Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Dec 2, 2018 at 8:29 PM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Feels decent at low speeds but did you take any turns at speed with it or try changing lanes quickly above 50mph? I don't know if what I'm feeling is normal or not, I'm just not used to it
  2. Dec 2, 2018 at 8:35 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Yes that's true. At that point sounds more complicated than it's worth. Before I made two separate loops I would isolate the ram and unbolt a clevis end so mechanically disconnect it. Trying to bleed air out of a two loop system would be a nightmare
    Justinogo[QUOTED] likes this.
  3. Dec 2, 2018 at 8:44 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Yeah I blasted down the interstate and took an interchange plus on/off ramps...felt pretty normal to me. Assist, plus bias ply iroks, plus leaf springs does not make for a particularly sharp driving experience on the highway
  4. Dec 2, 2018 at 8:46 PM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Very true. Probably more work and complexity than it would be worth. Guess I'll have to get used to it lol
  5. Dec 2, 2018 at 8:47 PM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Haha yyeeaahhhhh fair enough. Just not what I'm used to I guess
    malburg114 likes this.
  6. Dec 2, 2018 at 9:20 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    It keeps on adding up. It never ends.
  7. Dec 3, 2018 at 4:57 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Whats your current HA setup? (pump, reservoir, line size, cooler, etc.) I have realy good manners with HA even on highway curious to see if maybe something on your setup could be improved/rebuilt etc.
  8. Dec 3, 2018 at 8:15 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    It came on the truck so not 100% sure. I know it's a tapped ifs box and a trail gear pump, single ended ram and I think an oversized reservior.
    I don't know a ton about hydro stuff.. also my first truck with it so I don't know what it should or shouldn't feel like
  9. Dec 3, 2018 at 1:05 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Snap a few pics if you can. I would also look at the obvious things like cracked rubber lines, bad fittings, hose kinks, possible air pockets from poor line routing.
  10. Dec 3, 2018 at 3:34 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    It’s an off the shelf TG kit. 6x1.5” ram, TG pump, and TG lines. Tapped IFS box.
    Justinogo likes this.
  11. Dec 3, 2018 at 3:47 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Turns out my parts 80 is too nice to part out...so it looks like I’m learning how to change a 1fz front main seal, oil pump seal, VC gasket, and spark plug seals. Anybody want a green 94’ FZJ80? Body is perfect except for a hole in one rocker. Runs and drives great, just leaks oil badly from the front main. Manual cloth seats.
  12. Dec 8, 2018 at 5:39 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
  13. Dec 8, 2018 at 8:50 AM
    la0d0g
    running for the hills
    For crawling not hauling
  14. Dec 9, 2018 at 5:59 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Let me know if you do end up parting it.. ill take the front fenders from ya
  15. Dec 9, 2018 at 6:14 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  16. Dec 9, 2018 at 6:54 PM
    la0d0g
    Looks good!
    Acerwin[QUOTED] likes this.
  17. Dec 9, 2018 at 7:46 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I’m going to keep it whole, it feels like shooting a puppy to take it off the road. Just did the front main seal, oil pump gasket, resealed ps pump, distributor o-ring, vc gasket, and spark plug tube seals. It was leaking a ton of oil and PS fluid from the pump but ran great so I just fixed all the leaks and called it good. Whoever did the valve cover gasket previously didn’t drive the tube seals into the valve cover, just pushed them onto the tubes so it was huffing oil out the plug holes and breather BAD.
    I’ll find another one to pick the parts off that I want
  18. Dec 9, 2018 at 7:49 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Short shake down run with the 39s yesterday. Didnt break anything so that's a plus. Did well considering I barely aired down and no rubbing so I'm happy lol
    IMG_20181208_183634_926.jpg IMG_20181208_183631_251.jpg IMG_20181208_183644_295.jpg
  19. Dec 10, 2018 at 3:08 AM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks buddy.
  20. Dec 10, 2018 at 6:56 AM
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Looking sick! Gonna need some :sawzall: on those fenders though lol
