(SOLVED) 2002 Overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomahound555, Jul 19, 2023.
  1. Jul 20, 2023 at 3:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That's not overheating, I would consider overheating to be 3/4 or higher.
    Do you have a scan tool to read actual coolant temp?
  2. Jul 20, 2023 at 4:34 PM
    Tacomahound555
    Tacomahound555 [OP] Well-Known Member
    That's fair. I was using overheating as a blanket term for anything above operating temperature on the gauge but that makes more sense. I have an OBD2 scanner, not sure if that'll work but I'll try it out real quick.
    Mine does not scan for the temperature
  3. Jul 20, 2023 at 4:47 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If it can read engine data there should be a PID for Engine Coolant Temp.
  4. Jul 21, 2023 at 12:41 AM
    Tacomahound555
    I'll take a look at my obd2 tomorrow. Would be nice to see real engine temperature instead of relying on just a gauge
    It was getting hotter before I burped the cooling system but I'm starting to think the water pump is beginning to fail. Here's the symptoms
    Temperature rises a little bit when it's in idle or at low rpms
    Warm air sometimes comes out of the AC
    Looks like dried coolant residue on the outside of the water pump
    Clacking noise like in this video and it sounds like it's coming from where the water pump is
    https://youtu.be/SBYE0l7b1Y8
  5. Jul 23, 2023 at 11:00 AM
    Tacomahound555
    Decided to start from the beginning and change the temperature sender I changed last week. No overheating since so I'm chalking it up to a faulty temperature sender
    Madjik_Man likes this.
