Solution for springs.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Silver96, Aug 30, 2009.
  1. Aug 30, 2009 at 11:23 PM
    Silver96
    Silver96 [OP] Active Member
    I've got a '96 with squeeky leaf springs. It was suggested that I remove and sand each spring to remove any rust and dirt . Then apply two coats of "Slip Plate" graphite paint. Anyone with experience with this product or any other simular graphite paint? I'm looking for a solution and not a temporary fix. I may be too late on this but what is this "TSB" pertaining to leaf spring replacement? Any and all suggestions are needed. Thanks.
  2. Aug 30, 2009 at 11:30 PM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    i pressure washed mine out and sprayed wd40 everywhere in and around them and they stopped squeaking
  3. Aug 30, 2009 at 11:43 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    pressure wash then spray white lithium grease from auto zone/advance auto between the leafs. ive found it lasts longer than wd40
  4. Aug 31, 2009 at 2:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2....................definitely pressure wash the springs out, and dont use wd-40.....it collects dirt and suck. a good dry moly lube will stay on/between the springs,and will repel dust.
    YetiManetti likes this.
