Solo Spindles install looking for opinions
Discussion in 'Long Travel Suspension' started by 661prerunner, Nov 26, 2012.
  1. Nov 26, 2012 at 1:23 PM
    661prerunner
    661prerunner [OP] Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    First off thanks matt for the solo spindles. Im excited with my buy:D but it blows cuz I can't install them yet, not a good feeling just seeing them sit:(
    anyways I have 2 options I'm trying to weight out But im more in to option #1 but have option 2 in mind just to feel the difference in the build process
    Option 1: Get used UCAs save money and get the uniball and heim upgrade for install
    Option 2: Just get the new UCAs and get the uniball/heim upgrade at a later date.
    I guess a 3rd option is just used UCAs once I get some money
    I more or less know my direction but any input is always nice.
  2. Nov 26, 2012 at 2:34 PM
    Davidd
    Davidd Well-Known Member
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    I would just get the ucas... Why do you want the heim upgrade steering?
  3. Nov 26, 2012 at 2:45 PM
    661prerunner
    Santa Clarita
    01 prerunner
    Well thats the point of the thread. My knowledge is limited on this.
  4. Nov 26, 2012 at 2:48 PM
    Davidd
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    Just get the ucas. $800 upgrade for a mid travel truck is pricey. You can save that cash for long travel, plating areas like the frame, motor mounts etc which will cost more down the road if not taken care of
  5. Nov 26, 2012 at 2:55 PM
    661prerunner
    Santa Clarita
    01 prerunner
    For sure. I am going to do the coil buckets at time of install. I was saving for LT before I bought the spindles. But now MT for the front and LT for the rear in due time.
  6. Nov 26, 2012 at 3:03 PM
    Davidd
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    Sounds good. You can use that upgrade money on the rear LT or front plating.
  7. Nov 26, 2012 at 3:07 PM
    661prerunner
    Santa Clarita
    01 prerunner
    How would getting the steering upgrade be better on a LT the MT. would it benefit one more then the other.
    Lets put the cost thing aside on this questions
  8. Nov 26, 2012 at 7:19 PM
    Anthony250
    Anthony250 E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    I would Do what david said. Save the money for other things, Im Lt and still got balljoint lower and stock extended steering with no issues, Yet im seeing the need to reinforce things more than ever. The steering upgrade would only mainly benefit the uniball lower which is stronger,and probably slightly smoother steering with the hiem. There is no travel increase with the Hiem steering anyways i belive.
  9. Nov 26, 2012 at 7:38 PM
    Davidd
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    I am also running stock ball joints and stock tie rod ends. As long as you do your duty on replacing these components you will be good. Heim steering helps maximize wheel travel but it is only small increments if any on LT. Not sure if you would see any gains running MT.
  10. Nov 26, 2012 at 9:37 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    you can only run the heim steering/lower uni ball conversion with LT lower arms. you're sticking with stock lowers so it's not an option for ya
  11. Nov 27, 2012 at 5:21 PM
    661prerunner
    Santa Clarita
    01 prerunner
    well my mind is made up now. Money will go on to the rear:D
