Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Jan 10, 2023 at 2:51 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    So set bump height with both sides full bump OR one side full bump, one side full droop?
  2. Jan 10, 2023 at 2:58 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Set bump height with both sides at full bump
    malburg114, sparkystaco and slander like this.
  3. Jan 10, 2023 at 3:01 PM
    Kerleyfries
    Zack
    Lebanon
    Yes sir.
  4. Jan 10, 2023 at 6:54 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I should clarify that you will need to cycle it at full articulation both ways to check for clearance too. The steering/knuckle on the compressed side will rise when the other side droops. Also your upper link mount will pivot left to right some and could interfere with the motor mount, frame, or motor itself.
    sparkystaco likes this.
  5. Jan 10, 2023 at 7:12 PM
    smacaulay
    smacaulay Well-Known Member
    Going through this right now, exactly my experience. Cycle, move brackets, cycle, repeat.
  6. Jan 10, 2023 at 7:26 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    How did you get rust on the truck out there? You do beach runs in it?
    Don't tell @slander that.
    lol
    copy that brother. No sheepy blue.
    slander[QUOTED] likes this.
  7. Jan 10, 2023 at 7:31 PM
    Yota X
    NW New Jersey
    1st gen
    Look @slander my cheap and laziness is actually paying off.
    Wulf likes this.
  8. Jan 10, 2023 at 7:58 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Not a fun process, especially trying to get a floor jack to lift high enough.
    How well is yours going together with the 4WU kit and 80 axle?
  9. Jan 10, 2023 at 8:24 PM
    smacaulay
    Pretty smooth, had to (and still have to) get creative in some places but that’s to be expected. It’s a great kit so far.
  10. Jan 11, 2023 at 10:27 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Oh I have no idea what that pile of parts has been through... just picked it up on CL for $1500 with no motor.
    This was the truck before they took a bunch of parts off it..
    1985 Toyota 4 runner
    Clean title
    cliff notes from this video and my brief inspection.
    Trans
    Dual T case 2.28 front 4.7 rear case
    Beefy Trans Mount / skid
    Drivelines
    LC engineering T case e brake
    Diffs 5.29 gears rear spool not sure about front yet
    Heavy Duty Longfield axles in front not sure about rear yet
    Rear disc brake conversion.
    Rear Kings smooth bodies 14'' i think?
    Front Bilstein resi shocks
    a mile marker winch in the front
    Warn winch out back.
    outlaw 2s on some old but surprisingly good looking 35
    All pro Billet rear shackles
    going to be swapping some stuff on to this pile VVVVV
    along with some
    37s
    Coilovers (with Air bumps because this thing rides like a covered wagon with 3 inchs of uptravel in the desert )
    3rz maybe turbo
    [​IMG] [​IMG]
  11. Jan 11, 2023 at 7:57 PM
    Yota X
    NW New Jersey
    1st gen
    Anyone know where a square wave tachometer input source on a 1st gen with no 1st gen drivetrain sensors may be had?
  12. Jan 13, 2023 at 5:30 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    Anyone have and opinion on air bumps vs Poly?
  13. Jan 13, 2023 at 6:19 AM
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    allenfab and Dayman Karate like this.
  14. Jan 13, 2023 at 6:43 AM
    Mr.Bl0nde
    Middle TN
    stuff
    :burp:
  15. Jan 13, 2023 at 6:48 AM
    02hilux
    Planet: EARTH
    IT'S FRIDAY
    slander likes this.
  16. Jan 13, 2023 at 11:34 AM
    Kerleyfries
    Zack
    Lebanon
    You need to worry about motors that don’t knock before you even ask about bump stops.
  17. Jan 13, 2023 at 11:39 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Air bumps for tons, poly for yota axles :luvya:
    allenfab and slander like this.
  18. Jan 13, 2023 at 11:46 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Quoted for truth
  19. Jan 13, 2023 at 11:50 AM
    Wulf
    rock raisin
    What is the best oil and why is it SuperTech 10W40?
    Dave41079 and slander like this.
  20. Jan 13, 2023 at 2:44 PM
    02hilux
    Planet: EARTH
    Because.....
