Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Oct 16, 2017 at 6:56 PM
    #9441
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    This is live from the garage, and this is close to maxed out, no real binding.
    SMKYTXN likes this.
  2. Oct 16, 2017 at 6:56 PM
    #9442
    slander
    Hickory, NC
    It doesn't, but it somehow works because math and geometry.
  3. Oct 16, 2017 at 6:58 PM
    #9443
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I have my rear flange nearly pointing at the tcase with single ujoints and can run as fast as i want. So who knows.
  4. Oct 16, 2017 at 7:05 PM
    #9444
    slander
    Hickory, NC
    That's weird, on paper that shouldn't work lol. I also have my pinion offset 3" to the right and the internet told me it would vibe, explode right into a bus full of nuns and it doesn't/has not so who knows!!
  5. Oct 17, 2017 at 6:58 AM
    #9445
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
  6. Oct 17, 2017 at 8:39 PM
    #9446
    SMKYTXN
    Nathan
    Houston
    DCFB
    I have my lowers mocked up and I'm sitting here looking at the realestate for the upper on the passenger side. There's not much room to play with and it seems like the cat on the header is going to be in the way.
    Does anyone have a good shot of their upper link they can share?
  7. Oct 18, 2017 at 11:35 AM
    #9447
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Upper link seems to always be a bitch no matter what rig you have.
    I have the exact same axle you have, completely different truck though. My upper link is on the driver's side. There's a small truss with an upper link axle bracket on top of the already gigantic pumpkin, and that's where the upper links connects at the axle end. Some people just weld the upper link bracket on the cast directly because of space issues.
    Sorry, don't have a good pic. The first pic on this post from my build thread gives an idea of what the small axle truss looks like. Hard to tell but the upper link is somewhere in there lol https://www.tacomaworld.com/threads/99’-reg-cab-3-link-sas-1ton-axles-atlas.441316/page-4#post-13234691
  8. Oct 18, 2017 at 11:41 AM
    #9448
    SMKYTXN
    Nathan
    Houston
    DCFB
    I took a look through Mark's build last night and found a few shots of what he did. From the looks of it I may need to raise the belly up from where it's at now to get everything in. My up travel at the moment is non existent.
    @NwiTACO what did your belly height end up being?
    Old pics from Mark's build.
  9. Oct 18, 2017 at 11:46 AM
    #9449
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Does he have a body lift? Also, did you decide to place the upper link on the passenger side??
    BTW...rookie question. How do you link pics from other threads onto your own posts? I tried to copy the the pic links but it wouldn't do anything :confused:
  10. Oct 18, 2017 at 12:41 PM
    #9450
    la0d0g
    running for the hills
    For crawling not hauling
    Click the picture and grab the media URL.
  11. Oct 18, 2017 at 1:00 PM
    #9451
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    cool tks
  12. Oct 18, 2017 at 1:37 PM
    #9452
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Here what I did on an 09. I was able to stuff a 2" upper without needing to move the cat. It is very close to the cat/flange and frame, but it clears at full bump and when fully flexed at each side. These pics are at full compression.
  13. Oct 18, 2017 at 5:02 PM
    #9453
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Is there more room on the PS or is it just easier to package the axle end mount?
  14. Oct 18, 2017 at 9:20 PM
    #9454
    SMKYTXN
    Nathan
    Houston
    DCFB
    There may be room, but it's damn close. I'm going to make life easy and just cut the cats off and weld in a new flange. :D
    The room is on the passenger side. With the diff and driveshaft on the drivers it would be a nightmare to get the upper link in there as well.
    allenfab[QUOTED] likes this.
  15. Oct 19, 2017 at 1:28 PM
    #9455
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    My friend got the SAS finished and now just needs to finish the front bumper and do the rear suspension. Which for now will just be chevy 63s thanks to your guys advice on this thread! Heres some pictures.
    22556095_10212061947916898_936561666_o_z_127ce076ec08a81a4343ebe18936012c27d54a50.jpg
    22643019_10212061948756919_1117414438_o__62fb02191225a9f3989ba60750dd6526448f17b3.jpg
    22642935_10212061949316933_1335113935_o__e7461e1eb7fe661357c586f9dac3435262ce379e.jpg
    22561191_10212061948236906_1676540569_o__3b875a5b41e353a70b4d17f40dab41cd65405204.jpg
    I will need to trim back the fiberglass fenders a little
    BudMan, RyanL, bullaculla and 3 others like this.
  16. Oct 20, 2017 at 9:30 AM
    #9456
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Looks good :thumbsup:
    What are the specs? Looks like a TG axle in there.
  17. Oct 20, 2017 at 9:37 AM
    #9457
    SMKYTXN
    Nathan
    Houston
    DCFB
    Managed to squeeze the upper link in last night. I did cut the cat off the header though. I mean, who needs cats? Lol
  18. Oct 20, 2017 at 10:16 AM
    #9458
    slander
    Hickory, NC
    Looking at that, would it have been beneficial to chop the frame rail off right in front of the cab mount and build a new one further outboard then move that link a bit further outboard and away from the motor?
    Ugly Betty likes this.
  19. Oct 20, 2017 at 10:30 AM
    #9459
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    There isn't really a downside to having the mount closer to the center of the axle. If anything it should provide more neutral handling, even though it transmits all of it's force to the PS frame rail.
    The reason a lot of 1st gen SAS chop the frame is to raise it up and provide better uptravel and steering link clearance.
  20. Oct 20, 2017 at 10:48 AM
    #9460
    slander
    Hickory, NC
    Yeah I frame chopped mine. I was just looking at the tight packaging and wondering if making some new frame rails would free up some space, other advantage is you would not have to plate it all the way down (he's obviously well past that step).
