Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Jul 14, 2024 at 4:43 PM
    WacoDaTaco
    WacoDaTaco Member
    Collin
    2007 SAS Tacoma
    80 series front housing
    Fj80 housing, yes mini truck is around 6” too narrow
  2. Jul 14, 2024 at 4:46 PM
    WacoDaTaco
    WacoDaTaco Member
    Collin
    2007 SAS Tacoma
    Mine is an inhousefab one from DRT fabrication. Excellent quality has a slight turn down at the top & ends up pretty much 90 degrees from level ground. I’ve driven it in the rain & filter seemed dry it’s not for everyone obviously but I personally love the look of it
  3. Jul 14, 2024 at 4:52 PM
    02hilux
    Planet: EARTH
    that’s not too bad with the 80, being 2” narrower then the second gen taco rear wms. Which knuckle are you running?
  4. Jul 14, 2024 at 5:07 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Appreciate the insight. I'll have a 1-3/4 tube coming down the A-pillar, so unfortunately I've got to build my own that sits either higher off the A-pillar or further to one side. I do love the look.
  5. Jul 14, 2024 at 5:13 PM
    WacoDaTaco
    WacoDaTaco Member
    Collin
    2007 SAS Tacoma
    I believe the 80 is .5” narrower then the stock Tacoma rear, but rough stuff knuckles for highsteer
  6. Jul 19, 2024 at 3:03 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Few more things to do and it’s shakedown time
    Road_Warrior, Xero, TSAVO and 7 others like this.
  7. Jul 19, 2024 at 3:41 PM
    WacoDaTaco
    WacoDaTaco Member
    Collin
    2007 SAS Tacoma
    Looks awesome !
  8. Jul 19, 2024 at 4:32 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Thank you. Need to work something things out. Breaks feel great steering box is a little loose but that’s trail gear for ya. Rear shocks need to be put in and possibly an extra leaf. Only running 3leafs no overload in the 63s are right now with a 6” shackle
    tacoma16 likes this.
  9. Jul 24, 2024 at 10:32 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    @Brownmatthall
    Brownmatthall likes this.
  10. Jul 24, 2024 at 3:03 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I probably should at some point
  11. Jul 24, 2024 at 5:34 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Swap it? Go for it. If I could do it over again I’d just get the Martec front kit.
  12. Jul 24, 2024 at 6:34 PM
    Brownmatthall
    2016 TRD OR DCSB
    That's definitely been radar...
  13. Jul 24, 2024 at 7:46 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    There is a guy out west that can get the abs working. Send the front and rear hubs and he will machine them and send brackets to get the speedo and abs shit off the dash
    Brownmatthall[QUOTED] likes this.
  14. Jul 24, 2024 at 8:34 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    After 9 years of being sas'd and 3 years of abuse from an LS2 I have broken the dana 60 ring and pinion in the front and the arb locker and bent the 14 bold housing ever so slight.
    tacoma16, Wulf, Operator8 and 3 others like this.
  15. Sep 2, 2024 at 12:22 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Those running hydro assist. Having a hard time getting smooth steering. Changed the gear box it’s better but soon as I go to turn the wheel fast it gets super stiff. Power steering pump issue? Flow issue Have sat and bleed and bleed the system and I can’t get it to act right
    2020 tacoma. Stock pump. Psc 1.75” ram 8” stroke
  16. Sep 2, 2024 at 12:37 PM
    Wulf
    rock raisin
    IFS box? is the ram by chance hooked up backwards?
    even with a stock pump it shouldn't be stiff, I'm running a bigger ram on a tiny stock 22re pump and it's ezpz effort wise just slow
  17. Sep 2, 2024 at 1:01 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    It’s hooked up right I disconnected the ram while figuring out my trailgear box was a pos. yes ifs box
  18. Sep 2, 2024 at 1:03 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Thinking it’s a pump issue.
  19. Sep 2, 2024 at 2:46 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Had this happen with a full hydro set up with a brand new psc pump. Changed the pump and no more stuff steering. On a further note moving the remote reservoir closer to the pump and installing the psc vent cap that holds pressure on the system helped with over all operation
  20. Sep 2, 2024 at 3:09 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Going to call psc tomorrow and get things ordered and get an eta. Online says backorder
