Solid state relays
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skydvrr, Jan 20, 2020.
  1. Jan 21, 2020 at 7:17 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    The ZigBee / Z-wave stuff is over my head too. I vaguely know what it is / does.
    PLC's aren't that bad once you get into them. Trying to keep up with the latest and greatest software has been my issue. 20 years ago I learned Ladder Logic (basically like relay logic). Todays logic uses a "Concept" and "Function Block" theory. The ladder logic is still there. But it's only seen behind the scenes and by advanced users now.
  2. Jan 21, 2020 at 7:18 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    How are all the rail switches linked, do you have dedicated conduits that run next to the tracks to run fiber and twisted pair? @0xDEADBEEF
  3. Jan 21, 2020 at 7:20 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I've done zigbee for some home projects and a couple at a previous job. It's got a ton of uses and can be anywhere from very simple to complicated.
    We use ladder logic mostly and the market isn't as crazy as the PLC market, so that's nice.
  4. Jan 21, 2020 at 7:23 PM
    0xDEADBEEF
    It's varies a ton based on railroad preference and location needs. Generally though, most long distance signalling is done through the rails. In areas where you've got control points close together and timing is tighter it can be fiber, twisted pair, tin can and a string, Ethernet, radio, whatever.
  5. Jan 21, 2020 at 7:25 PM
    tacoma_ca
    I only use zigbee/Z-wave for home automation in combination with a lot of Lutron Caseta. It works great at home, but obviously doesn't have the reliability needed for important devices.
    PhenixFord[QUOTED] likes this.
  6. Jan 21, 2020 at 7:30 PM
    tacoma_ca
    What kind of frequencies are used for signalling through the rails? I've designed novel RF cables for long distance before, and keep finding more issues with that approach.
  7. Jan 21, 2020 at 7:34 PM
    PhenixFord
    Randy
    Arkansas
    I've been trying to get more into that field. But I find myself suffering more and more from the Old-Fart syndrome. I've installed similar projects using the Lutron x-10 (power line signal carrier) systems. But find myself struggling with systems compatibility when it comes to Home Automation. Maybe it's because I'm trying to utilize Apple / SIRI.
    Just one of many \/ \/ \/
    0xDEADBEEF likes this.
  8. Jan 21, 2020 at 7:36 PM
    0xDEADBEEF
    A lot of it is just DC, slow DC pulses, or sometimes ac. Audio frequencies get used for the shorter distance things like crossings. And yeah it varies considerably with ballast conditions and train presence. Its pretty fascinating how much they can do with such simple signals.
  9. Jan 21, 2020 at 7:39 PM
    tacoma_ca
    If you are looking towards wireless sensors, check out the hubitat forum. That is the best hub for integration by far these days and the devs are very active. In a company you would surely need to use wired devices for reliability and security, but for home use wireless is solid these days. You can tie mulitiple Lutron Caseta hubs into a hubitat hub which provides the common interface.
  10. Jan 21, 2020 at 7:40 PM
    tacoma_ca
    I was thinking that would leak to ground too much, but perhaps the solution is just more current.
  11. Jan 21, 2020 at 7:41 PM
    0xDEADBEEF
    A buddy of mine has done a bunch with the sonoff stuff, I've been meaning to give it a try.
  12. Jan 21, 2020 at 7:42 PM
    0xDEADBEEF
    Pretty much. Low voltage, and a few amps.
  13. Jan 21, 2020 at 7:45 PM
    tacoma_ca
    Sonoff is a lot like the TP-link wifi stuff but has screw terminals. At the end of the day, you want everything in one interface instead of 10 diff apps on your phone. (sprinklers, fans, lights, water alarms, door/window sensors, garage door controller, security cams, temp sensors, etc.) Hubitat is that single point of control for me. It talks to TP-link wifi stuff but I don't think it handles Sonoff.
  14. Jan 21, 2020 at 7:48 PM
    PhenixFord
    Randy
    Arkansas
    I like to stick to "wired" as much as possible. Currently, in my own home, I have "Up and Running" an Ecobee thermostat and a Garage Door Hub that's all Apple compatible. I purchased an Apple TV hub just basically so that I can set-up geo-fencing. But haven't got around to attempting the setup just yet. I've also got a Samsung CCTV setup and operating very well. But interested in more automation that is compatible with Apple.
  15. Jan 21, 2020 at 7:48 PM
    #35
    0xDEADBEEF
    The nice thing about the sonoff is it's just an esp8266 at the heart, so there's some nice open source firmware for it that opens up the possibilities.
  16. Jan 21, 2020 at 7:51 PM
    #36
    tacoma_ca
    Makes sense, am a fan of open source. I made a couple sensors based on ESP8266 which somebody made a driver for from hubitat.
    0xDEADBEEF[QUOTED] likes this.
  17. Jan 21, 2020 at 7:53 PM
    #37
    PhenixFord
    Randy
    Arkansas
    We actually own are own rail system here at work. I have to work on a couple of crossing stations on occasion when the arms get damaged or will not go up. I usually take a long crowbar for testing the signal to the arms. I'm not totally familiar with the system. So sometimes I just simply flip the crossing arm relay to clear the crossing.
  18. Jan 21, 2020 at 7:55 PM
    #38
    tacoma_ca
  19. Jan 21, 2020 at 7:56 PM
    #39
    0xDEADBEEF
    Nobody really likes crossings. They're picky and mechanical to start with, then mix in weather, vandalism and people running the gates. blech.
  20. Jan 21, 2020 at 8:04 PM
    #40
    0xDEADBEEF
    For a while I was using emoncms for temperature monitoring but never wanted to get into controls. Too afraid of someone going haywire when I'm out. Has that been reliable?
