Solid motor mounts on a DD
Discussion in 'Long Travel Suspension' started by Mxpatriot, Jul 8, 2012.
  1. Jul 8, 2012 at 8:02 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    Tolerable? Worth it?
    Anyone doing it?
  2. Jul 8, 2012 at 8:12 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    jason (jberry) and JD (CR250jumper) have both recently solid mounted their motor and tranny.
    i'm going to be doing mine ASAP. already got the motor mounts, just gonna box in the stock tranny mount like JD did
    both of them have said it's a night and day difference in terms of performance. the truck handles so much better when all of the weight of the motor is not flopping around. only at idle is the added vibration really noticeable, and they say it is very noticeable, but tolerable and the perks far out weigh the costs
  3. Jul 8, 2012 at 8:15 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    hmm I've been considering it lately
  4. Jul 8, 2012 at 8:17 PM
    Mxpatriot
    I was out jumping the truck on Saturday and came to the conclusion that I need to do it. That and revalve my coil overs for some more compression.
    Any 2nd gens do it yet?
  5. Jul 8, 2012 at 8:18 PM
    PLC721
    Patrick
    Chandler, Az
    i think you should be the first, then give me a full review ;)
  6. Jul 8, 2012 at 8:20 PM
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    My truck has solid motor mounts and tranny mounts. And we have fabbed a couple on my friends gen 1 tacoma's. But these are mainly desert off-road trucks.
    I highly recommend it also
  7. Jul 8, 2012 at 8:38 PM
    Mxpatriot
    DMZ's motor mounts look like they might be the ticket. I wonder how much the bushing flexes compared to the stock mounts... might be a good compromise.
  8. Jul 8, 2012 at 9:39 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    ive make bolt in polyurethane motormounts and trans mounts for the 2nd gen v6 auto's. have a billet version designed just need a decent priced prototype machinist and some real interest .....
    ive have a fabricated set on the red TSA race tacoma that has been going strong for 3 racing seasons, 4 years and thousands of race miles.
    vibrations arent bad at all , compared to a caged truck. but most of the trucks i built them for are dirt only toys , so no notable difference besides a more rigidly mounted drivetrain. but yes there is a noticeable increase in vibrations in the lower rpm ranges
    i say unless your truck is fully caged i wouldent recommend them( or at least a decently built engine/shock tower cage) . too much flex in the stock platform to have rigid mounts. theres been some desert trucks like jeepspeeds that upgrade to solid mounts and end up ripping a section of engine block out. hence my recommendation on having a proper structure
  9. Jul 9, 2012 at 11:39 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    :thumbsup:
    Good info there, I will def be doing an engine cage soon and full cage in the next year.
  10. Jul 9, 2012 at 11:48 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    if you like the shake a lot then it's a great idea. I wouldn't do it on a dd, or even a tacoma. It's mostly a high hp, race car kind of thing. I thought about doing stiffer mounts on my s2000 and decided not to after talking with some people who had done it and immediately swaped oem mounts back in.
  11. Jul 9, 2012 at 7:48 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    By that definition I must drive a racecar :burnrubber:
    Given that this was posted in the LT section, an S2000 has zero comparability with the question at hand. When you're bombing through woops at 60+ MPH and you motor mounts fail and drops right onto your front differential putting a hole in the diff and the block, bending or breaking the a/c lines and possibly power steering lines, you might rethink the need for solid mounts.
    Yes solid mounts will give you more vibrations, but its only noticeable when you're not moving. And for the record, my Tacoma is my DD. I don't have a very far commute anymore, but its still my DD.
  12. Jul 9, 2012 at 7:49 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    your slippers are your DD
  13. Jul 9, 2012 at 7:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Oh and to the OP, if you're worried about vibrations, you can solid mount just one side. I'd suggest the driver's side due to that's where more of the the truck weight is. You'll get some of the the same the benefits of full solid mounts, but without the vibrations. Just put in a brand new passenger isolator in while your at it and change it frequently as all the dampening will be done by that one.
  14. Jul 9, 2012 at 7:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    True, but USPS doesn't deliver to my new house. Fucking snowplows take out the mailboxes. I gotta go to the post office every few days. :eek:
  15. Jul 13, 2012 at 3:04 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Vibrations aren't that bad on a v6, on an inline 4 cylinder they are kind of annoying
  16. Jul 22, 2012 at 9:39 AM
    Defined
    mike
    southern california
    no problem , call me at 951-217-4947 this week or e-mail me at definedengineering@msn.com and we can get a order started.
    -mike
  17. Jul 22, 2012 at 12:35 PM
    ColesDirtyYota
    ColesDirtyYota Well-Known Member
    Cole
    San Diego
    Dezert Built
    Camburg LT Icon 2.5" x 9" coilovers Radflo 2.0" Bumpstops Radflo 2.5" x 16" tripple- Bypasses Deaver F67 Race Pack Richer Racing 12" shackles Full bedcage Full 2" cab cage Tube bumper Solid motor mounts Total Chaos spindle Gussets RR gusseted UCA mounts Total Chaos poly urethane Steering kit T100 axle 4:88's/ Locker AFE dry air intake BA Muffler Trimmed the Throttle Body Fiberwerx 05+ clip Fiberwerx 8" bedsides Full JL speakers/ deck/ sub Rigid Industry 30" LED bar ORW LED amber lights/ brake lights Kenwood Race Radio HF jack with custom skid plat
    I did it and love it. Much more solid obviously and better response in rough areas like whoop sections. If ur trucks not apavement princess then do it. Ull just end up smashing the stock ones in like i did. It just vibrates a bit more in the cab, but personally i like that. Feels like a prerunner should. You should get out of the hobby now if ur worried about some vibration in a truck designed for the dezert...
  18. Jul 22, 2012 at 1:00 PM
    Mxpatriot
    Seconded.
