Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. May 11, 2017 at 8:08 AM
    #8721
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Get the gearing and lockers done while the axles are out and easy to deal with. Hope you make it to RT. Planing on being there for a full 9 days
    SMKYTXN[QUOTED] likes this.
  2. May 11, 2017 at 8:10 AM
    #8722
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    That's the plan. Now that I have both axles in hand I'm going to start making calls on the full rebuild package plus gears and lockers. Try to knock it all out in one swoop.
  3. May 11, 2017 at 8:20 AM
    #8723
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Oh really? Not as easy as it seems to shave those axles correctly. But you are more than welcome to try with the angle grinder and stick welder you used for your SAS:luvya:
  4. May 11, 2017 at 8:30 AM
    #8724
    rctoy
    konstantenos
    Pocatello Idaho
    Since I did an arb I went with thin factory 5.38 gears. Cam with pinion bearings and set up kit. Dana/Spicer is still making them. Just a thought.
  5. May 11, 2017 at 8:36 AM
    #8725
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    I think you are up to a great start. Nice parts list. But of course I am biased toward 1ton builds :D
    How do the early 90' ball joint D60s rate against other ones? I think I read somewhere that the early 2000's ball joint are the more desirable ones, but I really have no idea. just curious more than anything else.
  6. May 11, 2017 at 8:38 AM
    #8726
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'll keep that in mind bud. The plan is to run ARB's front and back. Looks like ECG has the gear kit.
    Ugly Betty likes this.
  7. May 11, 2017 at 8:39 AM
    #8727
    SMKYTXN
    Nathan
    Houston
    DCFB
    No idea, I just know that I can make it work and it didn't cost a fortune. I paid $450 for it, so I'm off to a good start.
  8. May 11, 2017 at 8:40 AM
    #8728
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    A stick welder is actually the correct application for that!
    Shaving the lip off takes 1min with a sawzall! The builder you paid made it sound harder than it is!!
  9. May 11, 2017 at 8:47 AM
    #8729
    rctoy
    konstantenos
    Pocatello Idaho
    I'm running a 92 Ford D60 from the what I've seen is people desire the newer super 60 because the balljoints are bigger and the C's are way bigger, as is the axle tubes. If anyone starts making lower gears for the dodge AAM axle that's where it's at. Way better option for a SAS. If I could get 5.38's and a arb for it I'd bail my Dana and run the AAM
  10. May 11, 2017 at 8:49 AM
    #8730
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I got my 08 SD dana60 for $300 :D
  11. May 11, 2017 at 8:52 AM
    #8731
    rctoy
    konstantenos
    Pocatello Idaho
    That's what my buddy paid for his snow fighter king pin 60
  12. May 11, 2017 at 8:53 AM
    #8732
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Ahhh...so that's what the differences are. Interesting. BTW, for some reason I thought you were running a kingpin D60.
    Also interesting to learn about the AAM axles.
    Oh....I have seen those 05+ D60s and those things are absolute monsters. The ball joints, Inner C's, knuckles and axle tubes are bigger than any other D60. Plus they come with 35spline axles from factory all around. Only negative is the unit bearings and very short driver side axle tube.
  13. May 11, 2017 at 8:54 AM
    #8733
    SMKYTXN
    Nathan
    Houston
    DCFB
    No one likes a show off! Dick
  14. May 11, 2017 at 8:55 AM
    #8734
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Man, I don't know where people find those kingpin axles so cheap. I looked for almost a year and couldn't not find anything cheaper than a grand...plus shipping.
    SMKYTXN likes this.
  15. May 11, 2017 at 8:58 AM
    #8735
    SMKYTXN
    Nathan
    Houston
    DCFB
    They get them from their brothers, uncles, cousin.
    jubei and Nickel like this.
  16. May 11, 2017 at 8:58 AM
    #8736
    la0d0g
    running for the hills
    For crawling not hauling
    Monkeys can mig, just saying. Stick ftw.
    bullaculla and slander like this.
  17. May 11, 2017 at 9:16 AM
    #8737
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I normally score deals locally off CL, junkyards or car-part. It takes some patience and being able to buy with cash right when things come up but deals are out there. Especially in the rust belt where you can get parts off of a vehicle that is a rusty pile.
  18. May 11, 2017 at 9:21 AM
    #8738
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Haha, yea, the same guy that also did a SAS for a $1,000 and a case of beer:rolleyes:
    Nickel and SMKYTXN[QUOTED] like this.
  19. May 11, 2017 at 9:27 AM
    #8739
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    I tried all of that. Ball joint d60s...oh yea, found a bunch of those everywhere for cheap.
    It was the kingpin D60s that were scarce....especially the late 70s ones.
  20. May 11, 2017 at 9:41 AM
    #8740
    Sacrifice
    KS
    DCSB OR 4X4 LT
    its definitely massive. huge bitch to move around by myself with only an engine lift also.
    :rofl:
