SOLVED: another clunk diagnosis thread.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rambrose1, Jul 27, 2016.
  1. Feb 26, 2021 at 7:50 PM
    #61
    alxhrs
    alxhrs Member
    Had an alignment done after I put in some billies + aal. Right after the alignment lots of popping, creaking, etc. Thought it might settle out over time. I had specifically asked them to check all the main suspension bolts and torque them to factory settings since I had messed with it, they confirmed they did. I checked the LCA bolts, they were at around 20ft pounds torque, not 100 like they should be. Torqued them up and all the noises are gone.
  2. Mar 14, 2021 at 6:22 PM
    #62
    THEPYRITETACO
    THEPYRITETACO Well-Known Member
    NC
    2014 TRD Sport 4x4 DCLB
    Had the clunk. Tightened the LCA bolts. Clunk is gone. TW FTW.
    RHHousehold likes this.
  3. Jun 23, 2021 at 1:24 PM
    #63
    SoTexTacoma
    SoTexTacoma Well-Known Member
    Whidbey Island
    '14 TRDOffroad
    BP-51 w/Dakars MobTown Hybrid Bumper All-Pro skids Redline Hood Struts AllPro bed bars A lot, really.
    For those of you that notice the clunk in a “dip” situation.
    I had the same experience in my truck i ended up replacing the lower bushing in the shock mounting point itself. Was NOT easy without a press, but when it was complete, no more clunk. When i inspected the mounting point, there was a noticeable difference in how low the drivers side eyelet was inside the LCA mounting point. This was over a year ago and the sound has returned. Bit i believe it may be the passenger side that is the culprit now. I’ve decided I’m just going to live with it for now. Planning on upgrading to the 6112 soon, but having trouble sourcing them.
    Just a suggestion.
