Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Feb 16, 2023 at 6:17 PM
    Dayman Karate
    Dayman Karate Ruffling feathers and turning eagles into vultures
    Clay
    Central Alabama
    2001 4Runner, JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Does anyone know the trick to engage 4wd on a second gen electronic tcase? I’m assuming it won’t work with the front actuator gone. Briefly read something about grounding a wire, but not sure past that…
    tacoma16 likes this.
  2. Feb 17, 2023 at 9:26 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I believe some have removed the actuator and gone to cable shifters on the case to get rid of the electronics but not having do the fj case swap.
    Dayman Karate[QUOTED] likes this.
  3. Feb 17, 2023 at 9:35 AM
    Dayman Karate
    Clay
    Central Alabama
    Alright I’ll try to do some more digging on a mechanical swap for the electronic hickey booger. I don’t feel like doing an FJ swap. If I’m swapping anything like that I’m starting from the front back with shit that’ll work for a bouncer/buggy :rofl:
    tacoma16[QUOTED] likes this.
  4. Feb 17, 2023 at 10:15 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    You know the answer, starts with A and ends with As(s)!!!
    Related note, have you flexed that beast out with the wheeled turned at full lock? Are you going to have to dove tail the front?
  5. Feb 17, 2023 at 10:22 AM
    Dayman Karate
    Clay
    Central Alabama
    If it’s LS/TH400/Atlas then yes haha
    haven’t stuffed it at full lock yet. Dropped the axles off to be geared yesterday, so when those get back I’ll see what I’m up against. I’ll be all in the front fenders, but hopefully not into the frame.
    tacoma16 and slander[QUOTED] like this.
  6. Feb 17, 2023 at 12:33 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Go buy a tcase out of an FJ or 5th gen runner. They’re $400 and bolt right in. Then sell the parts place your tcase for the same or more. They sell the electronic ones for way more because of the motor and actuator on them. Manual case bolts right in with no driveshaft modifications on 2nd gens.
  7. Feb 17, 2023 at 12:49 PM
    Dayman Karate
    Clay
    Central Alabama
    I’ll crawl under my FJ and see if it looks the same and will fit my crazy crossmember. Really don’t want to do it. I want to trick this stupid bitch into working.
    tacoma16 and Brownmatthall like this.
  8. Feb 17, 2023 at 1:26 PM
    Dayman Karate
    Clay
    Central Alabama
  9. Feb 17, 2023 at 2:46 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    The out side case is dimensionally the same. Few differences like a hole for the actuator but everything else is essentially the same.
  10. Feb 17, 2023 at 3:18 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  11. Feb 17, 2023 at 3:24 PM
    Dayman Karate
    Clay
    Central Alabama
    Somehow looks more complicated than the FJ swap haha I was hoping it would be a “ground this wire” situation. I don’t care if it stays in 4wd, just need to be able to switch between lo/hi.
  12. Feb 17, 2023 at 3:26 PM
    Dayman Karate
    Clay
    Central Alabama
    That’s good news. I think the spline count is even the same for the autos, so that makes life easier. Still don’t want to do it though :rofl:
  13. Feb 17, 2023 at 3:30 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    its the easiest solution. only "fab" work would be getting the shifter into the right location. also, have to move sensors from stock tcase to fj case
  14. Feb 17, 2023 at 3:32 PM
    Dayman Karate
    Clay
    Central Alabama
    Are the sensors a direct swap or need to be spliced?
  15. Feb 17, 2023 at 3:39 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    direct swap. the fj cases has wires with a connector coming off the sensors and they don't plug into the Tacoma. just have to take the sensors off the back off the Tacoma case and put them into the fj case. the fjcase has 3 sensors but you will only swap 2 over. i just reused one of the sensors as a plug with the wires cut off of it. the sensors do have to go into the right spots based on the connectors on the harness.
  16. Feb 17, 2023 at 3:45 PM
    Dayman Karate
    Clay
    Central Alabama
    Well dang. Doesn’t get any easier than that. I love shifting in the FJ, too. Such a cooler feeling than turning a knob haha
  17. Feb 19, 2023 at 7:09 PM
    02hilux
    Planet: EARTH
    @ToyRyd04
    What's the bump can OD measurement, 2.25"?
  18. Feb 20, 2023 at 2:21 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Yep 2.25" is the hole saw size I used when making the mounts. Had to massage the hole just a tad but not much. I notice the cans have the slightest taper going down.
    sparkystaco and 02hilux[QUOTED] like this.
  19. Feb 20, 2023 at 9:06 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Upper link with a bend in it to clear a crossmember, heims on both ends or does one end need to be a bushing to keep it from flopping, and if so which end bushed?
  20. Feb 20, 2023 at 9:26 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I've seen most guys do The bushing on the frame side
