Solution: Fix hyper blink after doing Fog Light Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by RushTacoma, May 1, 2010.
  1. May 1, 2010 at 9:04 AM
    RushTacoma
    RushTacoma [OP] Toyota Member
    Jonathan
    Georgia
    2012 PreRunner
    To fix the hyper blink after doing the Fog Light Mod you can buy a LED resistor for $10 or you can just up your bulb size to 921 instead of 168. I just went and bought the 921 bulbs for my 03 tacoma to kill the hyper blink thanks to SRQ Taco for the advice and it worked! No more hyper blink and the bulbs cost $4.99 at autozone.
  2. May 1, 2010 at 9:17 AM
    747 function > form
    1st Gen.
    So the 921's are direct replacements (i.e., fit w/o modification) into the corner lamp bulb sockets?
  3. May 1, 2010 at 10:11 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    No problem I'm glad I could help :D
    Correct good sir!
    And to also put the 921's are way brighter than the stock 168's.
  4. May 1, 2010 at 10:21 AM
    RushTacoma
    Jonathan
    Georgia
    2012 PreRunner
    Yes! 921 bulbs are direct replacement! No modification need just plug them in and your good. There bigger bulbs than the stock 168 and so they are much brighter but like i said NO MODIFICATION needed and it fixes the hyper blink!
  5. May 1, 2010 at 2:09 PM
    747 function > form
    1st Gen.
    Amber 921s added...sweetness! Now oncoming vehicles can actually tell when my blinker is on.
  6. Oct 14, 2010 at 3:08 AM
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    Awesome guys thanks for the info - I am doing this mod this weekend -
    What bulbs did you all actually use for the "fog" lights? Stock or something different?
  7. Oct 14, 2010 at 6:23 AM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    Good call!! I'll be doing this mod soon!!
  8. Oct 14, 2010 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    For what its worth, my experience was different. I did this mod to turn my corner marker lights into turn signals. Swapped the green wires and of course had the hyper blink in the turn signals afterwards. Put in the 921NA bulbs, however, it did not slow down the hyper blink.
    Yes, 921s are higher wattage, yes they are brighter than 168s or 194s. Unfortunately, on my truck I had to add the load balancer/resistors to slow the hyper blink to a normal speed.
    It is not clear why this seems to work on some and not on mine. :confused:
  9. Oct 14, 2010 at 9:45 PM
    bfogelma
    bfogelma Well-Known Member
    Brandon
    Bend, OR
    2011 DCSB
    i recently did this mod and now i have the running lights down low but the corner lights are not functioning as blinkers, anyone have any suggestions?
  10. Oct 15, 2010 at 12:26 PM
    bfogelma
    Brandon
    Bend, OR
    2011 DCSB
    update: put the bigger bulbs in and pretty much fixed the problem, they not only light up properly but also dont have the hyperblink!
    by the looks of it i fried the smaller little bulbs in there... for future reference those doing this to an older truck like mine you should probably just invest in new bigger bulbs off the bat.
  11. Oct 18, 2010 at 6:57 PM
    rrosebr
    rrosebr Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    But wouldn't you still need to change out the socket to a dual filament socket so that the light would function as the blinker and parking lights.
  12. Nov 12, 2011 at 6:03 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    x2 Need to know
  13. Nov 12, 2011 at 6:25 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    If you haven't already done so, check out Beau02's excellent write-up. A materials/parts list is located on page 6.
    FWIW, I used a pair of clear 4157 Siverstar bulbs as "fogs". (If anybody knows of brighter options, without requiring additional modification/rewiring, let me know...)
  14. Nov 12, 2011 at 10:39 PM
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    if i remember correctly arent the 921s the same as the bulbs in the dash? if so i could use the ones i have from my dash in the corners?
    i did the dash led mod so i have the orig. dash bulbs laying around
  15. Oct 17, 2012 at 7:54 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    the 921s don't work on my rig either... what size load resistor did you use? and it just goes in-line to the (+) of the "new" blinkers ?? thanks
  16. Oct 17, 2012 at 10:51 AM
    Digiratus
    Roaming the PNW
    The RedHead
    One end of the load resistor connect to the power wire, the other end connects to the ground wire. This adds resistance to the circuit and makes the ECU think a higher wattage bulb is being used and stops the hyperblink.
    It's been a while but IIRC, I used a 6 ohm resistor.
    http://www.superbrightleds.com/pdfs/load_resistor_info.pdf
  17. Oct 17, 2012 at 4:43 PM
    TIPICOTACO
    Tyler
    nw nj
    ^ ah ha Thank you!
    FINALLY got around to adding the 6 ohm resistors... hyper blink solved. :D
    thank you for the advice!!!
