solid axle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vang Toua Moua, Jan 17, 2012.
  1. Jan 17, 2012 at 9:00 PM
    Vang Toua Moua
    Vang Toua Moua [OP] Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    has anybody ever attempted to bolt on the v6 tranny onto a 4 cyl engine? and would it bolt right up. the reason is im doing a solid axle and wanted to become a 4x4 so he told me i would need a new tranny and transfer. help please.
  2. Jan 17, 2012 at 9:06 PM
    baja820
    baja820 Well-Known Member
    pacific northwest mountains
    '11 SR5 Tacoma V6 6MT 4x4
    Why do you want the five speed? I've heard they have issues slipping.
  3. Jan 17, 2012 at 10:19 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Run a divorced t-case. Problem solved.
  4. Jan 18, 2012 at 11:54 AM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    how does that work and where would i find one for the 4 cyl?
    no ijust want to become 4wd with the solid axle
  5. Jan 18, 2012 at 12:00 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    what axle are you using? links or leafs?
    why not just use the 4cyl trans and transfer case?
  6. Jan 18, 2012 at 1:42 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You know what they say...
    if you have to ask you probably can't afford it.
    Seriously though are you doing the work yourself?
  7. Jan 18, 2012 at 11:32 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    That's what I thought of because I saw some Ebay. Only place I could find it easily.
    Haha yeah but I have I just have no clue what would or would've fit. No im having a shop weld my parts. The 4x4 conversion is for after I have the axle on.
  8. Jan 18, 2012 at 11:45 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Well a divorced t-case is one that isn't mated to your transmission, rather it has a short section of driveline.
    So you fab up a t-case cross member and then get your driveshafts made and run the shifter linkage.
    This also means you can run different axles, drivers or passenger side drop as long as you find the corresponding case. Makes it a little easier to choose an axle.
    You can find a divorced t-case or you can find an adapter for a married case and turn it into a divorced t-case. That gives you a little more options and you can upgrade some with lower gears, giving you say 3:1 or 4:1 low.
  9. Jan 21, 2012 at 9:49 AM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    oh wow thanks very much, i never knew this far. well i found some transfer adapters but didnt know how they went. basiclly they hook up to any transfer or only certain kind?
  10. Jan 21, 2012 at 11:02 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You'll have to find ones that convert say a NP ### to a divorced unit. They'll be for specific units.
    Look into a Dana 20 or a Dana 300 or an NP205.
  11. Jan 21, 2012 at 1:53 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    oh ok, would they just hook up to any tranny? that would all make it way more simple. but i have heard from many other sites that the toyota t case is a tough son of a gun, tho?
  12. Jan 21, 2012 at 3:02 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Okay so if you divorce the tranny you can run whatever flange and u-joint adapters to run a driveline from your output to the t-case. Then you run drivlines from the t-case to the axles F&R.
    TRANSMISSION>----TCASE-------------R. Axle
    F. Axle____________
    You could run a divorced toyota t-case as well just find the right adapters and case and you can bolt the adapter to the cone then run a driveline from the output of your transmission to the flange on the adapter of the t-case then from the t-case to the axles.
    Make sense?
    I'm not saying that a divorced t-case is the best way to do it, but it's an option and I would think that it might be a good option for starting with a 2wd trans.
    Also makes it easier to run a doubler since you can run whatever t-case you want to run as long as you find the adapters. So the toyota case is probably a good option for doubler or single.
    My opinion is worth what you're paying me for it.
    http://www.ottindustries.com/divorced_toyota_tcase.html
    http://www.pirate4x4.com/forum/showthread.php?t=138650
    http://www.fourwheeler.com/techarticles/drivetrain/129_0710_11_best_transfer_cases/viewall.html
    just to clarify, whatever case you choose there are typically adapters to mate your driveshaft to both o/p of the transmission and to the i/p of the t-case.
    It might be easier to run the toyota t-case as they use a flange. But there are adapters for yokes to flange and from yokes of what style u-joint to yokes of another and there are also u-joints that go from one style yoke to another. Any driveline shop will be able to set you straight with what you need. Basically the most popular cases like the 205 should have adapters to switch from yoke style to flange style, or I'd think. All stuff to research before you buy a case.
    Or maybe it'd be simpler to get a toyota case then you don't need to worry about yoke to flange adapters but you'll probably need to figure that out with your axles. Research before you buy.
    Theres guys who know much more about this than me, so hopefully someone else will chime in but maybe try the solid axle section on TTORA?
    http://www.lowrangeoffroad.com/index.php/dana-60-flange-for-toyota-driveshaft.html
    I guess in the end what I'm suggesting is find the case you want to run, something strong, if you want a doubler make sure you can get adapters to double and then make sure you can get the adapters to divorce the case and adapters for the drivelines (that should be the easiest part). Then you fab your crossmembers, talk to some shops and see what length you should make the t-case to transmission shaft then have it made and have the shafts from your t-case to axles made. Run the shifter linkage, and you should be set. Research research research though to make sure this is the best option. I think it would be based on you can keep your factory transmission which you know is good, and you have more options for t-cases. Research though.
  13. Jan 21, 2012 at 3:48 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Sorry if that's confusing, I kept thinking of more things so I kept adding. :p
  14. Jan 21, 2012 at 9:32 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    holy smokes. thank you. now i understand how it all works. i got it with the help of the picture becasuse i have never seen how a divorced case was assembled. yes im doing research and it has been going on for about 2 or so months now. just alot of sites want you to buy their product but barely tell anything about it.
  15. Jan 21, 2012 at 9:46 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah I'd just get the adapters for the toyota cases. Divorce one and then double them together.
    OR give marlin crawler, inchworm, and lowrange offroad and give them your specs and see what adapters they have to mate a t-case to your transmission. That may be easier if they have adapters. If you can run an older style case you can run a doubler too. That gives you great control off road.
    http://www.lowrangeoffroad.com/index.php/yotamain/tacoma/transfer-case/prerunner-adapter-kit.html
    I think this would work actually. That would probably be a better option just make sure you make a mount for the t-case with rubber bushings as I believe the factory motor mounts are rubber. They should be able to tell you if it'll run on your truck and what cases you can mount behind it.
    I didn't think anyone made adapters thus my recommendation for a divorced t-case. Either will work but I'd go this way for simplicity.
    Edit: I see you're a 5 lug. I'll admit I know little about the 5 lugs and I'm not sure if you use the same transmission as the 6 lug 2.7 L 4 spds and if this adapter would work. Ask them. Also don't know much about the rear axle, would you be swapping both axles?
    Also, have you factored the cost of parts let alone labor for a swap like this? If you want a quality shop with excellent work check out Stoffregen motor sports in Cool, California. He has an account here.
  16. Jan 22, 2012 at 3:14 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    yeah that seems to be the path im heading right now. i found an adapter on a ott toyota adapter also. the shop is here in my town and he is buying all the parts and installtion for maybe around 3 grands. i have the 5 lug but i thought either one has the same engine so same tranny too, i suppose. just the front.
  17. Jan 26, 2012 at 1:01 AM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    theres a question i found. is the old 4runner axles way to short for my truck. if im right the old solids are 6 or so inches shorter than what i got?
  18. Jan 26, 2012 at 7:49 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Subbed, I wanna see how this turns out! :popcorn:
  19. Jan 26, 2012 at 8:20 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Probably yeah I'm not sure of the width but I'm pretty sure the older SA toys were all more narrow. Look at a LC axle.
  20. Feb 9, 2012 at 10:29 AM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    well my update of my research. the older ones were to narrow so i found a dana 30 that was just right, 61". better than perfect. its driver diff and needs steering box. does anyone have a clue or could direct me to the correct steering box for my truck? plus a good transfer case for my truck that is driver. plus the best part is i might be the first in the central valley with a solid axle 2 gen tacoma. lol
