[Solved] Best Way to Disable Ignition When Checking Compression on 3.4 Liter Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Jun 8, 2019.
  1. Jun 8, 2019 at 2:17 PM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    It's been over 55 years since I last checked the compression on an(y) engine. So-o-o,
    What is the easiest and safest way to disable the ignition while checking compression on a 3.4 liter engine? I need to do this to make sure my problem is not compression-related.
  2. Jun 8, 2019 at 2:24 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I’ve never done this either but maybe disconnect the + side of the battery and run a lead from the battery’s positive post through a switch to the + post on the starter after removing the cable that is connected to it to prevent any chance of back feeding. That way no power goes to the ignition but you can turn the starter using the switch.
  3. Jun 8, 2019 at 2:29 PM
    mrl390
    mrl390 Well-Known Member
    2019 Tacoma Double Cab TRD Off-road
    Pull the fuel pump relay so the engine won’t get any fuel. That way it won’t pump fuel into the cylinder and up into your gauge when you crank it. Engine won’t fire and you’ll get a more accurate reading without ruining your compression gauge.
    CD20H likes this.
  4. Jun 8, 2019 at 2:33 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Disconnect the primary coil wires. Not the spark plug leads but the wires that supply voltage to the coils. I agree with mrl390.....disable fuel also.
  5. Jun 8, 2019 at 5:09 PM
    skeezix
    Colorado
    1998 Limited
    Here is a diagram of the fuel pump operation:
    As shown in the following diagram, the Circuit Opening Relay is high up behind the instrument panel. I'm a pretty big guy and I don't think I can reach it.
    Is this a better spot to disconnect the fuel pump? At least I can get to it (I think, anyway).
    Thank you for your help.
  6. Jun 8, 2019 at 5:23 PM
    mrl390
    Most fuel injected vehicles have some kind of fuse or larger relay in the BCM/fuse box for the EFI or fuel pump or sometimes both. Check the diagram for your fuse block to see where it is. Test to make sure you pulled the correct one by turning the ignition to on and listen to whether the fuel pump primes or not. Then try to start the engine if it doesn't start then you cut off the fuel supply and should be good
  7. Jun 8, 2019 at 8:05 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    Remove the 7.5 amp ignition fuse from underneath steering wheel.
    But, yeah, disabling the fuel as noted above would be good, as well.
  8. Jun 8, 2019 at 11:17 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Pull the EFI fuse and disconnect the main power wires going to the coils. Just recently checked compression on a 3.4 3rd gen runner.
  9. Jun 9, 2019 at 12:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The simple way is to disconnect the ECM ground .
    You can also unplug the igniter which will also shut off the fuel. No bending or getting on your knees to reach things
    To us older people unplugging the igniter is like the coil wire in our days
    When your all done just clear all the codes
  10. Jun 9, 2019 at 12:10 PM
    skeezix
    Colorado
    1998 Limited
    What's the trick to pulling the 15 amp EFI fuse up and out of the fuse box (on the driver's side under the hood)? It appears to be stuck. I'm using a little pick tool pull it up but the fuse won't budge and I'm afraid I might break it if I pull any harder. Is there some kind of latch or lock?
    Just how much force is needed to remove those little fuses anyway?
    Or alternatively, at what point on the truck is the ECM ground that Wyoming09 referred to?
    Or, where is the "igniter" that he mentioned?
    Once I get that done, I'm ready to check the compression.
    V8 engines were a helluva lot simpler dontcha know...
  11. Jun 9, 2019 at 2:02 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If it hasn't been pulled for a while then it can definitely be hard to pull out. The OEM little puller thing in the cover of the box has always worked for me. Sometimes on other vehicles I've had to use these mini needle nose plier things. But was always able to pull the fuse.
  12. Jun 9, 2019 at 4:39 PM
    skeezix
    Colorado
    1998 Limited
    Yes, now I remember the extractor. Never thought to turn the cover upside down. Thank you Mr. Cruiserguy.
    cruiserguy likes this.
  13. Jun 9, 2019 at 7:10 PM
    cruiserguy
    Elijah
    SEKS
    No problemo. Those fuses are almost impossible to remove without that protruding leading edge on those tweezer/tool things
  14. Jun 9, 2019 at 10:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've always just disconnected the coil packs. Disconnecting the crank position sensor won't allow spark either. Sounds like there are many ways to skin this cat
  15. Jun 10, 2019 at 5:55 AM
    skeezix
    Colorado
    1998 Limited
    The coil packs are out. I was trying to see how to disable the fuel pump so I could crank the engine without fuel squirting all over and making my day...
  16. Jun 10, 2019 at 6:31 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You won't get fuel in your gauge. If the ECU doesn't get all the parameters set to 'run', it's not pumping fuel.
    Disconect the injector wiring if still worried.
