SOLVED: another clunk diagnosis thread.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rambrose1, Jul 27, 2016.
  1. Sep 20, 2016 at 10:28 AM
    #41
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    Got front shocks and shock assemblies replaced under warranty. All good and rides great, with no more clanks clinch or suspension noise.
  2. Sep 21, 2016 at 9:09 AM
    #42
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    everything is tight, so i give up. on with the clunking..
  3. Dec 29, 2016 at 3:04 PM
    #43
    electra_boogaloo
    electra_boogaloo Well-Known Member
    2007 Double Cab Long Bed
    my truck stopped clunking recently. now it's popping and creaking. aka, cv joints. specifically the inner ones. they were dry rotted and torn when i got the truck and i'm guessing there was some moisture in there causing the joint to get stuck and suddenly release with a loud thud. i will be replacing them with napa cvs soon and hopefully have a nice quiet truck agian.
  4. Mar 27, 2017 at 6:11 AM
    #44
    danteisme
    South Western PA
    i recently looked at my LCA bolts again to check for tightness, both were loose. i tightened them up again back to spec. and now my clunking is gone....again. I'm not sure why they keep loosening up, is it worth getting another nut on each one of those LCA bolts and crank it down to the other factory nut so it prevents them from backing out again?
    PStan likes this.
  5. Mar 27, 2017 at 8:52 AM
    #45
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Thread locker might be easier.
  6. Mar 27, 2017 at 8:58 AM
    #46
    danteisme
    South Western PA
    True, but i would have to remove the nut most of the way to get the locker on there. i dont want to throw my alignment out of whack.
  7. Mar 27, 2017 at 9:19 AM
    #47
    ItalynStylion
    Steven
    DFW, Tx.
    Can't you just mark the setting and then install it so the marks line up after you apply the locker?
    TacoTuesday94 and KingTaco81 like this.
  8. Mar 27, 2017 at 9:20 AM
    #48
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    I had the same clunk on my truck. LCA bolts where not tighten properly at last alignment. It only took a few days after alignment to start making the clunk when changing directions and wheels turned ( backing up turning right then going forward turning left). I got a new free alignment and watched the tech torque the cam bolts. My son's Tacoma had a similar clunk but only when the suspension articulated ( going onto the driveway or coming off the driveway). It was the sway bar link bolt. Double nutted it and problem solved.
  9. Mar 27, 2017 at 9:51 AM
    #49
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    Should be able to remove the nut without turning the bolt or losing alignment. Just mark your cam tabs before if you are unsure. Also if you have room to double nut it that should work too. Most likely coming loose because you need new cam bolts. Threads may be damaged from driving while loose. Contrary to what many people think, bolts are a wear item that occasionally need to be replaced
    PStan likes this.
  10. Mar 27, 2017 at 1:11 PM
    #50
    danteisme
    South Western PA
    Does anyone know if the cam bolts were to be replaced during the frame recall?
  11. Mar 27, 2017 at 3:42 PM
    #51
    devkurf
    devkurf Member at Large
    midwest
    I'm almost positive they were.
  12. Mar 28, 2017 at 5:23 AM
    #52
    danteisme
    South Western PA
    Interesting. I'm going to see what the dealership's take is on this. The frame recall was done right before i purchased the truck, so i'm not even sure which dealer did the work.
  13. Apr 4, 2017 at 10:51 AM
    #53
    danteisme
    South Western PA
    I called the dealership i go to, they said the control arm bolts are replaced during the frame recall. I had to get off the phone to take another call, but i will call them back and ask them if they care what dealership did the recall work.
  14. Apr 5, 2017 at 9:27 PM
    #54
    HooDoo
    HooDoo Member
    2015 Tacoma TRD 4WD
    I just did a lift on my 2015 trd 4wd today and the only thing I'm a tad uncomfortable with is the 100 lb torque spec on those LCA bolts. At 100 lbs I swear it was going to strip so I backed off to 90 and it still wasn't clicking at what I felt was well into the danger zone. So again I backed off to 85, got it to click, then re-upped to 90 and got it to click there, but I was not willing to go beyond that.
    I might add that I'm no stranger to wrenching. Worked on cars and motorcycles all my life and I'm 56 now. I can't help but question that spec. Everything else torqued to spec with no doubts, including the 118 lb bolts on each side of the lower ball joints. Any thoughts on this? I'm wondering if this spec is wrong and perhaps it relates to loosening down the road due to over-tightening/thread damage, etc..
    jetfishn likes this.
  15. Apr 6, 2017 at 5:52 AM
    #55
    danteisme
    South Western PA
    i felt the same way when i was checking these bolts the first time. With how much i was cranking on them, i thought for sure with my next turn of the wrench i would have a broken lca bolt to deal with.
  16. Apr 7, 2017 at 1:08 PM
    #56
    HooDoo
    HooDoo Member
    2015 Tacoma TRD 4WD
    I felt the they would strip rather than break. 100 lbs is a lot for a nut that size. I left mine at 90 lbs. It'll be loosened and re-torqued by the alignment fellers anyway, so it surely isn't hurting if I'm a tad light for minute. I was reading another post here that said there was a typo (incorrect value) on one of the torque settings on the front end but I don't recall which bolt was in question or the source of the values. That's why I brought up the possibility.
  17. Apr 7, 2017 at 1:17 PM
    #57
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    The manual states 37 ftlbs and it is actually 73 ftlbs on the rear leaf spring u bolt nuts. The value is correct for the cam bolts. Everytime I get my truck back from the alignment shop they are under torqued.
    PStan likes this.
  18. Apr 7, 2017 at 11:00 PM
    #58
    HooDoo
    HooDoo Member
    2015 Tacoma TRD 4WD
    I installed my add-a-leafs today and when I was ready to torque the u-bolts I had to look that up and I saw that. I'm sure that's what I remembered seeing, something I was going to have to deal with during my lift rather than a value specifically on the front end.
    So I assume you re-torque your cam bolts to spec after your alignments or just observing the shops values? Way under is not good but close counts. Hoping to get it aligned tomorrow but no appt. yet.
  19. Apr 8, 2017 at 9:27 AM
    #59
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    Anyone know if the total chaos cam tab gussets would prevent them from coming loose? My 15' makes the same clunk. I removed the sway bar since it happened after wheeling and I thought I bent it, then I added ORI Struts, so there are no coils now. Still have clunk
  20. Jun 8, 2018 at 11:51 AM
    #60
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Your Lower Control Arm bolts were 20 to 40ft/lb?
    Did you tighten both sides LCA bolts to 100 ft./lb?
