
    #8499
    rctoy
    konstantenos
    Pocatello Idaho
    The biggest bitch is loosing the taco booster for the older t100 booster. Doesn't offer nearly the assist as the tacoma did. Half tempted to jump to a Chevy booster and master
  20. Mar 22, 2017 at 1:15 AM
    #8500
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    That's what my friend did in his SAS toyota...plus chevy parts are so ridiculously cheap.
    Please figure it out so that I can copy what you did since we basically have similar set ups lol
