Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Feb 14, 2023 at 7:01 AM
    02hilux
    Planet: EARTH
    @smacaulay
    I'm running psc 1.75x6.75 ram, you will be fine with the 1.50x6. I didn't buy a hose kit (per your post with TG high pressure hose). I mount the ram, took some measurement and went to the local hydraulic shop and had them made the 2 hose for the ram and the high pressure hose from the pump to the steering box. 30 buck each hose at the time, might be close to 50 now?
  2. Feb 14, 2023 at 7:02 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    This is what I went with for full hydro. I haven't bought fluid or hoses yet. Clevis/tie rods from a Barnes kit.
    Trail-Gear Steering Shaft Adapters 130297-1-KIT- $78.67
    PSC Replacement Steering Cylinders SC2212K- $487.99
    PSC Power Steering Pumps SP1200X- $275.00
    PSC Power Steering Reservoirs SR146-6-10- $275.00
    AFCO Racing Power Steering Fluid Coolers 37600- $87.99
    Trail-Gear Steering Control Valves 130045-1-KIT- $480.48
    Trail-Gear Orbital Power Steering Mounting Kits 130295-1-KIT- $26.46
    Total: $1711.59
    TACORIDER likes this.
  3. Feb 14, 2023 at 7:14 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I'm a huge fan of the Eaton hose and fittings PSC sells. Field serviceable, clockable, and buildable on your own.
    https://www.pscmotorsports.com/parts/hose-kits-biy/psc-hk-achp.html
    I also run an all PSC setup: Resi, pressurized breather, TC pump and an 8" throw ram since I used FROR arms for my steering.
  4. Feb 14, 2023 at 7:18 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Is that the kind you cut with a razor blade push in and tighten down? I’ve been debating what to do for hoses. Would like to do it myself, unless it’s super difficult or risky to get a good seal.
  5. Feb 14, 2023 at 7:20 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    You need to cut them with a cutoff wheel in a grinder since they are steel braided internally. Then they thread into half the fitting before the other half screws into it. Similar to an AN fitting but crazy secure and easy.
  6. Feb 14, 2023 at 7:20 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    They are worth is, thread one part into the hose ID, then screw on the other part for outer OD of those hose. Never had a leak and they are great, do it yourself and keep some hose for a solid trail fix if you ever cut a hose.
    Dayman Karate[QUOTED] likes this.
  7. Feb 14, 2023 at 7:37 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    seems like the way to go then. No single purpose expensive tools to buy either which is always nice. Currently looking for a giant allen wrench to use once on my clevis bolts haha
  8. Feb 14, 2023 at 11:11 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Discounthydrualichose.com is another source for quick custom hoses if you don't want to build your own. They made me some PS hoses (-6 AN stuff) and were a quick turn around.
    la0d0g, sparkystaco and Dayman Karate like this.
  9. Feb 14, 2023 at 11:26 AM
    smacaulay
    smacaulay Well-Known Member
    Super helpful input guys, really appreciate it. Here's the updated plan with more PSC stuff (almost $1300 :eek:), will look into that Hayden cooler too:
  10. Feb 14, 2023 at 11:31 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    You're probably fine to use a Toyota pump and resi too if you wanted to save a few bucks.
  11. Feb 14, 2023 at 11:32 AM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    $32 - Trail gear PS belt (https://trail-gear.com/steering/steering-components-catagory/pump-pulleys/ps-belt-9430.html)
    NO V-belt for the 3.4, you use a 4groove pulley so make sure your ordering a 4groove pulley for the PS pump. Old 22re, maybe 2.4l? used v belts.
    Trying to find the belt length i used... **Looks like Bando 4PK1045**
    jubei likes this.
  12. Feb 14, 2023 at 11:48 AM
    smacaulay
    I smoked a stock 2.7 pump the first trip out on my last rig with the same axle, might have been other factors (no hydro assist) but I'm ok paying for peace of mind this time.
  13. Feb 14, 2023 at 11:49 AM
    smacaulay
  14. Feb 14, 2023 at 11:49 AM
    smacaulay
    Pump, pulley, and bracket ordered through Summit for <$400
  15. Feb 14, 2023 at 11:55 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Did you smoke the pump or just not realize how much an IFS box sucks without assist? With my assist lines capped off, I can't even turn 37's on my garage floor sitting still. Assist hooked up, and it's one finger all day.
    Either way, sounds like you've got a plan.
  16. Feb 14, 2023 at 12:04 PM
    smacaulay
    Pump gave out mid-trip, manual steering all the way out sucked. With deep backspaced wheels and 37's with the FJ80 axle the PSC pump i had on the 3rz worked well without hydro assist. I've got shallow backspacing on this one, and need to run 1" spacers up front to match my 07 rear axle WMS. Keep the questions and guidance coming, this is a huge help!
  17. Feb 14, 2023 at 4:31 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    I dont miss the days of no steering. Kind of suprised my front lived as long as it did with hydro.
  18. Feb 14, 2023 at 5:17 PM
    slander
    Hickory, NC
    Really even idling? I shouldn't bitch about my shitty Ford box that much then!
  19. Feb 14, 2023 at 7:40 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Right! I had no assist for half a day and I don’t know how you did it for so long.
    I’ve got probably 5psi in the tires right now but yeah. You could fight and muscle it if you really wanted but it wasn’t ideal.
  20. Feb 14, 2023 at 8:10 PM
    slander
    Hickory, NC
    Wow that sucks!!
