Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Sep 2, 2024 at 3:25 PM
    02hilux
    Planet: EARTH
    What’s the length from the reservoir to the pump? Is it more gravity fed? Any possible bend that can restrict flow?
  2. Sep 2, 2024 at 3:44 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    It’s a straight shot. 3/8 return to a big cooler back to the resi. Stock feed hose no kinks
  3. Sep 2, 2024 at 4:21 PM
    02hilux
    Planet: EARTH
    Do you know the size of the feeder? That might be the issue
    Wulf likes this.
  4. Sep 2, 2024 at 4:51 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    I don’t. I’d say around 5/8 or bigger
  5. Sep 2, 2024 at 6:25 PM
    02hilux
    Planet: EARTH
    If it’s 5/8+ then I’ll retract my statement. 5/8 should supply sufficient fluid to the pump. Only thing I can think of is the factory pump output isn’t efficient enough for the steering box and ram. On my buddy’s 5vz setup with the factory pump and no ram and no cooler, the steering will be fine until it gets hot. After that, it’s manual steering. He added a cooler which provided some relief until it heats up on the trail and back to square one. He then upgraded to PSC pump and added a ram and had no issue since.
    Wulf likes this.
  6. Sep 2, 2024 at 8:49 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Get a higher flow pump. My old psc pump was only 2.8 gpm at 1500 psi. Couldn’t steer when aired down unless moving or rev the engine. Swapped to a radial dynamics 4gpm at 1500psi and works better than ever
  7. Sep 6, 2024 at 8:59 PM
    Team_Jake
    Team_Jake Well-Known Member
    '99 4Runner Limited '01 Tacoma Xtracab
    It’s driving under its own power now, it’s been too long. Still a lot to do…
  8. Sep 6, 2024 at 9:40 PM
    02hilux
    Planet: EARTH
  9. Sep 6, 2024 at 10:35 PM
    Team_Jake
    40s, probably looks bigger pre-fender trim
    sparkystaco and 02hilux[QUOTED] like this.
  10. Sep 24, 2024 at 9:33 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Dunno if this is the right spot to ask but eh. Recently finished the SAS on the truck, shoutout trailtoys. Tons with a stock t case mated to a shit gear 4.7:1. One of the t cases (I think it's the stock, sounds like a chain) sounds like a military bombardment at double digit speeds without resistance, or constant above 48mph. Fluid levels are fine, I used 75w-90. No metal on flush. Both t cases still work fine but the sound is going to drive me fucking insane. Old pirate 4x4 threads say its just because of how steep the driveshaft angles are, which mine are, but this noise is going to give me an aneurism. Anyone know a troubleshoot/fix or should I just try thicker oil and send it?
  11. Sep 24, 2024 at 10:32 PM
    02hilux
    Planet: EARTH
    History on both case? Do the 4.7 case have new bearing or did you purchased the unit second hand?
    picture of truck on flat ground and shaft angle?
  12. Sep 24, 2024 at 10:50 PM
    CedarPark
    Dylan
    Cedar Park, TX
    Truck has about 70k so stock ones the same. 4.7 was installed a couple years ago with mayyyyyybe 5k miles on it. Truck spent most of the time after I threw the cases in broken, got it new
  13. Sep 24, 2024 at 11:09 PM
    02hilux
    Planet: EARTH
    how high is high, what’s ride height? I don’t suspect that being the issue as I rode in people’s tall 4R & Taco (30+ inches @ ride height) without gear/chain whine. The gear case is louder than the chain but shouldn’t be that bad. You sure it’s not a carrier or pinion whine?
    Got a short clip?
  14. Sep 24, 2024 at 11:21 PM
    CedarPark
    Dylan
    Cedar Park, TX
    I'll get some measurements and a clip in the morning. Not 100% sure its the t case but pretty sure it is, definitely sounds like a chain. Video clip will be scuffed since its at its worst at almost 50mph but i'll see what I can manage:)
  15. Sep 25, 2024 at 6:22 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Does pulling on the 4x shifter change the tone? On either tcase.
    What kind of 4.7s?
    What kind of crawlbox adapter plate?
  16. Sep 25, 2024 at 9:34 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Had some similar happen when I did mine truck had a 32" frame height it was the double cardinal joint on the rear drive line.
  17. Oct 17, 2024 at 9:16 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Just have a question about 2nd gen Tacoma sas.
    is there a reason why everyone goes to the ford d60 and not the chevy or dodge?
    ford d60 is high pinion, left side pumpkin I get it. but is there a good reason not to use a Chevy or dodge d60 other than no one makes a sas kit to put into a 2nd gen?
    thanks ahead of time.
  18. Oct 18, 2024 at 6:22 AM
    rctoy
    konstantenos
    Pocatello Idaho
    Oh God yeah. For instance most people are getting 05 and up for axles and Chevy don't have an 05 and up. The new dodge axle is driver drop high pinion but gearing down to 4.88 is the lowest you can go and it doesn't have hubs
    sparkystaco and Windigo[QUOTED] like this.
  19. Oct 18, 2024 at 6:23 AM
    rctoy
    konstantenos
    Pocatello Idaho
    In other news I have started collecting parts to 3 link the rear of my Tacoma and rear steer the 14 bolt
    bhigbee, sparkystaco and Windigo like this.
  20. Oct 18, 2024 at 6:30 AM
    Windigo
    Farook
    '14 Acess Cab
    from my old truck 2nd gen 4 runner I have the 60 from a 1st gen dodge and a 14 bolt both geared up and locked.
    do you think it would be worth it to run that 60 or would getting a ford one be the way to go. Not trying to do this on the cheep but at the same time If i can save by reusing the old stuff I have will it be worth it.
