Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Nov 27, 2018 at 4:37 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Anyone want a d60 front diff cover from ruff stuff? I ordered the wrong one awhile back. I’ll let go pretty cheap.
    Sold
  2. Nov 27, 2018 at 5:16 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    Maybe. Not sure on shipping. I am in 85004
  3. Nov 27, 2018 at 5:25 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Flat rate box $20 shipping.
    I’ll take $85 all together
  4. Nov 27, 2018 at 5:29 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    I'll send you a PM
    Acerwin[QUOTED] likes this.
  5. Nov 27, 2018 at 6:04 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Didn’t order the Superduty one ?
  6. Nov 27, 2018 at 6:40 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I thought I did at first but guess not :rolleyes:
  7. Nov 27, 2018 at 6:49 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ordered the motobilt one last week. Hope it gets here this week or early next.
  8. Nov 28, 2018 at 3:31 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    I have the lower link brackets from them. My truss is from artec and the rest is ruff stuff
  9. Nov 28, 2018 at 3:38 AM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yeah they all make good products. I’ll probably get the motobilt fuel cell kit eventually.
  10. Nov 28, 2018 at 3:47 AM
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    Should of got a train one
  11. Nov 28, 2018 at 8:12 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Thanks man. Cycled everything last weekend and only had to grind the cab a little. Plan is to run to big bear in California this weekend to pick up a solid axle industries full float kit with drive flanges to hopefully get this rear axle going. Supposed rear housing is 8 weeks out sadly. But then itll just be shafts.
  12. Nov 30, 2018 at 1:13 PM
    malburg114
    Las Vegas, NV
    Beef
    Acerwin, buyobuyo and jubei like this.
  13. Nov 30, 2018 at 1:25 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    So I've had a random thought floating around in my head for awhile, so I figured I would ask it here. Here or the LT forum seems like the most likely place to ask, but they're a little too salty over there. :rofl:
    Anywho... I was curious if anyone has converted a stock 2nd gen axle to free floating. This question first came to me when I was looking around on RuffStuff's website and saw their axle flanges that use Toyota front spindles.
  14. Nov 30, 2018 at 2:04 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Don't underestimate the SAS forum...
    I'm sure it can be done with an adapter ring that bolts where the drum backing plate would go and then a spindle bolted to the adapter but the real question is why bother? Then you need customer inner axles and all the hubs/brakes, plus drive flanges. Stock axleshafts typically are not a weak point and aftermarket housings aren't terribly expensive if you are looking to go FF or you can look at FZJ80 axles.
    6 gearT444E and malburg114 like this.
  15. Nov 30, 2018 at 4:55 PM
    malburg114
    Las Vegas, NV
    I have to agree with @Snowy. Seems like a waste considering all the work that needs to be done for not much of an upgrade. Rather go 80 axle or build a 9 in or Dana 60. hell you can even build a 14 bolt now and get 6 lug hubs for them.
    I say this yet look at my front axle... oh well live and learn :rolleyes:
  16. Nov 30, 2018 at 5:33 PM
    Timbo's Customs
    Timothy
    Lakeland FL
  17. Dec 1, 2018 at 6:49 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    No underestimation going on here. The amount of work you guys put into your trucks is amazing.
    Thanks for the comments, fellas. Mainly this is a thought experiment because I saw the axle flanges on RuffStuff's website. I'm running +2 LT in the front, so eventually I'd like a wider rear axle to match. I've looked around some at the various aftermarket axle options, but that's another massive chunk of change. I did stumble across someone local-ish that's SAS'ing their 2nd gen. He's selling off his stock parts for dirt cheap (including rear axle), so it got me thinking again about if anyone had ever tried widening and floating a stock axle.
    The main issue I see with the FZJ80 axle is that it's narrower than the stock 2nd gen axle from what I can find online, which is going in the wrong direction.
  18. Dec 1, 2018 at 10:33 AM
    malburg114
    Las Vegas, NV
    I'd almost say your better off building a 9 in. Fabricated housings are fairly cheap. Junkyard ones are next to free. Get a 35 spline center section and either do full float or semi float and I wouldn't worry about. Its expensive but this hole hobby is expensive. To much work and time in the stock rear and sourcing of parts I think to make that worth it
    Timbo's Customs likes this.
  19. Dec 1, 2018 at 12:13 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    I’m over 8k in parts and I’m still collecting haha. It is expensive
    malburg114[QUOTED] likes this.
  20. Dec 1, 2018 at 12:21 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Yeah. I figure it'd run me 3-5k for a built 9" axle.
    malburg114 likes this.
