Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. May 10, 2017 at 9:29 AM
    #8701
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    the tank is nice for setting beads (tbh ive only used it for motorcycle tires though to do that). the 450h is also 100% duty cycle so not really a worry there. just depends on how much of a hurry youre in when you air up i guess
  2. May 10, 2017 at 9:38 AM
    #8702
    cmack
    cmack Well-Known Member
    18 Burrito
    kinda what I was thinking too...
    good to know and I appreciate the info!
  3. May 10, 2017 at 11:43 AM
    #8703
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I paid $330 shipped to my doorstep. I played the CO2 game got old having to fill the tank and pack the heavy fucking thing around.
  4. May 10, 2017 at 11:43 AM
    #8704
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    The tank is also nice cause it gives the air a chance to cool and you can run a moisture trap in front of it. Those little portables put out a surprising amount of moisture. In Hawaii anyway...
    not a good thing if you are running balance beads.
  5. May 10, 2017 at 12:25 PM
    #8705
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I don't see a 480C listed anywhere for less than $200 a compressor....
  6. May 10, 2017 at 12:29 PM
    #8706
    rctoy
    konstantenos
    Pocatello Idaho
  7. May 10, 2017 at 12:36 PM
    #8707
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
  8. May 10, 2017 at 12:37 PM
    #8708
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Dual Smittybilt compressors is about the same price. If we are talking about shortest time to air up, dual Smittybilts with a small tank would air up a 35 in around 2 minutes. Viair is constant duty, and may have higher efficiency for air tools though.
  9. May 10, 2017 at 3:34 PM
    #8709
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
    haha very true... Its all good man I have thick skin, plus I live in Comifornia so I'm accustomed to people judging without asking questions:luvya: Anyways yeah the rear axle is diffidently coming out, I'm actually looking forward to seeing how much abuse the factory axle will take. The factory rear axle only has link tabs welded on it... Sooo pretty easy to swap out. The rear cantilever setup/cage was designed to easily swap the rear axle with only requiring new link tabs welded on. Who knows maybe I will replace both with PROROCK 60 and call it good:D
    bullaculla likes this.
  10. May 10, 2017 at 5:03 PM
    #8710
    rctoy
    konstantenos
    Pocatello Idaho
    I didn't buy them for their speed i bought them for reliability. As far as air tools goes i would never use them on trail i have cordless impacts 3/8" 1/2".
    I have front and rear ARB's so it makes sense to use compressors to activate. before my truck was ever built i did the CO2 thing and used it to air up tires and run my air bags with a regulator on the way back from cali i developed a leak in one of the air bags and the whole tank was gone half way home so the truck started to lean i Installed air compressors and replaced the air bag and when the other bag developed a leak it didn't matter the compressors just ran more.
  11. May 10, 2017 at 6:44 PM
    #8711
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    14bolt and spend the thousands of bucks you save on something else!
    Boomtacoma01 likes this.
  12. May 11, 2017 at 3:19 AM
    #8712
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Haha, true. You better have thick skin over there or you won't survive haha.
    Keep using the rear factory axle until you figure something else. Who knows...if you don't wheel like a maniac it might last you for a long time.
    You and I finally agree on something LOL :D
    When people go the 1ton route, yea, the 14bolt is a no brainer.
    However....if you really "build" a 14bolt, then it will still cost you some money no matter what - though a fraction of any custom axle.
    Typical 14bolt build:
    Price of the axle...(older model cheaper, late model more expensive)
    Add gears and locker plus labor....[if you don't do it yourself]
    Add shave kit...
    Add disk brake conversion...(older model only)
    Add parking brake....(older model only)
    Add labor for the shave job... (if you don't do it yourself)
    Add brake lines...
    Add diff cover...
    Add 14bolt to toyota flange...(if you want to keep your factory drive shafts).
    So it adds up and you are over a grand easily.
    Now, you can do it really cheap by getting an old school 14bolt, keep the drum brakes, skip the shave job, install the locker and gears yourself, etc. Grand total: $150-200 for the axle + gears and locker.
    But then you have an axle with a huge pumpkin that requires at least 42"s to get any decent clearance and huge drum brakes that work but are not as nice as disk brakes.
    I went with a later model 14bolt, those have disk brakes already from factory and ebrake.
  13. May 11, 2017 at 5:00 AM
    #8713
    slander
    Hickory, NC
    You are an idiot if you keep drums on a 14bolt and if you need to pay someone to do the shave job or anything but the gears, you should not be owning a SAS truck.
    malburg114 likes this.
  14. May 11, 2017 at 5:06 AM
    #8714
    rctoy
    konstantenos
    Pocatello Idaho
    I still have drum brakes. They work good enough but disk are on the list.
  15. May 11, 2017 at 5:29 AM
    #8715
    Sacrifice
    KS
    DCSB OR 4X4 LT
    IDIOT!:rolleyes:
    Sarcasm font in the extreme
  16. May 11, 2017 at 5:32 AM
    #8716
    rctoy
    konstantenos
    Pocatello Idaho
    Save that unimportant shit like brakes for last.
  17. May 11, 2017 at 5:37 AM
    #8717
    slander
    Hickory, NC
  18. May 11, 2017 at 5:55 AM
    #8718
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I dun red it
  19. May 11, 2017 at 6:00 AM
    #8719
    rctoy
    konstantenos
    Pocatello Idaho
    X2
  20. May 11, 2017 at 8:01 AM
    #8720
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I'm starting to feel like I might actually start my swap. I have the following sitting at the house and have a line on shop space to work in.
    - 94 Ford D60 (Already cleaned the mounts off)
    - 14 Bolt out of a 2000 GM Express Van
    - Hutchinson Beadlocks
    - Pitbull Rocker Radials, 41.5
    - Just ordered all the heims for the 3 link and steering up front
    The plan is to leave the chevy 63's out back for the time being and knock out the front 3 link. That's the quickest way to get me back rolling again, hopefully in time for Rock Therapy in October. I'll finish putting together my shopping list over the weekend and then set about setting my cc on fire. :D
    Nickel, Ugly Betty and Sacrifice like this.
