(Solved) 3rz starts and dies, no CEL
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zach3rz, Feb 18, 2024.
  1. Feb 29, 2024 at 8:41 PM
    #41
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure what TE1 is for but the com line between the PCM and scan tool is the SDL line that goes from E5 Pin 7 (White) at the PCM to Pin 2 (White) at DLC 3
    Have we checked 5v ref? I didn't see where you did?
  2. Feb 29, 2024 at 8:45 PM
    #42
    Zach3rz
    Zach3rz [OP] Well-Known Member
    Zach
    1997 toyota tacoma 2.7 3rz
    Pin #1 on the 16 pin connector is getting 5.5 volts
    TnShooter likes this.
  3. Feb 29, 2024 at 8:45 PM
    #43
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I listed the checks in post #24
    Then asked this, to emphasize that pin.
    OP reasoned this. I can only take his word for the values.
  4. Feb 29, 2024 at 8:47 PM
    #44
    Zach3rz
    Zach
    All the pins that had voltage reference on the diagrams in the thread are dead on except the te1
  5. Feb 29, 2024 at 8:49 PM
    #45
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Your talking about Connector E7 Pin 1 (Green/Yellow)?
  6. Feb 29, 2024 at 8:52 PM
    #46
    Zach3rz
    Zach
    Yes it has 5.5 volts
  7. Feb 29, 2024 at 8:59 PM
    #47
    TnShooter
    Deogee
    STOCK
    Yes.
  8. Feb 29, 2024 at 9:00 PM
    #48
    TnShooter
    Deogee
    STOCK
    I’m operating off Chiltons.
    They call it the 16 pin connector.
    But yes, that is the one we have checked.
  9. Feb 29, 2024 at 9:01 PM
    #49
    Zach3rz
    Zach
    If you didnt read back through the thread this is the issue at hand. No cel with key on or any other position. Truck will start on the fuel pumps prime but the fuel pump is not getting its signal to stay on (im assuming that is how it operates)
  10. Feb 29, 2024 at 9:02 PM
    #50
    TnShooter
    Deogee
    STOCK
    It won’t unless it sees a crank signal.
    Or at least, that’s how most Toyotas work.
    But Dm knows more than me.
  11. Feb 29, 2024 at 9:06 PM
    #51
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok TE1 is the test terminal, on older Toyotas you grounded it to flash the codes out on the CEL and put the PCM into test mode. It's use on a 97 is not clear in service info, I can't find any info on it.
    Have you checked that wire for a short to ground?
  12. Feb 29, 2024 at 9:08 PM
    #52
    TnShooter
    Deogee
    STOCK
    Not, yet. He hasn’t.
  13. Feb 29, 2024 at 9:09 PM
    #53
    TnShooter
    Deogee
    STOCK
    See why I tagged you?
    I looked for info on TE1 before I tagged you. :rofl:
    I was lost, I figured maybe you’d know. :D
  14. Feb 29, 2024 at 9:13 PM
    #54
    TnShooter
    Deogee
    STOCK
    OP, disconnect the 16 pin a E7 connector.
    Use a test light. Hook the light to battery power, and prob pin 1 on E7 (16 pin)
    If the light comes on, you have a short.
    Or you can use a voltage meter too.
    But I like to use a light.
  15. Feb 29, 2024 at 9:14 PM
    #55
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean I know what it's for on the older Toyota vehicles, it's purpose here isn't clear to me though.
    Is the an auto or manual truck?
  16. Feb 29, 2024 at 9:14 PM
    #56
    Zach3rz
    Zach
    This may sound stupid but what would be the best way to test it for short to ground? I have a decent multimeter its a blue power CBPDM300 from cornwell and i have a power probe also
  17. Feb 29, 2024 at 9:14 PM
    #57
    Zach3rz
    Zach
    Manual
  18. Feb 29, 2024 at 9:15 PM
    #58
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd probably do a resistance check on that one, it's just a sense circuit so it wouldn't take much to pull it to ground.
    TnShooter[QUOTED] likes this.
  19. Feb 29, 2024 at 9:15 PM
    #59
    TnShooter
    Deogee
    STOCK
    See my post above:thumbsup:
  20. Feb 29, 2024 at 9:16 PM
    #60
    TnShooter
    Deogee
    STOCK
    You can explain that one. :rofl:
    I could, but I tend to make things “more complicated” in my explanations.
